#1065 | |
Drives: 15 ZN6 Asphalt
2017 Subaru BRZ Facelift
Usually I already fill up by around 8 to 9 gallons. I do hope on next generation Toyota/Subaru should give a car an option to increase the fuel tank capacity like how the 911 do it would be great option for daily grinders like myself or for long commutes. Sent from my iPhone using Tapatalk
2015 ZN6 DD AT
#1066 | |
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (07-26-2016), daiheadjai (07-26-2016), darthpnoy1984 (07-26-2016), Mim (07-26-2016), SStratos (08-03-2016) |
#1067 | |
Hail Magnet
Except we're not worth the time or investment. So you can either continue to fill up right when the low fuel light comes on, or trust that you wont be out when the needle hits "E" (which I have been to and can tell you I still had over a gallon left in the tank). Largest fillup since ive been keeping track was about 11.5 gallons, but I remember doing slightly over 12 at some point early on. |
#1068 | |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | nikitopo (07-26-2016) |
#1069 | |
Time Traveller
Under load, the stiffest wheel is going to deform the least in the aforementioned directions thus providing the most predictable tire contact patch shape and behavior thus directly affecting driving dynamics. ![]() The trade-off is that generally stiffer = heavier unless more exotic design, materials and mfg techniques are used thus increasing cost. To your average street driver, this might not matter. To someone involved in motorsports it will. If Toyobaru has improved the stiffness of the wheels on the 86 without passing the cost on to owners than it is definitely worth mentioning as a value-add. Buying aftermarket wheels to achieve the same effect is a real cost. |
| The Following 4 Users Say Thank You to DAEMANO For This Useful Post: | funwheeldrive (07-26-2016), nikitopo (07-26-2016), Sport-Tech (07-26-2016), Yoshoobaroo (07-26-2016) |
#1070 | |
TRACKBREAD
1. Both wheels are low pressure cast and weigh about the same, so the difference in stiffness would be due to geometry change in the face of the wheel, which is minimal. 2. This car is light and not able to put THAT much load on the wheels. If BMW can get away with thin spokes on their 4000lbs+ M5/6, we can too. 3. Contact patch will vary much more due to bushing deflection than wheel deflection. let alone the deformation of the tire itself. These aren't formula 1 cars. Unless I see data that proves otherwise, I'm willing to bet you cannot feel the difference between the 2, OR measure it with a stopwatch outside of a statistically significant margin of error. |
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#1071 | |
1st86 Driver!
Honestly, I wouldn't want the tank to be much bigger. I average 343 miles to the tank over 4.5 years. No reason to haul an additional one or two gallons around for 343 miles just to go another 30-60 miles.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | darthpnoy1984 (07-26-2016) |
#1072 | |
Time Traveller
| The Following 3 Users Say Thank You to DAEMANO For This Useful Post: |
#1073 |
I just want to know when I can buy carbon fiber wheels for this car.
| The Following User Says Thank You to funwheeldrive For This Useful Post: | Sport-Tech (07-26-2016) |
#1074 |
Drives: TBD
#1075 |
TRACKBREAD
#1076 | |
Time Traveller
Thanks for the P.S.A. anyhow. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | funwheeldrive (07-26-2016) |
#1077 | |
TRACKBREAD
You fail to consider that the aluminum of the wheels is literally ten thousand times stiffer than tire rubber (Young's Modulus of ~7*10^10 vs ~7*10^6). That means that, roughly, if the tire deflects 1" (pretty extreme, but for the sake of argument), the wheel will deflect 1/1000th of an inch. The wheels aren't even cast to that tolerance, not even close! Most OEM wheels are held to a ~3mm tolerance (118/1000ths of an inch). Stiffening the stock wheels to improve the handling of a car is a fool's errand. Considering that the old wheel style performs more than adequately, any stiffness gained in the new wheels will have a virtually immeasurable effect on the car's handling. It's neat to put in the brochure though. -Josh |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | funwheeldrive (07-26-2016) |
#1078 |
Drives: MY11 Maxima 350st, MY15 BRZ
Its only been mentioned as a marketing ploy, to make people think the wheels are special in some way and, be less likely to feel the need to swap them for something after market.
I like the look of the new ones, but then I also like the look of the old ones too ^_^"
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
| The Following User Says Thank You to Mim For This Useful Post: | Yoshoobaroo (07-26-2016) |
| Tags |
| -20hp heavy body kit, 10/10 do want, 2017, better than the 86, facelift, more drag same hp, update, would bang (gears), zaku goes to ct |
| 2017 FRS Official Facelift Pics | Zhangy | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-17-2016 06:06 PM |
| When will we see the facelift revealed? | airjonny | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 03-17-2016 05:04 PM |
| 2017 Toyota 86 facelift | TMXSTAR | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-17-2016 12:06 PM |
| Were they not going to debut the 2017 facelift end October??? | gt8613 | BRZ First-Gen (2012+) -- General Topics | 10 | 11-16-2015 10:21 AM |
| FR-S/86 Facelift render | JW89225 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 11-04-2015 07:43 PM |
