#141 |
Drives: 2014 GT86
tawheed: there should be no illeffects for this mod that i know off, and most that did liked change in clutch pedal feel.
However if you are also doing clutch pedal dead travel adjustment, be more careful with that, leaving some free travel, not taking it all out with adjusting engagement point right after from fully pressed. Very slight clutch drag sometimes hard to notice, and for sure disengage you'll press more, so it will chew quickly through flimsy stock rubber clutch pedal bumpstop. |
#142 |
I would like to do this mod. But all the pictures are gone due to the hosting site.
Can someone repost the tutorial with pictures? also, as far as pedal height.....what are people looking for. I've owned 2 manuals in my life and never adjusted the height, so what would I be looking for in that realm. I'm 5'7 if that matters. |
#143 |
Drives: 2014 GT86
IIRC in pedal travel adjustment mod it was mentioned "slightly lower then brake pedal", but on mine it resulted in slight clutch drag. Car didn't move in gear with clutch pressed, when giving some gas, but engaging reverse was noticeably harder, so i dialed back some dead travel, some 0.5"/1cm of pedal travel from felt bite point. Lesser then stock dead travel, but not with felt clutch bite right away from full press.
#144 |
Well google is your frienemy. I found a Youtube video showing how to remove it. Simple. I did lose the E-clip though, it went flying, somwhere. It came off with very little force in about 10-15mins of work.
Everything else is oiled and in a Ziploc for storage. I had very little slop in the first few mm's of depression of the pedal. I like the harder feel of the clutch and I must say the engagement points are easier to feel. This mod will stay on my car. |
#145 |
Drives: 2013 FR-S, 2015 TC
Worth every theoretical penny. Just did it before my 45 minute drive to work and it made the feel of the pedal infinitely better.
Sent from my Nexus 6 using Tapatalk
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
#146 |
Drives: '17 BRZ w/ PP || MBTA
What's the easiest way to reinstall it? Specifically compressing the spring enough.
#147 | |
Drives: Car
#148 |
Drives: Satin White Pearl
Hey guys so I just took the spring out and I have a question for people who also has a tune with an OFT. After I took the spring out I tried to recline it but it stops to where the launch control is set. Is this normal?
#149 |
Drives: '17 86
Pulled the spring this morning. It now feels more like what I'm used in my All Trac/GT4 Celica. Definitely worth doing in my opinion.
| The Following User Says Thank You to nitro_alltrac For This Useful Post: | stevesnj (09-24-2017) |
#150 |
Drives: Black Panda BRZ
Apologies for the bump, but I have never seen so many likeminded people on one thread! Just done this 4 years after buying my first brz, and so wish I had done it straightaway - this car has always made me feel like an amateur when changing gear (20+ years of driving exclusively stick) with it's vague clutch. First drive after removing spring and I feel like i can drive properly again.
Can honestly say if I was only allowed one mod on this car, this would be it. Just done it on my impreza too with exactly the same huge improvement. Feel like i've wasted years of satisfied driving time waiting until now. And would echo tips above about making sure pedal is fully depressed when doing the mod to reduce knuckle skin loss... Last edited by jonboy99; 05-02-2018 at 09:45 AM. |
| The Following User Says Thank You to jonboy99 For This Useful Post: | jcw99 (11-23-2017) |
#151 | |
Drives: Toyotas 86 (2013) & RunX RSi (2003)
#152 |
No, I'd definitely give it a while with the spring in place - some (maybe most?) seem to be quite happy with the clutch, in which case there's no need to have a heavier clutch for no reason. I started driving in the early 90s so may just be I got used to those less modern clutches and can't adapt. For me though, this mod is night and day.
#153 | |
Drives: 2017 Subaru BRZ
Thanks to OP for this illustrated guide. It was a great help. |
#154 |
Drives: 2015 FRS
I also did this recently as really the first mod (other than small bulb changes) that I did to my car; mind you, I'm a complete newb at modifying anything on cars.
This DIY was fairly straightforward and definitely worth doing. Really the hardest part for me was getting the pin out and then putting it back together sans spring. Had to use a hammer and really use just brute force to get it back together. The difference is night and day, even my friend who I let test drive it (spring in, then spring out) felt it was way better. This is my first manual car so I had thought that maybe me jerking into gears at times was because I sucked at manual but having the spring out has been smoothing the ride out for me, so maybe I don't suck as much as I initially thought. Do it, definitely recommend! |
| The Following User Says Thank You to HBK86 For This Useful Post: | jcw99 (11-27-2017) |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 01:40 PM |
| How To: Clutch Spring Removal in 15 Minutes | eric6 | DIY (Do-It-Yourself) Guides | 165 | 02-15-2017 12:44 AM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 04:42 AM |
| Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 11:14 PM |
| Clutch Spring Removal & Throwout Bearing | DemonRawr | Issues | Warranty | Recalls / TSB | 2 | 05-13-2015 09:08 PM |
