#13693 | ||
"DGM BRZ"
Drives: 2016 BRZ Limited
Nope. There's currently no adapter on the market to make it work with the '16 harness. The AX-TOYUSB-1/2 will NOT work with a 2016 starlink Subaru.
You don't need the dash kit to mount your radio to the car, so don't waste your money on it unless you don't mind the look. Existing radio guides for the 2013-2015 BRZ will tell you to wire the blue power antenna wire on the Toyota Metra 70-1761 to your blue/white remote power (System Remote Blue/White on Pioneer decks) to turn on the door speaker amps. This is incorrect for 2016 models. You need to wire your blue/white remote power wire to the 9th pin (Brown wire) of the 28 pin data harness, which is the 3rd wire harness coming out of the car. This harness is for the backup camera, the integrated mic, the door amp power, and more. For the reverse camera to work you need a voltage regulator to step down the 12v power from the car harness to 6v, the required voltage for the OEM rear view camera. I suggest buying this: [ame="http://www.amazon.com/gp/product/B00CGQRIFG"]Amazon.com: DROK® Waterproof High Efficiency Car Power Converter DC12V to 6V/3A Step Down Voltage Module 9-22V to 6V Power Supply: Electronics[/ame] Splice into your 12V accessory power wire to the red 12v INPUT wire of the regulator and wire the black ground wire to the black INPUT ground wire on the regulator. Wire the yellow 6v OUTPUT wire of the regulator to pin 11 of the 28 pin harness (this will power on the OEM camera). Wire the black OUTPUT ground wire to pin 22 of the harness (camera ground). I removed the prewired RCA plug with pins on it from the useless AX-TOYCAM2 harness I had laying around... if you don't have that harness just cut up any old RCA cable and separate the copper ground from the signal wire inside of it. The signal wire is your + (pin 12) and the ground is your - (pin 13) - plug them into their respective holes on the 28 pin harness. I then plugged the other end of the RCA cable into the rear camera input of my Pioneer AVH-x8500BHS. Remember to go into your settings and change the Camera from "Off" to "Battery" (not "Ground"), and set the camera to NTSC under "Video Signal Options"
| The Following 2 Users Say Thank You to treminaor For This Useful Post: | JohnBgon (03-05-2016), Pointmutation (03-23-2016) |
#13694 | |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Anything worth doing is worth doing twice...
#13695 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I test-fitted my new wheels and tires two weekends ago. Back on winters for the next few weeks, but then they go back on, along with coilovers/camber plates/LCAs. I'm excited!!!
| The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post: |
#13696 |
drained a tail light, and resealed using Gorilla Gaskets and 3M goop. drove 3 miles in dry weather with no condensation. working so far......
#13697 |
Turbo E85
Drives: 13 wrb brz
Flex Fuel Turbo BRZ
| The Following 2 Users Say Thank You to BRZtoni For This Useful Post: | Choco (03-09-2016), Mr.Impreza (03-06-2016) |
#13698 |
Drives: Subaru BRZ
#13699 |
Turbo E85
Drives: 13 wrb brz
im not rich enough. its just a basic fordable bike forgot the brand
Flex Fuel Turbo BRZ
| The Following User Says Thank You to BRZtoni For This Useful Post: | JD001 (03-06-2016) |
#13700 |
I'm bad at English
Drives: Subaru BRZ 2016 M/T
| The Following User Says Thank You to TMXSTAR For This Useful Post: | Stang70Fastback (03-06-2016) |
#13701 |
Drives: '13 BRZ Ltd WRB
HRE FF15. I'm guessing 18", would be interested to know the width/offset/tire. Looks great, like a more sophisticated version of the STi wheels that come with some models.
#13702 | |
A.K.A. Starlord
Some of my friends jokingly gave me a hard time saying, "Why would you spend all that money just for wheels that look the same as the ones that came with the car!" but once one of my friends saw them on the car in person, he agreed it was a significant upgrade in the looks department, lol. |
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | 2point0 (03-07-2016) |
#13703 |
Drives: '22 BRZ
Played with my data logging setup for this year, then washed and waxed.
| The Following User Says Thank You to DocWalt For This Useful Post: | nisti (03-07-2016) |
#13705 |
Turbo E85
Drives: 13 wrb brz
Flex Fuel Turbo BRZ
| The Following 2 Users Say Thank You to BRZtoni For This Useful Post: | ajaxthebetter (03-07-2016), iarefluffy (03-07-2016) |
#13706 |
A.K.A. Starlord
Sooo, since it's supposed to be warm for the rest of the month, I gave up and switched back to summer wheels/tires permanently today, lol. #toosoonjunior
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | ajaxthebetter (03-07-2016) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 09:53 AM |
