Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 12-14-2014, 01:40 AM   #10375
twag4
Drives: frs
Originally Posted by x1UP View Post
That should fix the wheel gap or would I need to mod the car further?
The wheel gap is best fixed by lowering. By going with an oversized tire, you will have inaccuracy in your speedometer. You will also enjoy the affects of higher gear ratios due to the increase in diameter of the wheel and tire. In a car some call "underpowered", this is probably a negative. To best illustrate what I am talking about, see this: http://www.frsproject.com/tire_size.php
twag4 is offline   Reply With Quote
Old 12-14-2014, 01:44 AM   #10376
twag4
Drives: frs
Also, both sizes are way too big for stock wheels.
Old 12-14-2014, 02:06 AM   #10377
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
What would be the best set up without doing any sort of modifications?
I'm trying to go for a wider look, all in all, I want the tire to stick out of the body more than stock (where it is inside the body).
Also, gave her a wash and detail today. So shiny.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 12-14-2014, 02:35 AM   #10378
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Some reference shots below of the 245/40/17, car is lowered 20mm. Same rolling diameter as stock, but the extra poke on the tires fills out under the fenders horizontally.
I'm on 8" wide wheels so it looks meaty but steering did soften up a bit. On a 7" width wheel it will probably be quite understeery and rolly polly? Best option would be buy some wheels that are wider or have lower offset. Or put spacers on.
This is the tyre calculator you can find in the wheels section of this forum, have a play and you'll get a visual of how different tyre and wheel combos work together.
blue cat is offline   Reply With Quote
The Following User Says Thank You to blue cat For This Useful Post:
qitorr (12-14-2014)
Old 12-14-2014, 04:03 AM   #10379
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
The quick & easy way to do this is just with spacers. Then you can save up for wider wheels to accomodate wider tires. For a 245 width tire, go with a 8-9" wide wheel.
On my 17x8s, I went from a 225 to a 245 and it definitely made the steering feel a bit sloppier. I'm about to get them re-mounted onto 17x9 wheels and am looking forward to crisper response.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
chanomatik (12-14-2014)
Old 12-14-2014, 07:12 AM   #10380
funwheeldrive
Originally Posted by mixxxx View Post
Canyon carving at Tuna Canyon Road.
Sometimes I wish WRB was available for the FRS.
The Following User Says Thank You to funwheeldrive For This Useful Post:
andrealynn.BRZ (12-14-2014)
Old 12-14-2014, 07:40 AM   #10381
Fastbrew
Drives: 2014 Pearl White BRZ
Originally Posted by JPxM0Dz View Post
Ordered these
That's a pretty clean look. Nice.
Fastbrew is offline   Reply With Quote
The Following User Says Thank You to Fastbrew For This Useful Post:
JPxM0Dz (12-14-2014)
Old 12-14-2014, 01:40 PM   #10382
twag4
Drives: frs
As others have said, spacers or bigger wheels for a more finished look. Also, I have heard of others going to 225/45r17, but again it will affect gearing and speedometer. Also will affect fuel economy somewhat due to heavier tires and altered gearing.
Old 12-14-2014, 03:12 PM   #10383
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Washed her up and put the winter stockers w/Blizzaks back on. Probably the last winter they will see. No Tread. I think I'm going to sell my summer wheels and get go to a full 9.5" wheel come spring!
Dat Gap!
The Following 2 Users Say Thank You to Kiske For This Useful Post:
chanomatik (12-15-2014), sprintertrueno86 (12-14-2014)
Old 12-14-2014, 03:48 PM   #10384
Porcupint
Drives: 13 GBS BRZ
Wrapped the center console silver pillars in alcantara. That wasn't too bad.
Need to replace the knee pads next.
Porcupint is offline   Reply With Quote
Old 12-14-2014, 03:54 PM   #10385
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
What did the gas attendant do to your BRZ today
sprintertrueno86 is offline   Reply With Quote
Old 12-14-2014, 05:08 PM   #10386
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
I hope you gave him/her shit
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 12-14-2014, 05:21 PM   #10387
Turbowned
Turbowned's Avatar
That sucks dude. Stupid Subaru nail polish paint.
The Following User Says Thank You to Turbowned For This Useful Post:
Choco (12-14-2014)
Old 12-14-2014, 07:00 PM   #10388
bababooey
Drives: BRZ SWP Limited -6MT
Added Cusco HT pedal and practiced a little on turning downshifts to second.
Also ran thru a tank of petrol. Filled with e85 for first time, reflashed and put about 10 easy miles. Then began hot doggin it running it thru a few gears. Don't know if the ecu is still learning after another 10 harder miles, but the change felt was more dramatic going stock to oft stage 1 on 93 pump than 93 pump to stage 2 el e85.
It's great to know if pump prices rise again, ethanol may be more cost effective. Upside is I filled up a 20 bill and some change.
Search this Thread:
Advanced Search
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 09:53 AM
