#1947 |
Drives: Argento Scion FR-S
Added a Hotchkis front brace and Rexspeed hood dampers last week. Took off the Hotchkis sticker because I'm going for a "stock+" look. Not so thrilled with the hood dampers - the brackets need to be at an angle or else the dampers touch the inside of the fender. Also, the sticky tape looks a bit tacky (no pun intended). Will probably go for Grimspeeds instead.
| The Following User Says Thank You to mike_ekim1024 For This Useful Post: | WRXGuy1 (05-08-2013) |
#1948 |
Installed front diffuser!
| The Following User Says Thank You to sklimo For This Useful Post: | RazBRZ (05-07-2013) |
#1949 | |
Drives: '13 BRZ Ltd WRB
Today I installed a set of wheels in the back of my BRZ...does that count? If it helps, they were just done getting powdercoated!
Which one is that? Doesn't look pointy enough to be the HTAutos one.
#1950 |
Got it from @JonMotoring on forum
| The Following User Says Thank You to sklimo For This Useful Post: | 2point0 (05-07-2013) |
#1951 |
@2point0 The fitting is damn near perfect for a $135 mod. You gotta drill and remove some hardware to access top of inside of bumper to attach with the included nuts and bolts. But nothing too crazy. May want to get extra washers as I needed! All in all very very happy with the way it looks.
#1952 | |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
| The Following User Says Thank You to Wonderbar For This Useful Post: | sklimo (05-07-2013) |
#1953 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Plasti-dipped my rear emblems.. Meh.. apparently I suck at all things that require patience..:/ ..looks like ass for the most part.. will retry and do it again I guess.. 5 coats and let it dry fully.. How do you get rid of the rough edges??? :/
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following User Says Thank You to Scooby South For This Useful Post: | RazBRZ (05-07-2013) |
#1955 |
Drives: GBS BRZ Limited
Put in those damn grommets found in the glove compartment. WTF Subaru. Had I not signed up here I would have had no idea.
#1956 |
#1957 |
http://www.ft86club.com/forums/showp...3&postcount=42
![]() Next time you're under your car just check for two oval seals just in front of the rear tires. The dealer is supposed to install them prior to delivery. Yours might already be installed.
| The Following User Says Thank You to spdfreak For This Useful Post: | sklimo (05-07-2013) |
#1958 | |
Drives: BRZ Limited
#1959 | |
#1960 |
Cones are bad
Drives: 2013 BRZ Premium
I did a lot.
| The Following 2 Users Say Thank You to RazBRZ For This Useful Post: | Scooby South (05-08-2013), sklimo (05-07-2013) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 09:53 AM |
