#19391 |
Road-hole
Drives: 2013 Whiteout FR-S
Wel...
Working on finishing up a twin supercharger build on my frs...
| The Following 6 Users Say Thank You to Jaden For This Useful Post: | BrahmaBull1990 (01-11-2022), dpfarr (12-29-2021), Dzmitry (01-04-2022), grumpysnapper (12-29-2021), NoHaveMSG (12-29-2021), Wally86 (01-05-2022) |
#19392 |
Drives: Crapcan
That's, uh..............interesting
#19393 |
Road-hole
| The Following 4 Users Say Thank You to Jaden For This Useful Post: |
#19394 |
Road-hole
So originally I was going to use an m90 I had gotten off of a buick. The problem is it's difficult to intercool and I don't particularly like the idea of water meth injection. I'm on ethanol so I could've gotten away with it, until I had to use 91.
I wanted positive displacement and I was looking at ways to use fmic for air charge cooling. Enter the amr500. Inexpensive, compact, can be mounted in any orientation and spin in any direction. Too small to be useful by itself, but two of them? It gives 1000cc per revolution which is the same as the sprintex 210; however, they also have a higher maximum continuous rpm than the sprintex. Two of these are pretty much perfectly sized for a stock block 86. You're looking at a Max of about 330 to 350 whp. With the pulley setup I'm using, it will have about 275 to start off. I'll probably raise it up once I get larger injectors. This morning I'm redoing the pulley setup to make them easily swappable. I'll be doing a detailed build thread also. Jaden P.s. one of the best things about it is the known ccs per rev, which is identical to the sprintex 210. You can look at the compiled spreadsheet from that blower to accurately estimate what this one will do. Last edited by Jaden; 12-30-2021 at 02:09 PM. |
| The Following 9 Users Say Thank You to Jaden For This Useful Post: | blsfrs (12-31-2021), BrahmaBull1990 (01-11-2022), CincyJohn (01-01-2022), Dzmitry (01-04-2022), grumpysnapper (01-03-2022), Jdmjunkie (12-30-2021), NoHaveMSG (12-30-2021), Stonehorsw (01-02-2022), Wally86 (01-05-2022) |
#19395 |
Howdy
Drives: 2020 BRZ PP
After two weeks, I couldn’t stand not driving her due to being out of town and the weather. The roads are reasonably plowed and sanded up here in the PNW. Drove to Costco for ramen only to remember they are closed today.
Anyways, HAPPY NEW YEAR! May your mods be plentiful and your bearings un-spun.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#19396 |
Cut away enough of the "dribble" lip so that a sandwich plate can now sit where it is supposed to.... lower, more compact and making way more sense.
(no need for a riser plate and its extra seal) |
| The Following 6 Users Say Thank You to grumpysnapper For This Useful Post: | BigTuna (01-03-2022), BrahmaBull1990 (01-03-2022), Jaden (01-04-2022), MrSkubi (01-10-2022), NoHaveMSG (01-03-2022), soundman98 (01-03-2022) |
#19397 |
Drives: 2013 Rally Blue BRZ
While I'm waiting for a buddy to get a night free to help me set the timing and put the timing cover back on, I took out the exhaust manifold studs, cleaned them up real nice and put them back in.
#19398 |
Just the tip
Drives: 2017 DGM BRZ
Played snowplow last week and the lip didn't survive a very snowy looking chunk of ice.
At least no bumper damage! |
#19399 |
| The Following 3 Users Say Thank You to Grady For This Useful Post: |
#19400 |
Just the tip
| The Following 3 Users Say Thank You to wolffbite For This Useful Post: |
#19401 |
The first time I went off the track did the same and tore up my STI lip. I purchased a knock off and put the STI badge on it. It did not fit as well as the STI version but was only $100 instead of $500.
| The Following User Says Thank You to Grady For This Useful Post: | FLYFISHR (01-08-2022) |
#19402 |
Drives: 2017 BRZ series.yellow
Switched to a Lithium battery for the weight savings.
Lost 31 lbs. off the front of the car. |
#19403 |
Good choice, that is my plan is to shift to these as batteries start to go out. I will stay with full size replacements though.
#19404 |
If the full size replacements come down in price, I'd consider it. But these small ones are much less and it still has a similar CCA as the factory battery.
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 09:53 AM |
