#19265 |
1st86 Driver!
I thought that too but thought maybe it was just the lighting.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#19266 |
Drives: Subaru BRZ
#19267 |
It looks like it’s in the same location as the Civic Type R which behaves in the way you just described. But I think air goes into the NACA duct to blow hot air out through the transmission tunnel area.
#19268 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Happy 8/6 Day
#19269 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Did a wash, including inside the trunk lid area and under the fuel lid. Also did a plast-x job on my headlights to get rid of the yellow. At 8.25 years and 182k miles and have hardly had any issues. I really hope my next car treats me this well.
| The Following 4 Users Say Thank You to B-R-Z For This Useful Post: |
#19270 | |
Weight Weenie
Drives: 15 FR-S
Looks great. Is that a wrap on the tailights? |
#19271 |
#19272 |
Weight Weenie
Drives: 15 FR-S
#19273 |
| The Following User Says Thank You to B-R-Z For This Useful Post: | new2subaru (08-06-2021) |
#19274 |
Drives: 2014 subaru brz
i have drop 20 degrees in engine temp and oil temp with this hood of course cant drive it in the rain took the inserts out under the vents
#19275 |
yes the guy did a bad match of the paint but to the non train eye its ok lol going in for a new paint job over the winter
#19276 |
Drives: Crapcan
Why not? I drive my car with ducted hood in the rain. Mine just having a center duct actually puts a crazy swirl pattern of the rain on the windshield. It is usually parked outside too.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | norcalpb (08-09-2021) |
#19277 |
Drives: 2013 BRZ Sport-Tech
Finally completed part 1 of my brake change. Started Last Thursday!
Nothing fancy, just normal brakes for a 2013. Bought the parts Wednesday, started on Thursday after work by pulling the rears... Well attempting to; they were stuck. Turns out I was sold the wrong rear rotors anyway (non-vented). Put everything back on, looked up the threads for the 2 bolt holes to push the rotors off. Went to the store to exchange the rear rotors and bought the required bolts. Well, the right rears weren't in stock so they had to order them for me to pick up yesterday. Went home and proceeded to pull apart the fronts (this is still Thursday). Fronts were also stuck on but now I had the bolts. Got the left front off, pulled out the new rotor, "hey, these don't quite look the same size." Sure enough, the new ones were ~3/8" smaller in diameter (see attached photo with inside pad and rotor. No you shouldn't be able to see the pad at all). Re-assemble old brakes. Pack up tools. No time to get back to the store before they close. Messed up plans for the weekend. Fast forward to yesterday. Get home from work, go return front rotors and pick up new for all 4 corners (store wouldn't do anything to compensate me on what an ordeal they had added to this job, "rotors were already on sale"). Start with fronts again. Rotors are stuck again/still but deal with it using the bolts. Everything is going ok but then I can't get the caliper over the lower pin on the drivers side. Push as hard as I can on the pin and nothing. Pull it out, wipe off the grease and re-insert to see if there's just an air pocket trapped by excess grease. Still no luck. Feels like it's bottoming out. try putting a C clamp on it, tapping with a hammer, no luck. Remove it to find lots of grease on the tip this time. Wipe off and reinsert. Seems to be going a bit farther but not enough. Press with fingers and remove, barely any grease on tip. Tap with hammer and remove; big glob. Repeat tapping of hammer and wiping of grease until pin sits well within the area it needs to. Remove 1 last time to re-grease the sides. I'm now working by flashlight but I finally manage to get everything re-assembled. Now I have to find time to do the rears... ![]() Then I get to do my girlfriends car.
| The Following User Says Thank You to CrowsFeast For This Useful Post: | Wally86 (08-10-2021) |
#19278 | |
Drives: 18 Brz (Sold) / 22 BRZ
Brake work
Also, an anti-seize between hub and rotor may help next time you havr to change. |
| The Following User Says Thank You to Stonehorsw For This Useful Post: | Wally86 (08-10-2021) |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 09:53 AM |
