Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 06-22-2021, 01:13 PM   #19181
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Stonehorsw View Post
Any issues running E85 on the track? Did you notice fuel starvation? (E85 + 660s tires)
I have been running the Verus fuel flap. No issues on this track, the one I am running on 7/17 will be the real test as it has a long sustained left hander.
My car is also splitter, diffuser, and medium wing.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Stonehorsw (06-22-2021)
Old 06-22-2021, 02:09 PM   #19182
Grady
Grady's Avatar
I have the flapper and at Cressen through Horseshoe, Boot Hill, Tombstone(all one big left around 270 deg) it will starve coming out if below 3/4 tank.
The Following 2 Users Say Thank You to Grady For This Useful Post:
NoHaveMSG (06-22-2021), Stonehorsw (06-22-2021)
Old 06-22-2021, 03:13 PM   #19183
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Originally Posted by CincyJohn View Post
Originally Posted by N_Raged View Post
Washed my engine bay.
What did you do exactly?
-Disconnect battery.
-Dry-clean: Use a shop-vac on reverse (or a blower attachment from an air compressor) to blow away loose dust from entire engine bay.
-Protect: Cover alternator and engine block with garbage bag.
-Degrease: Spray degreaser on surfaces in the engine bay and on the underside of the hood that I want cleaned - avoiding any electrical wiring. Agitate the degreaser with a soft brush to loosen the grease/dirt.
-Rinse: Use a garden hose on the MIST setting to gently rinse away the degreaser. Don't use a high pressure stream or a pressure washer.
-Dry: Using the shop-vac on reverse again, blow away the a water from the areas you rinsed.
-Detail: Remove the plastic bag. Now with a rag and degreaser, use some elbow grease to gently clean any area that was covered by the plastic bag and anything you may have missed.
-Dress up: Using your favourite plastic/rubber protector spray and a clean rag, apply some to any dull plastic cover and rubber hoses to restore their shine. Not really required for newer cars, but might be a good idea for cars that have seen a lot of mileage.
-Reconnect battery.
-Admire your OCD.
N_Raged is offline   Reply With Quote
The Following 7 Users Say Thank You to N_Raged For This Useful Post:
BAM_Nyblodx16 (06-23-2021), CincyJohn (06-30-2021), juenedgi (06-23-2021), KMA KiCKz (06-23-2021), Stonehorsw (06-22-2021), The Red One (06-24-2021), Wally86 (06-22-2021)
Old 06-22-2021, 04:39 PM   #19184
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am thinking I will be okay, the big constant radius turn I take a shallow entry and double apex it. I guess I will find out for sure on the 17th. I would like to have that sorted before the SCCA TT even at that track at the end of July.
Old 06-22-2021, 07:12 PM   #19185
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
-Dress up: Using our favourite plastic/rubber protector spray and a clean rag, apply some to any dull plastic cover and rubber hoses to restore their shine. Not really required for newer cars, but might be a good idea for cars that have seen a lot of mileage.
-Reconnect battery.
-Admire your OCD.
I've purchased the product for cleaning and dressing. Just waiting on a weekend to get into it. Yours looks great!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is online now   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
N_Raged (06-22-2021)
Old 06-22-2021, 07:59 PM   #19186
gen3v8
Barred
gen3v8's Avatar
Drives: My18 wrxsti My19 brzts
Also forgot to mention was my first time running E85 on track. Holy hell what a difference. I am actually quite happy with the power the car makes now. Downside is I noticed I need to upgrade my radiator. I was hitting close to 240F and having to cool the car down or just pull off the rest of the session. I started noticing last couple years I could hit 230F on water temps and though it was an issue with my cooling stack. Nope, still not better. Koyo Rad on the way.
I`ll be trying our 98 this w/e It runs great on e85 but fuel starves on 1 long left. Hopefully it won`t starve on 98?
Wait until my Flex capacitor hits 88
gen3v8 is offline   Reply With Quote
Old 06-23-2021, 01:54 AM   #19187
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I assume you mean 98 petrol? Should be less likely then with e85.
gen3v8 (06-23-2021)
Old 06-23-2021, 02:37 AM   #19188
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
EU ratings are 95/98, which are equivalent to US ratings of 91/93. So, EU 95 octane = US 91 octane and EU 98 octane = US 93 octane. Top performance with EU 98 octane = 93 US octane
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
NoHaveMSG (06-23-2021)
Old 06-23-2021, 02:45 AM   #19189
pope
has a funny hat
Drives: 2014 BRZ Limited
did IDK three fifths of my brake replacement and fluid flush project…
pope is offline   Reply With Quote
The Following 5 Users Say Thank You to pope For This Useful Post:
BrahmaBull1990 (06-23-2021), in_sherman (07-05-2021), Stonehorsw (06-23-2021), therealstoly (06-23-2021), Wally86 (06-23-2021)
Old 06-23-2021, 03:53 PM   #19190
JD001
JD001's Avatar
Drives: Subaru BRZ
What's with the pink sharkfin?
The Following User Says Thank You to JD001 For This Useful Post:
soundman98 (06-23-2021)
Old 06-23-2021, 05:39 PM   #19191
pope
has a funny hat
long backstory, but essentially comes down to trolling my wife.
The Following 4 Users Say Thank You to pope For This Useful Post:
CrowsFeast (06-25-2021), JD001 (06-24-2021), soundman98 (06-23-2021), Ultramaroon (07-01-2021)
Old 06-24-2021, 10:42 PM   #19192
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
oil change night.
thomasmryan is offline   Reply With Quote
The Following 4 Users Say Thank You to thomasmryan For This Useful Post:
BrahmaBull1990 (06-26-2021), DarkSunrise (07-01-2021), JD001 (06-25-2021), Wally86 (06-25-2021)
Old 06-25-2021, 11:44 PM   #19193
gen3v8
Barred
gen3v8's Avatar
Fitted some MCA pro sport coil overs today. Was going to the track tomorrow but covid has locked us down to the city of Sydney. Lucky to get to the workshop because by the days end I`ll bet we`ll be locked down to the council area which is the biggest in the Eastern suburbs.
The Following 4 Users Say Thank You to gen3v8 For This Useful Post:
BrahmaBull1990 (06-26-2021), NoHaveMSG (06-28-2021), Stonehorsw (06-28-2021), Wally86 (06-28-2021)
Old 06-29-2021, 12:43 PM   #19194
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Installed my rear tow hook. Tomorrow I’ve got rubber liners for the cup holders and center console, cabin neon lights for show, and my front license plate tow hook adaption (won’t install yet due to waiting on my actual plates to arrive).
Sur is offline   Reply With Quote
The Following 2 Users Say Thank You to Sur For This Useful Post:
BrahmaBull1990 (06-30-2021), Wally86 (07-01-2021)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 09:53 AM
