Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 03-11-2018, 08:03 PM   #16647
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by carsebuco View Post
How mudh did it "actually" cost, huh?
If I could have "paid off" the Kiosk where I did the test just to get a don't ask, don't tell PASS...I would have...as it turns out, didn't even need to!
BirdTRD is offline   Reply With Quote
Old 03-11-2018, 08:08 PM   #16648
Side
Side's Avatar
Drives: 2018 BRZ tS
Originally Posted by Viper224 View Post
JDM side markers
Maybe I'll have to do that to mine again after all. Did you get the Helix replicas or did you order JDM from Japan?
Side is offline   Reply With Quote
The Following User Says Thank You to Side For This Useful Post:
Viper224 (03-11-2018)
Old 03-11-2018, 08:20 PM   #16649
Viper224
Viper224's Avatar
Drives: 2018 BRZ tS
I do like them more than the US ones. They're the real JDM and I ordered them from FT86SpeedFactory. Took a little more time to install than I thought, because I had to mess with the top clips a little so that they would click back in.
Viper224 is offline   Reply With Quote
The Following 2 Users Say Thank You to Viper224 For This Useful Post:
Side (03-11-2018), SkyeHack (03-12-2018)
Old 03-11-2018, 09:45 PM   #16650
uppitypanda
Drives: '17 BRZ PP
Sunset cruise to the Everglades to break in the new springs. Love it
uppitypanda is offline   Reply With Quote
The Following 11 Users Say Thank You to uppitypanda For This Useful Post:
carsebuco (03-11-2018), derekbrz24 (03-13-2018), dhuang (03-14-2018), Ganthrithor (03-13-2018), MJones_RB (03-12-2018), new2subaru (03-13-2018), SkyeHack (03-12-2018), spike021 (03-11-2018), trippinbillies40 (03-12-2018), weederr33 (03-13-2018), yberther (03-13-2018)
Old 03-11-2018, 09:46 PM   #16651
Brink
Drives: 2017 BRZ
I got the same, they definitely look better than stock (got the amber bulbs with them to keep them the right color). Another one of those little things that should have just been that way from the factory.
Brink is offline   Reply With Quote
Old 03-12-2018, 09:41 AM   #16652
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
I got the Piston 86 Fender emblems from a friend's FR-S
update: Also got new 4.5" extended exhaust tips on my 2017. The OEM bolt on tips were too boring and tucked in for my taste.
xenarc is offline   Reply With Quote
The Following User Says Thank You to xenarc For This Useful Post:
Old 03-12-2018, 11:06 PM   #16653
e30kawi
Drives: CWP limited
They look great! Do you have a shot showing more of the car from the side?
e30kawi is offline   Reply With Quote
Old 03-13-2018, 11:04 PM   #16654
cjd
cjd's Avatar
Drives: 2017 BRZ
Today I worked a little on the alignment. It's too cold for any more at 26°F. And I'll have to revisit it later, since something is funky in the front. Got the front to -3.4°/-3.5° camber and 0.01° toe in... have yet to look at the back beyond noting it needs work. Not surprising since I did coilovers, lca's, and toe arms... Front is bugging me with the camber plates in very different spots (nearly maxed out on the -3.4° side, maxed would probably sneak to -3.5°... yet the other side has almost 2° more range, give or take. This will be good enough for a bit of driving around, and I'll put the car up and go over everything again after the exhaust is all in - I'll need to re-balance it anyway.
whee? no. not even close. Why did I decide I wanted to do my own alignments?
Old 03-14-2018, 06:55 AM   #16655
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
If one is maxed out and the other is not even close, I would start by checking the alignment at the bottom of the struts. Get that set equally first, otherwise the car will behave slightly differently when cornering. As for toe... Give it a skosch of toe out instead of keeping it in up front. You'll thank me at your next autocross the first time you turn in for a corner.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
cjd (03-14-2018)
Old 03-14-2018, 09:57 AM   #16656
cjd
cjd's Avatar
Drives: 2017 BRZ
That's the plan on toe for the second round after I get all the parts on the car, and let the suspension settle, if its going to do that. This was close enough, I'm too cold to fiddle any more. I do need to recheck the knuckle, make sure it didn't slip.
I think I may need to see about zeroing the steering angle too, or something. Small tweaks of the wheel can still feel centered to me but push toe angles to one side or the other... And there's a discussion in the SSC thread that got me thinking about this.
So much left to do and the season starts in a month!
The Following User Says Thank You to cjd For This Useful Post:
Tcoat (03-14-2018)
Old 03-14-2018, 11:11 AM   #16657
austinbrz
austinbrz's Avatar
Drives: 2015 BRZ Limited (Crystal Black)
New diffuser painted and installed.
austinbrz is offline   Reply With Quote
The Following User Says Thank You to austinbrz For This Useful Post:
trippinbillies40 (03-14-2018)
Old 03-14-2018, 11:46 AM   #16658
xenarc
xenarc's Avatar
PRETTY SICK Austinbrz
austinbrz (03-15-2018)
Old 03-14-2018, 03:55 PM   #16659
re-animator
are those STI center caps on enkei Raijins? if so where did they come from? i've got the same wheels.
re-animator is offline   Reply With Quote
Old 03-14-2018, 11:02 PM   #16660
cjd
cjd's Avatar
Drives: 2017 BRZ
Went ahead and double checked the one corner... not surprisingly, it was messed up at the knuckle. Nice and even both sides now at the camber plates. That was all the energy I had this evening, even though it's MUCH warmer outside. I'll go ahead and string it again and tweak the front toe a touch, then get the back aligned - hope to get the car out for a drive this weekend - need to wrap up the tank of gas I got from the dealer so I know what's in it when we tune it.
Header, tune, exhaust is next up.
Why does this stuff always take ten times as long as you want it to?
Search this Thread:
Advanced Search
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 09:53 AM
