Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 04-28-2016, 08:55 PM   #14155
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
Originally Posted by BirdTRD View Post
I didn't know you could get just that piece of the garnish. How much did it run you? If I decide to make it "permanent", I might just have to go that route.
Yea, I wanted to change them black before the Hyper.Blue was announced and I was happy to see I could purchase the OEM fins in black. Same here, but I saw a DIY on here that enlightened me that the chrome fins are held on by double-sided tape. They are $80 for the pair (link below), which was a little pricey but they look really clean and were easy to install once I got the other chrome fins off.
http://subaruonlineparts.com/subaru-...ck-p-4113.html
Ethereal05 is offline   Reply With Quote
The Following User Says Thank You to Ethereal05 For This Useful Post:
BirdTRD (04-28-2016)
Old 04-29-2016, 01:27 PM   #14156
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Finally installed hubcentric rings & swag came in
Old 04-29-2016, 02:05 PM   #14157
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Porcupint View Post
The A clips on both of mine finally snapped at the metal yesterday when trying to put them back in.... Not sure if I'm going to clear markers or just zip tie them.
I just put tiny strips of 3m double-sided tape on the top of the side marker. it's working well so far but i'm not sure how easily they'll come out
Old 04-29-2016, 05:23 PM   #14158
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Opened a box full of sexy!
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
SmartedPanda (04-29-2016)
Old 04-29-2016, 05:36 PM   #14159
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Might steal this, mine gets loose every 2-3 weeks. Damn it Helix.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 04-30-2016, 12:53 AM   #14160
Porcupint
Drives: 13 GBS BRZ
I went the zip tie route. Pull the metal A clip out. Drill a small hole through where spot where the clip was. Put the marker on the car. Push a small zip tie through the hole where you press the clip down and through the hole you drilled in the marker and the zip tie should come back around to you. Zip it down and you're good to go.
Honestly it works quite well and much easier than dealing with those damn clips.
Porcupint is offline   Reply With Quote
Old 04-30-2016, 06:54 PM   #14161
jasonojordan
Drives: 2013 satin white brz limited
Started out the day with win! Then went winless . Then ended the day with win!!!!
(inside joke. On a local car forum a kid asked how to make his car winless. It was a typo and we ran with it)
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
MJones_RB (05-02-2016)
Old 04-30-2016, 07:12 PM   #14162
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Got the light smoke Valenti Revo's installed yesterday. Lovin' the new look of the ass end. Waiting for a few more "accessories" to come in on Monday that should help change it up just a bit more.
nisti (04-30-2016)
Old 04-30-2016, 08:22 PM   #14163
SmartedPanda
Did you follow this guide?
http://www.ft86club.com/forums/showt...18587:thumbup:
Old 05-01-2016, 12:37 AM   #14164
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
ajaxthebetter (05-01-2016)
Old 05-01-2016, 12:58 AM   #14165
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
Put in a factory order for a manual WRB Limited. 😀
Sent from my Nexus 9 using Tapatalk
trigun286 is offline   Reply With Quote
The Following 3 Users Say Thank You to trigun286 For This Useful Post:
ajaxthebetter (05-01-2016), Shedd22 (05-02-2016), VMRamos (05-01-2016)
Old 05-01-2016, 03:59 AM   #14166
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Officially got her diagnosed... RIP. Cylinder 3 direct injection seal failed, causing lean causing, making boost = bad time. Scouring for a replacement block. Sadly I was hoping to save up to build my stock block, I don't think I can financially swing buing a new engine and sending it to full blown to be built. Will just have to settle for getting it runing again.
Figures... I was just getting geared up to start my custom rear difuser project to match my front end.
Old 05-01-2016, 02:17 PM   #14167
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Today i turned into an FR-S
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
BoxRZ_86 (05-01-2016)
Old 05-01-2016, 03:30 PM   #14168
DSOmegaX
DSOmegaX's Avatar
Put her in the shop for a few days for a complete rear subframe change out
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 09:53 AM
