#15 |
Drives: 2JZ FRS
My guess is the pump install. It can come unseated enough to bleed off volume and go lean under load when demand is high. Seen it happen a million times. O rings, spacers, etc. it's kind of a crappy install procedure with most pumps and trial and error until you find a combo that works well
#16 |
Drives: 85 corolla gts
"O" rings between the pump outlet and the housing. Get new ones that are e85 compatible.
#17 | ||
Drives: 2013 BRZ black
| IP Coil Packs | bozack | Engine, Exhaust, Transmission | 6 | 03-06-2022 02:36 PM |
| Vendors/Members, Anyone have coil packs in stock? | ZionsWrath | Engine, Exhaust, Transmission | 3 | 05-12-2015 03:04 PM |
| Cosworth Power Packs pricing | Simon99 | Engine, Exhaust, Transmission | 175 | 11-05-2014 11:36 PM |
| 3M tape failing on front lip after time? | 1Cor10:23 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 11-19-2013 02:51 AM |
