thatchmaster
Old 01-26-2017, 06:10 AM   #407
Sundae
meatbun
Sundae's Avatar
Drives: 2016 Scion FR-S RS 2.0 (812)
Smile
Hey all, haven't visited in a while but I've made some changes lately... specifically, bought a set of TRD louvers that I wanted to share here before anywhere else.
I took a chance on these because you WILL NOT find any images online with these louvers on a 2.0 (until now, I guess). In fact, I defy you to find any. Anyway, I think it turned out handsomely. I couldn't have hoped for better; it compliments the 'black out' aesthetic I've been aiming for so perfectly.
Few pics from different angles here:
http://imgur.com/a/JvQfE
The other customizations you see on my derrière are the smoked Valentis, black matte Toyota badges and TRD exhaust.
Sundae is offline   Reply With Quote
The Following 14 Users Say Thank You to Sundae For This Useful Post:
Chaetagnath (01-27-2017), funwheeldrive (01-26-2017), gypsy_seven (01-30-2017), HKz (02-20-2017), kakacarrotcake (02-11-2017), KalbiCool88 (02-11-2017), mmmcambelsoup (01-31-2017), novice (01-30-2017), Reign (01-27-2017), SC10N (02-11-2017), SK86 (01-27-2017), Tcoat (01-26-2017), thatchmaster (01-26-2017), Vic4uf (02-01-2017)
Old 01-30-2017, 10:37 AM   #408
novice
novice's Avatar
Drives: Fr-S 2.0 Release
Thanks for the post. looks great!
novice is offline   Reply With Quote
Old 01-30-2017, 11:23 PM   #409
leeloo_17
omg that looks beautiful
leeloo_17 is offline   Reply With Quote
Old 02-01-2017, 09:55 PM   #410
WNCFRS
Drives: 2016 FRS RS 2.0 auto #921
Originally Posted by WNCFRS View Post
Not sure if this is the best place to post this question but figured RS2 owners would see it.
I've had my RS2 for about six months and look forward to driving it every chance I get. Can't say I've felt that way about a car since my 67 Stingray twin top. One relatively minor issue I've noticed is that the temperature setting seems to be wildly inaccurate. In the summer I would have to set it around 62 or less for reasonably cool air and recently when some warming is required I have to keep it in the same area to not get roasted. I admit this is merely my mental comparison to settings in our 2014 Prius or 07 Rav4, both of which have digital climate control. It seems like my required setting in the FRS is around six or seven degrees lower for about the same temp.
My next step is to keep a digital thermometer in the car to get some hard numbers but just thought I'd ask if any other RS2 owners are experiencing the same issue. My thought is perhaps a faulty temp sensor somewhere.
Yesterday I took the time to check the climate control with a digital thermometer. On a fifty mile drive I set it at 62 and the cab temp stayed a consistent 72, a ten degree differential. I also checked it on our 2014 Prius and it stayed within one degree. In two weeks I'm taking the FRS in for it's first complimentary oil change at 7.5 months (I changed it myself around 1k miles). I emailed the service rep my test results and told him I would like it repaired during my visit. I'll post the results.
WNCFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to WNCFRS For This Useful Post:
thatchmaster (02-01-2017), Vic4uf (02-01-2017)
Old 02-05-2017, 10:24 PM   #411
Vic4uf
Drives: FRS, Camry
Has anyone else noticed the double sided tape holding the rear lip on the trunk is coming undone? Especially during hot FL days, the adhesive holding the rear lip looks like it's giving way. I considered taking it into the dealership.
Vic4uf is offline   Reply With Quote
Old 02-06-2017, 01:12 PM   #412
sirsol66
Drives: 2013 FRS- Hot Lava
Same. My car was shipped brand new from Texas but the lip is pealing. I'm replacing it with a TRD spoiler anyways.
sirsol66 is offline   Reply With Quote
The Following User Says Thank You to sirsol66 For This Useful Post:
Vic4uf (02-06-2017)
Old 02-06-2017, 01:19 PM   #413
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Yes, just on the sides. It almost looks like they used a standard double side tape layout that the regular spoiler gets which does not touch the sides and then stuck a little piece in for our RS2.0 spoilers....I was able to carefully remove the existing double side tape and maneuver some new tape into place after loosening the spoiler mount nuts in the inside of the trunk, re-tightened after new tape was installed. This was the lazy fix, at some point I'll remove the spoiler and redo all of the double side tape or more likely, install the TRD spoiler
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
The Following User Says Thank You to wrh3 For This Useful Post:
Vic4uf (02-06-2017)
Old 02-07-2017, 11:45 PM   #414
AbductedCasper
AbductedCasper's Avatar
Drives: FR-S Release Series 2.0 #349
Yeah mine is peeling off. I told the dealership they said that they'll cover it and replace it with a brand new one.
AbductedCasper is offline   Reply With Quote
Old 02-08-2017, 12:58 PM   #415
michaelchatten
Drives: 2016 FR-S RS 2.0
Yeah I took mine in and they fixed it.
michaelchatten is offline   Reply With Quote
The Following User Says Thank You to michaelchatten For This Useful Post:
funwheeldrive (02-08-2017)
Old 02-09-2017, 03:31 PM   #416
Netsunesa
Drives: 13 Evo X, Scion Frs RS 2.0 #45
#45 NOVA
I own number 45 / 1000
Netsunesa is offline   Reply With Quote
The Following 2 Users Say Thank You to Netsunesa For This Useful Post:
Tcoat (02-09-2017), thatchmaster (02-09-2017)
Old 02-10-2017, 10:26 PM   #417
illestBreezy
illestBreezy's Avatar
Drives: FRS, GR Supra, S15 Silvia
Hey guys, here is how my car currently sits. More big things coming!!
Instagram: @bryanevander
illestBreezy is offline   Reply With Quote
The Following 4 Users Say Thank You to illestBreezy For This Useful Post:
KalbiCool88 (02-11-2017), Lonewolf (02-14-2017), SC10N (02-11-2017), wrh3 (03-15-2017)
Old 02-14-2017, 06:28 PM   #418
WNCFRS
Took the FRS to the dealer today and they confirmed that the climate control was about ten degrees off in calibration. They had never run into this problem before so they consulted with a toyota tech line that they have access to. All they had to do was use their scan tool and modify a setting. It still isn't perfect but on the way home it was about four degrees off. At my next free oil change I may have them tweak it a little more.
The Following User Says Thank You to WNCFRS For This Useful Post:
funwheeldrive (02-14-2017)
Old 02-18-2017, 10:07 PM   #419
GreenRanger86
GreenRanger86's Avatar
Drives: Halo 2016 FRS
Anyone planning to get trade their front TRD 2.0 lip for a used Authentic JDM TRD lip?
Sent from my SM-T713 using Tapatalk
GreenRanger86 is offline   Reply With Quote
Old 02-20-2017, 01:55 PM   #420
sirsol66
What's the condition on the lip? If you're willing to cover the shipping charge I have a basically new (car has 143 miles on it) 2.0 lip.
FR-S 10 Series Registry torqdork Scion FR-S / Toyota 86 GT86 General Forum 2508 07-16-2023 03:41 PM
FT86Club's BRZ Series.HyperBlue Owners Registry Veloist BRZ First-Gen (2012+) -- General Topics 960 08-14-2022 10:57 PM
FR-S Monogram Series Registry Chad86 Scion FR-S / Toyota 86 GT86 General Forum 79 09-10-2021 11:14 PM
FR-S Release Series 1.0 Registry brianFKNmyers Scion FR-S / Toyota 86 GT86 General Forum 800 10-26-2020 10:18 PM
'Unofficial' US BRZ Series.Blue Registry Jimmy45brz BRZ First-Gen (2012+) -- General Topics 110 08-15-2017 08:37 PM
