#71 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
Maybe a small slide on spacer would do the trick
#72 | |
Drives: 2022 GR86
#73 |
Drives: 2022 GR86
Ordered as set of Hypergrams in 17x9 et40 5x100 with Bridgestone RE71R in 245/40 for autox next year.
Took some pictures on my Performance Package Brembos for other folks to have a better idea how these look. As you can see, there's plenty of clearance even if you turn the bleeder cap the wrong way ![]() ![]() ![]() ![]() ![]()
#74 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | SuperTom (02-12-2022) |
#75 |
Drives: 2022 GR86
| The Following User Says Thank You to timurrrr For This Useful Post: | jflogerzi (12-22-2020) |
#76 |
Drives: 2019 BRZ w/ PP
Man that looks good...
| The Following User Says Thank You to NaturallyAspirated For This Useful Post: | timurrrr (12-23-2020) |
#77 |
Second. Super clean
| The Following User Says Thank You to jflogerzi For This Useful Post: | timurrrr (12-23-2020) |
#78 | |
Drives: FR-S Whiteout
a lot of yes.
Intent > Content
cowardice is the mother of cruelty. |
#79 |
Drives: 2017 BRZ PP (White)
#80 |
Not my car, but I did have aluminum hubcentric ring in my aftermarket wheels.
Intent > Content
#81 |
I will have some 17x8 hypergrams up for sale soon if your in the SoCal area
#82 |
Dr. Fünke, Analrapist
Drives: 2013 BRZ Limited, 2004 WRX STI
Recently purchased some 17x9 +40 Hypergrams in gunmetal for my BRZ. Had them wrapped in Yokohama Advan A052 235/40/17s. I'm running stock dampers lowered 1" on Eibach springs. Heads up I needed 3mm spacers to clear the spring perch. Also with the meatier tires, on track I consistently knocked out my side markers.
![]() ![]() ![]() ![]() Hat tip to @ATL BRZ for the tip on the 3mm spacers, I would've been a sad panda without them Also as noted by @jflogerzi, the 17x9s easily clear BBKs. I'm running the Stoptech C43 kit on mine and have plenty of clearance.
Last edited by weepel; 09-13-2021 at 11:54 AM. Reason: Photos were initially added as URLs, not embedded |
| The Following 2 Users Say Thank You to weepel For This Useful Post: | ATL BRZ (09-21-2021), SockMonkey (09-14-2021) |
#83 | |
Drives: '13 BRZ Limited
#84 | |
I do plan on upgrading eventually to a decent set of coilovers as after ~7 years of tracking the car, the stock dampers have taken a beating and it would be nice to get more camber and to not have to run the 3mm spacers for these wheels.
| Konig Rims- what do you think? | KatrinaR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-25-2015 02:35 PM |
| Konig Torch 18x8.0 +35 | khan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-21-2014 01:27 AM |
| WTB- Konig Daylites | solort | Want-To-Buy Requests | 0 | 01-08-2014 12:07 AM |
| Konig Wheels | pghfan19 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 04-25-2013 01:24 AM |
| Konig deception | oaroyale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-02-2013 10:02 PM |
