Old 05-05-2016, 11:22 AM   #10403
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Have to do LCAs for the rear. Or just leave it and you will get used to it. I don't even notice mine anymore and as long as I am getting perfectly even wear on the tires I am fine with it.
Originally Posted by cjd View Post
Rear you want the LCA - there is no bolt, and the whiteline bushing makes your shop hate you.
Add more to the front, enjoy the visual balance once again and benefit from improved handling
I tried the "leave it and forget" but it's not working
I'm just not a fan of camber at all. Id rather sacrifice that extra bit of handling to have the car look how I want since I'm not doing autox/track driving.
It was nice to see the quick consensus for LCAs though and I did read about the whiteline being terrible to adjust
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline
The Following User Says Thank You to Tectoniic For This Useful Post:
Tcoat (05-05-2016)
Old 05-05-2016, 11:24 AM   #10404
Ashikabi
Ashikabi's Avatar
Originally Posted by babydriver View Post
Ashikabi,
What's in Austin this weekend? Are you here for the Auto Show?
DreamHack videogame tournament. My brother is competing. What kind of auto show?
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
p1l0t (05-05-2016)
Old 05-05-2016, 11:56 AM   #10405
The only time I notice now is when somebody says "are your wheels angled?" Then I have to explain that the angle looks like more then it is, they are in spec, no I don't wear out tires faster, the front aren't angled as much because it isn't lowered as much, no my alignment is not wrong, it is lowered purely because I like the look better, almost 2 inches, they are not special tires, they do not rub on anything, nothing is broken ..... Ahhhh shit, in hindsight it may actually be easier to just put LCAs on instead of answering all the questions/comments all the time.
Tcoat is offline
Dadhawk (05-05-2016), MisterSheep (05-05-2016), soulreapersteve (05-05-2016), Tectoniic (05-05-2016)
Old 05-05-2016, 11:58 AM   #10406
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
All I did was get front camber bolts to even out the camber front and rear.. -2.5 all around
Instagram: trevor.parque
MisterSheep is offline
Old 05-05-2016, 12:02 PM   #10407
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Quick, lowest displacement with the most cylinders. Mass produced engines only.
Nevermore is offline
Old 05-05-2016, 12:05 PM   #10408
MisterSheep
Killed Scion
uhhhh I know lotus came out with a 3L v8...
Old 05-05-2016, 12:13 PM   #10409
humfrz
A couple of drinks??
Just 1 + a special drug will get things done.
*Disclaimer*: Following my advice will net you jail time with Bubba.
Back-in-the-day ........ back on the farm ....... on a hot, Saturday afternoon, one could mix up a concotion of ground up lemon peels, mixed with finely crushed ice, packed in a large Mason jar, filled to the brim with vodka (or shine) and then give one of those to an unsuspecting young lady and tell her it's lemonade.
There was a good chance for a roll in the hay after a couple of those ......
humfrz
humfrz is offline
Old 05-05-2016, 12:27 PM   #10410
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Close, 3.5L, still a good size, definitely small enough. But not common enough.
The Following User Says Thank You to Nevermore For This Useful Post:
Old 05-05-2016, 12:33 PM   #10411
MisterSheep
Killed Scion
Ferrari came out with a 2L v8 and the Suzuki C2 concept car had a 1.6L twin turbo v8.
3.4L v8 out of a Ford Taurus.. Smaller maybe more common.
BMW's 3L v8 out of a E34 530i
Old 05-05-2016, 12:53 PM   #10412
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Ferrari actually has a 2.0L flat 12 that was used in a hill climb car only, and that's the only one that exists. I want that engine.
The ford would probably be easiest to get, but the BMW is probably nicer.
Old 05-05-2016, 12:54 PM   #10413
MisterSheep
Killed Scion
The bmw one is probably nicer and might be easier to get.
Old 05-05-2016, 02:06 PM   #10414
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
http://www.ebay.com/itm/BMW-E34-530i...RWV9t7&vxp=mtr
Old 05-05-2016, 02:18 PM   #10415
MisterSheep
Killed Scion
215hp/214tq
https://en.wikipedia.org/wiki/BMW_M60
Old 05-05-2016, 02:22 PM   #10416
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Yeah, I saw that. Think it would fit in the FR-S? Haha
In all seriousness if I went this route it would probably no longer be for an RX-7. If I was going to buy a BMW motor, I might as well stuff it into a BMW, which would definitely be a long way down the line because I know it wouldn't be cheap at all. The current choice car would be a 2002, which would probably move nicely under that kind of power. I'd want a shop to clean it up as best as possible, to coax at least a little reliability out of it. I'd explore ITBs/superchargers if I decided the little thing needed more power, but really 215 is plenty, and I love that it's a 3L V8.
Search this Thread:
Advanced Search
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
