86WORX
Old 06-22-2021, 09:51 AM   #78849
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Tried to do a little good ole italian tune up on the car. Hit 100 MPH before I started smelling something like burning rubber. Wasn't clutch. Or oil. It smelled like rubber. Any thoughts?
Tires are made of rubber! So are condoms though
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
bcj (06-22-2021), spcmafia (06-22-2021), Ultramaroon (06-22-2021)
Old 06-22-2021, 10:37 AM   #78850
I've smelled it before, but never at such low speeds. I remember its been mentioned before but can't remember where.
Fender liner melting with some headers or turbos has been mentioned before. I don't remember what you have done to your car.
Tcoat is offline
Old 06-22-2021, 11:59 AM   #78851
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I have ceramic coated headers. Maybe the overpipe gets hot. Another thing it could be the accessory belt touching the inlet tube. The smell goes away quick after WOT.
spcmafia is offline
Old 06-22-2021, 11:59 AM   #78852
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Could have been debris or a timing cover leak on to the header.
NoHaveMSG is offline
Old 06-22-2021, 12:00 PM   #78853
Well the belt touching the tube should be a real easy visual.
Tcoat is offline
Old 06-22-2021, 12:02 PM   #78854
spcmafia
spcmafia's Avatar
Man, I was just reading the seal replacement for that, have to pull the whole engine. Does this usually happen when in WOT?
spcmafia is offline
Old 06-22-2021, 12:02 PM   #78855
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
These are actually hella good.
Yes, they are. I have a Habit Grill near by and often go thru the drive thru just for some green beans for a snack.
Sapphireho is offline
spike021 (06-22-2021)
Old 06-22-2021, 12:03 PM   #78856
spcmafia
spcmafia's Avatar
I'll inspect it today after work, I was on my way to work running a bit late. Is a little weird since this is a fairly new car, less than 26K miles.
spcmafia is offline
Old 06-22-2021, 12:04 PM   #78857
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sustained acceleration probably got the exhaust hotter then normal. Just my guess.
Yes to reseal the timing cover, engine has to come out.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Wally86 (06-22-2021)
Old 06-22-2021, 12:06 PM   #78858
spcmafia
spcmafia's Avatar
Yes to reseal the timing cover, engine has tocome out.
It did remind me of the smell I sensed when I first fired up the engine after installing the headers. I don't usually drive on WOT, so it probably never really settled.
spcmafia is offline
Old 06-22-2021, 12:34 PM   #78859
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
There are ways to drive other than WOT!?!?
Spuds is offline
soundman98 (06-23-2021), Wally86 (06-22-2021)
Old 06-22-2021, 12:34 PM   #78860
Sapphireho
Connection issues
Sapphireho's Avatar
Talk about things melting, we are expecting 9 days in a row over 100°F. Way hotter than average. Ouch!
Old 06-22-2021, 12:39 PM   #78861
spcmafia
spcmafia's Avatar
Well there is the SSD drive. HDD drive, SATA drive.
spcmafia is offline
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
soundman98 (06-23-2021), Ultramaroon (06-22-2021)
Old 06-22-2021, 12:42 PM   #78862
spcmafia
spcmafia's Avatar
Dry heat or Satan's asshole (Fort Polk, LA) type of heat that has 98% humidity.
spcmafia is offline
Search this Thread:
Advanced Search
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
