#75559 | ||
I had figured when they said coding questions for this internal transfer opportunity, it'd be more like discussing code I've written here for my current team or work on a relevant problem for this new team. Not just a straight-up typical challenge problem that's asked of people interviewing to every new job. So while I'd seen this problem before, I hadn't practiced it recently and the pattern recognition for thinking through how to solve it was rusty. Some people can still solve stuff like that on the spot, but I got anxious. Also, in general when it comes to these types of interviews I've just always felt fairly insecure and unskilled because they're usually styled at one type of vague, very unrelated problem solving on the spot, which I'm not good at. Rather than the kind of problem solving that is actually relevant to the job itself. The last time I interviewed when I got my current job back in Dec. 2019, it was a full day on-site with 4 one hour segments, each with a different person. Did fine with 3/4 of them, panicked on one. I'm mostly out of practice, which makes the fear/anxiety problem worse. And it's difficult to spend time outside of work practicing because we're in crunch mode on some projects. Most people you ask would say the typical software engineer interviewing process is incredibly awful, but there's not really a better way either. The sad thing about this scenario is just that since I already went through that process, I was hoping/expecting that with this being internal, my earlier interviews would have counted and these would be more relevant to the role itself, which they clearly are not.
Instagram: @spike.brz
| The Following User Says Thank You to spike021 For This Useful Post: | humfrz (02-23-2021) |
#75560 |
Site Moderator
Drives: ichi 86 Project
Haha if you guys wanna know. Current name lists are:
Fiona Artoria Elise Aura Sonia Aria Mia Vanessa Sena Sydney Lily Rin & yes, a lot of name that ends w “a” lol |
| The Following 3 Users Say Thank You to ichitaka05 For This Useful Post: |
#75561 | |
Great list of names. I'd maybe add Sophia on there. I personally don't love Fiona/Vanessa but if you're happy with them that's all that matters!
| The Following User Says Thank You to spike021 For This Useful Post: | ichitaka05 (02-22-2021) |
#75562 |
ProCrastinationConsultant
wait until you see her. my brother and his wife did. they're confident in the name they chose. they individually had narrowed down their name lists to about 5 names per gender, but it's still a lot to choose from!
| The Following User Says Thank You to soundman98 For This Useful Post: | ichitaka05 (02-23-2021) |
#75563 | |
I know nothing about software engineering, however, I have interviewed for several positions during my working days in the scientific field. Most of the executives that I have interviewed with and were hired by, held a PhD degree and most of my prospective counterparts had PhDs. I had a BBS degree (Barely a Bachelor of Science - ), so, I had to try to avoid direct scientific questions.For example, in your case with the "typical challenge problem", I might have admitted that I was a bit rusty with that particular type of problem and would need to do a bit of research and/or brushing up to solve the problem. "HOWEVER, in the past I have successfully solved similar problems". "FOR EXAMPLE, when I was project manager of _______, a problem arose that involved ___________. I proceeded to _____ and ______. After consulting with _____ and _____ I laid out a plan that was accepted and was successful in meeting the objective, on time, within budget. AND THEN when I was _____, my team was given the task of __________, again, I _________ by _________." Just keep on going till the interviewer has had enough ......... This strategy may or may not work for you, in your field. ![]() Good luck with your next interview - |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (02-23-2021), spike021 (02-23-2021) |
#75564 | ||
.In these kind of interviews they don't want you to say it requires some research, even if it's just a matter of rust. It's basically like doing a decently tough Calculus/Linear Algebra/whatever problem, closed-book/notes/etc. You need to be able to perform on the spot. Generally they'll say something like "it's ok, we can walk through it together." But the results of that vary. Sometimes the interviewer means that and will gladly help you and that help doesn't negatively affect how they report the interview went. Sometimes depending on the interviewer, they'll be more like "I had to help this guy on this part or that part, which I think are too easy so they shouldn't have had issues with it" and it will reflect negatively. You can't really BS it, either.
#75565 | |
1st86 Driver!
In all cases, we had a few names picked out, and even with that, only used 1 of the selected names after the birth.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | ichitaka05 (02-23-2021), soundman98 (02-24-2021) |
#75566 | |
How about a nice Fannie or Bertha? https://wehavekids.com/baby-names/En...ve-Disappeared
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (02-24-2021) |
#75567 | |
1st86 Driver!
Oddly enough, its likely to be a dealer add-on! It won't top the Durango but 620HP or so is nothing to sneeze at. I think with the suspension changes they've made to the big SUVs it would be an interesting (but still very dangerous) driver.
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Tcoat (02-23-2021), Ultramaroon (02-23-2021) |
#75568 | |
Site Moderator
#75569 |
So do I but they are all about 80 years old!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (02-23-2021), Ultramaroon (02-23-2021) |
#75570 |
Site Moderator
Well, you’re around that age, that’s why. Edna is 60? But the rest are <30 for me.
#75571 | |
Drives: 2018 Subaru BRZ
Rin, because if you get a pet and name him Obito she will always take care of him.
| The Following User Says Thank You to spcmafia For This Useful Post: | soundman98 (02-24-2021) |
#75572 | |
Site Moderator
| The Following User Says Thank You to ichitaka05 For This Useful Post: | soundman98 (02-24-2021) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
