#73529 |
Drives: Crapcan
I always had good luck with cheap band-aids.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (11-08-2020) |
#73530 |
ProCrastinationConsultant
#73531 |
I know what I'd do with that defective puppy - and I don't care how good a deal I got on it.
Life can be too damn short -
#73532 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (11-08-2020), soundman98 (11-08-2020) |
#73533 |
Junior Senior with Cheese
Drives: 15 BRZ
| The Following User Says Thank You to ScoobsMcGee For This Useful Post: | humfrz (11-08-2020) |
#73534 | |
and there will never, ever be gas connected to it unless it's in use, and i'm within spitting distance from it. i might be crazy, but i'm not insane! i do have another propane torpedo heater, but it doesn't have a thermostat, and it sounds like a jet taking off a block away, so it means that i need to stop everything, turn it on, stop talking to myself because i can't hear anything while it runs, warm everything up, then turn it off again, and repeat, about every 10 minutes. the point of this was so that it's automatic enough to keep the garage tolerable while i'm pretending to be working in there!
#73535 | |
as part of the cost of hitting it, it was required that we all attend a day 'class' about it. (it would have been nicer if they had just lined us up and snapped our knuckles with a ruler for 4 hours) one of the first things they spent 1/4 of the day on was the origins of 811, and chain of command. they went through an incident where a utility crew hit an unmarked gas main and a sewer line in the middle of winter while doing some repairs in the street, and no one claimed jurisdiction. as they were trying to notify emergency services, and get gas and electrical shut down, the gas backfed through the sewer lines into nearby houses. when the furnaces kicked on, the houses blew up, one by one. it was something like 10 houses by the time all the agencies got organized enough to do anything about it. i also learned that the utility companies can legally run their lines on the surface, and it would still be the fault of anyone that hit them for any reason. if a homeowner were to hit a line with a lawnmower, they could be ticketed for it... a plumber was there because he rotted out a clogged sewer line(house to street), the gas company had cut and ran their gas supply THROUGH the sewer line, and the plumber was fined and ticketed for hitting the gas line with his pipe clearing equipment, and additionally ticketed for not having the entire front yard marked out, not having a dig ticket on file, and for not digging up to clarify that he wasn't close to any utility lines. the 'teacher' said the only right way for him to do his job is to quote every single customer to dig up their entire yard, for every simple roto-rooter job--imagine getting that quote... i think everyone that was forced to take that 'class' left more angry and disgusted with the utility companies than they had arrived.
| The Following 5 Users Say Thank You to soundman98 For This Useful Post: | MICHAEL450f (11-08-2020), NoHaveMSG (11-08-2020), ScoobsMcGee (11-08-2020), Spuds (11-08-2020), Ultramaroon (11-08-2020) |
#73536 | |
The Dictater
Drives: '13 Red Scion FRS
We had an incident when somebody blew up some very large lipo batteries because they weren't charging them correctly (I forget exactly what they did, but it was excessively stupid). The entire company had to take online battery training. And then they did it again and the entire company had to take a revised training... |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (11-08-2020), Ultramaroon (11-08-2020) |
#73537 |
The other thing to consider when using a non-vented heater in a garage is the condensation. All cool metal surfaces will get wet. Tools, all parts of the car, light fixtures.
Before i gave up on a top hat heater and went vented i would open the doors and run my summer fan after i worked. The other shop i used a torpedo heater as it put heat where i was working, and again would open the doors when done. |
| The Following User Says Thank You to ls1ac For This Useful Post: | soundman98 (11-08-2020) |
#73538 |
Drives: 15 BRZ
Happy to say that the passenger seat came out without any drama, unlike the driver's seat. Now to figure out this airbag occupancy sensor. Thankfully have all winter for that.
The TOB went from a slight whine at the beginning of the week to a wail when I started up the car yesterday. So I put the thing away despite the nice weather and will spend the winter working on the seat, and figuring out which clutch/flywheel to get to accommodate the inevitable high boost pully I'm not smart enough to avoid getting. |
| The Following 4 Users Say Thank You to ScoobsMcGee For This Useful Post: |
#73539 | |
Drives: Crapcan
Tracbox has seatbelt chime disable option. https://www.geraldjustprojects.com/p...gt86-trac-box/ Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | ScoobsMcGee (11-08-2020) |
#73540 | |
fabulous
![]() Either you know what's up, or you don't. I totally get it.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (11-08-2020), Tcoat (11-08-2020) |
#73541 | |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-08-2020) |
#73542 | |
fabulous
The drive unit acts like a sprag clutch so it doesn't push the belt. That's a huge deal for me.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
