86WORX
Old 12-23-2019, 01:58 PM   #64471
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Wheels and tires. Brakes are for pu$$ys.
Jk, brakes are important, but how will it affect your bias? Looking at your build thread, you already have 4 piston calipers on the front, which probably affected your bias. Would it be better if you swapped out the rears as well?
For daily bias isn't bad as ppl calculated to be. I've done few tests on it (other than daily), but bias is very minor. BUT that doesn't mean anything. atm I'm leaning towards brakes as well. We'll see how it goes
ichitaka05 is offline
Spuds (12-23-2019)
Old 12-23-2019, 02:06 PM   #64472
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Debating to buy rear Subaru 2 piston calipers kit plus upgrade pads or buy new wheels and tires for next yr... Can't do both, cuz both cost bout the same amount.
The real question is, will the 2 piston rears be the best design ever and allow you to see your brakepad wear without removing the caliper?
wolffbite is offline
The Following 5 Users Say Thank You to wolffbite For This Useful Post:
humfrz (12-23-2019), ichitaka05 (12-23-2019), NoHaveMSG (12-23-2019), soundman98 (12-23-2019), Spuds (12-23-2019)
Old 12-23-2019, 02:09 PM   #64473
ichitaka05
Site Moderator
ichitaka05's Avatar
Damn you! I didn't expect that answer (question?) here... now, I've spill my water all over my desk and my boss is wondering what's going on here.
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
soundman98 (12-23-2019), Spuds (12-23-2019), wolffbite (12-24-2019)
Old 12-23-2019, 02:24 PM   #64474
Ultramaroon
fabulous
Ultramaroon's Avatar
I'd want adjustable brake bias on the fly if I was tracking regularly. Once experienced, it becomes a necessity. Or maybe I just like having another knob to tweak. I sure loved experimenting with it.
Ultramaroon is offline
Old 12-23-2019, 02:32 PM   #64475
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Wonder what the ABS computer would do if you put an adjuster on each of the rear main lines
NoHaveMSG is offline
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 12-23-2019, 02:36 PM   #64476
humfrz
Well, they do say not to swim in, or eat the fish from Lake Lowell.
Well ya, that best be heeded. The Shoshone did say they could come back in other forms -
humfrz
humfrz is offline
Old 12-23-2019, 02:43 PM   #64477
Ultramaroon
fabulous
I think not much. It'd still kick in based on what it sees from the wheel speed sensors.
Old 12-23-2019, 03:09 PM   #64478
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If you are at the level where you need adjustable brake bias, wouldn't you just pull the ABS fuse before getting on the track?
Spuds is offline
Old 12-23-2019, 03:20 PM   #64479
Ultramaroon
fabulous
Maybe, but the question here is whether or not it would freak out. I have only a few laps of autocross test and tune experience with adjustable brake bias. I was impressed but wonder how much I would fiddle with it once I got it dialed.
Old 12-23-2019, 03:22 PM   #64480
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pulling the fuse jacks up the bias pretty bad. I am not at the point of going that far it was just an out loud thought based on what Ultra said.
Spuds (12-23-2019)
Old 12-23-2019, 03:29 PM   #64481
humfrz
….careful with that kind of thinking -
humfrz
humfrz is offline
The Following 4 Users Say Thank You to humfrz For This Useful Post:
korhun (12-24-2019), NoHaveMSG (12-23-2019), Spuds (12-23-2019), Ultramaroon (12-23-2019)
Old 12-23-2019, 06:08 PM   #64482
ichitaka05
Site Moderator
ichitaka05's Avatar
Local 86/BRZ fb gp was selling new KYB Excel-G struts for $100 (all 4 of em). Not sure it's worth it or spent extra to go Koni Yellow
Old 12-23-2019, 06:13 PM   #64483
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
go koni yellow.
the KYB is less.. good than your stock shocks.
Clutch Dog is offline
Old 12-23-2019, 06:16 PM   #64484
ichitaka05
Site Moderator
ichitaka05's Avatar
Originally Posted by Clutch Dog View Post
go koni yellow.
Was it less? I thought it was bout same was stock (maybe fraction stiffer than stock). Either way, next yr, I gotta replace my struts, so looking into different options.
Also annoying part of Koni Yellow is, you gotta drill bigger hole for the rear top hat.
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
