#62959 |
Drives: Crapcan
To lower compression you would have to increase the combustion chamber volume at TDC. Since piston and rod heights are fixed the only way to increase chamber volume is to alter the stroke.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | p1l0t (11-15-2019) |
#62960 |
fabulous
Yes.
#62961 |
fabulous
I suggest mentally picturing the system on end and consider how the cylinder bore and crankshaft axis of rotation are both fixed.
#62962 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
[ame]https://www.youtube.com/watch?v=Qffp-38_ycE[/ame]
#62963 |
Drives: Crapcan
I'm lucky if they even put the plates on the rack and wipe down their equipment when done at my gym. The evening crowd is lazy.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | spike021 (11-15-2019) |
#62964 |
Drives: 2017 BRZ PP , 2005 Saab 97X
| The Following 5 Users Say Thank You to Clutch Dog For This Useful Post: | soundman98 (11-16-2019), spike021 (11-15-2019), Spuds (11-15-2019), Ultramaroon (11-15-2019), weederr33 (11-15-2019) |
#62965 |
Drives: 2013 frs red
What is the point of variable compression ratio?
#62966 |
fabulous
Lower CR under boost. Higher when cruising with cracked throttle. CR profile is tailored to further maximize ignition advance across a wider range of operating conditions. (gamut?)
Now I'm going to go study to see if I'm in the ballpark.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#62967 |
fabulous
Ok, yeah, I'm a smartypants.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (11-16-2019) |
#62968 |
The Dictater
Drives: '13 Red Scion FRS
Higher pressure results in less losses to entropy during combustion. In theory you want the highest compression you can get at all times. But the limiting factor is the tendency of gasoline/air to detonate when you compress it too quickly. By decreasing the maximum pressure, you decrease the rate of compression. Thus allowing higher rpm, advancing timing, and more fuel/air (higher boost) at higher temperatures.
Being able to tune the compression ratio gives you the best of both worlds in the same engine. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Lantanafrs2 (11-15-2019), Ultramaroon (11-15-2019) |
#62969 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (11-15-2019) |
#62970 |
Dismember
Drives: 2013 Red Scion FR-S
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Lantanafrs2 (11-15-2019) |
#62971 |
fabulous
#62972 |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
