86WORX
Old 10-08-2019, 02:49 PM   #61629
Oh, OK, I'll update the picture -
humfrz
Looks more like Ho but that probably isn't milk.
Tcoat is offline
Old 10-08-2019, 02:53 PM   #61630
humfrz
I did say giant.
Unrelated, but mechanic got the bolt out. Took 2 hours of trying stuff, and then they ground it down and welded a hex bolt head to it. I suggested they try a nut over the torx head, but I think they drilled the old head out to try to tap it first.
That's the way they should have come from the factory -
humfrz
humfrz is offline
ScoobsMcGee (10-08-2019), Tcoat (10-08-2019)
Old 10-08-2019, 02:57 PM   #61631
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
My Grandmother had several like that except they had been slightly modified. My Grandfather removed the handle and connected rod that would fit in the chuck of a variable electric drill. Easy work...
I was totally thinking the same thing last night.
Sapphireho is offline
Dadhawk (10-08-2019)
Old 10-08-2019, 03:00 PM   #61632
Cole
Not a troll
Cole's Avatar
So uh, that veteran plate thread got out of hand real fast, eh?
Cole is offline
The Following 3 Users Say Thank You to Cole For This Useful Post:
ScoobsMcGee (10-08-2019), soundman98 (10-08-2019), Tcoat (10-08-2019)
Old 10-08-2019, 03:01 PM   #61633
humfrz
My Grandparents owned a "cheese grade" dairy farm so they always had fresh butter, buttermilk, and of course "just from source and still warm" milk. I miss that stuff, but not enough to have a cow to milk!
I thought about that - but, I really couldn't see the advantage -
humfrz
humfrz is offline
Old 10-08-2019, 03:06 PM   #61634
1st86 Driver!
humfrz
Better gearing on that one, would still churn faster.
Dadhawk is offline
humfrz (10-08-2019)
Old 10-08-2019, 03:30 PM   #61635
Ultramaroon
fabulous
Ultramaroon's Avatar
(directed at myself)
I don't know why I didn't consider it is a hall sensor. Yeah, it does pull it's own separate 12v source for the actuator.
It was the factory that suggested I fake a throttle input. I guess I just have to give them a call, but since they got bought by Borgwarner they are a pain to get ahold of.
It should be easy enough to fake the throttle input but you will need a 5V power source. Even a phone battery will work (3.7V-4.2V). I'm sure there's a pull-sown resistor at the input. Check the input resistance to ground with a DMM and make a little voltage divider that includes a compatible potentiometer. I can draw up a quick schematic if will help.
Ultramaroon is offline
NoHaveMSG (10-08-2019)
Old 10-08-2019, 03:44 PM   #61636
Ultramaroon
fabulous
I spend about 4 months a year with that one. When I go back to my summer tires it seems like something is wrong when it is gone.
My commute is less than 20 miles round trip. The car picks up the registered sensors in the garage and I never see a fault.
Tcoat (10-08-2019)
Old 10-08-2019, 04:02 PM   #61637
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
In hindsight, kind of wish I didn't hunt that one down.
ScoobsMcGee is offline
Old 10-08-2019, 04:03 PM   #61638
My sensors are stored about 20 miles from home.
Tcoat is offline
Ultramaroon (10-08-2019)
Old 10-08-2019, 04:09 PM   #61639
Tcoat is offline
Clutch Dog (10-08-2019), p1l0t (10-08-2019), ScoobsMcGee (10-08-2019)
Old 10-08-2019, 05:18 PM   #61640
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks I appreciate it. No need for schematic. I think we are just going to mechanically actuate it. In the end I doubt we continue to use this controller much longer as the software doesn't work on anything beyond Windows XP and the new Gen 4's have more inputs.
NoHaveMSG is offline
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 10-08-2019, 06:56 PM   #61641
humfrz
I can't find it - where is it?
humfrz
humfrz is offline
Old 10-08-2019, 08:13 PM   #61642
humfrz
Welp, as I remember, back on the farm, when I was very young, my grandmother would sit me down on the yellow, linoleum covered floor in the kitchen and place a churn full of cream in front of me.
She told me to crank the handle, to make butter. She really didn't care how fast I turned it. I asked, how long do I have to turn the crank? She said, until it won't turn anymore.
After a spell.
Gran ma-ma! I made butter! -
She said, good job and dumped out the butter and whey into a bowl and filled up the jar again, set it down and told me to make more. The second batch wasn't nearly as fun -
humfrz
humfrz is offline
Dadhawk (10-08-2019), NoHaveMSG (10-08-2019)
Search this Thread:
Advanced Search
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
