#61503 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Does the glove box cigarette lighter plug fit?
"I gotta rock." -- Charley Brown |
#61504 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | humfrz (10-06-2019) |
#61505 | |
Drives: 2017 BRZ PP , 2005 Saab 97X
haha no.. its a 3/8th hole the cigarette lighter is a bit too big
its just a black veneer so worst comes to worse. i have to self etch primer and then lay some cheap rustoleum black paint on it. probably in matt. and then call it good enough the other cheaper and lazier option is finding a neat blanket and stapleing it to the back and boom no more bolts or holes |
#61506 | |
Drives: 2017 BRZ
Any hardware store or lumber yard should have 3/8" dowel. Get a door trim saw (should be small, cheap, and flexible) and it'll give you a nice flush cut. Glue the dowel in place, THEN cut. You push the blade flat against the surface - it flexes to allow this, and if you're careful it won't mar the surface No need for bondo. A good fit should be flush and clean. If you're painting or veneering and need filler, good old spackle works just as well (the stuff you fill holes in the wall with). A true craftsman isn't measured by making few mistakes... it's by how they're handled. Googly eyes over the holes might work too...
#61507 |
fabulous
I just cut a few toothpicks in half, wet the cut ends with a little glue and stuff them into the drilled hole. Once they fill the space, I continue wedging with the tapered ends and gently tap them home. 3/8" might be too much to fill this way but I figured I'd share.
#61508 | |
Drive From Home
Drives: BRZ STI Performance
![]() The people that are working on them I mean at least my place we are starting to see a lot of peeps retire and it's bad. Somebody high up at Swatch told me before about Breguet watchmakers retiring and losing technical expertise at the company. |
| The Following 2 Users Say Thank You to krayzie For This Useful Post: | Dadhawk (10-06-2019), Ultramaroon (10-06-2019) |
#61509 | |
1st86 Driver!
In this case, I think the dowel should work OK, as would the decorative cover like some draw pulls.
![]() Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Ultramaroon (10-06-2019) |
#61510 | |
Drives: 2017 BRZ
This can work really well. This can be a bear to sand though... need a good wood to glue ratio for it to work out.
| The Following User Says Thank You to cjd For This Useful Post: | Dadhawk (10-06-2019) |
#61511 | |
Then, when the law changes - BAMB - you will be ready to be a gentleman farmer. - humfrz |
#61512 | |
Connection issues
Drives: '15 ultramarine
I'm all for the state gubment doing it and just lowering everyone's taxes. State already has the brick and mortar liquor stores, just add pot. Keep the price lower than Oregon and whammo, tons of money for the state. Have a lottery for what farms can grow, and limit each to no more than an acre, New lottery every couple years to spread the wealth with farmers. Tons of testing, so no products killing people. Win all around. |
#61513 |
Connection issues
I actually like gambling better at the Red Dog than I do in reno.
#61514 | |
ProCrastinationConsultant
#61515 | |
![]() Don't be overengineering this situation (like several people are advocating - ).It's a fucking bedroom! Just how much time do you spend in there looking at the headboard? - ![]() Just go to Lowes, buy a couple of Hillman black plastic plugs and push them in place. After a few days/nights you won't even notice them! SMH ![]() ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (10-06-2019), Tcoat (10-06-2019) |
#61516 |
Connection issues
I took my truck to a local shop. I'm still trying to find shops I feel comfortable with.
Took it to Roger's tire and service. They had it the week I was gone. Brought it in for the bent axle, and told them while it was here, do a radiator flush, transmission service, and oil change. They did everything but the axle. Didn't even look at it. First line on the ticket, and no one saw it. Finding a new shop. |
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
