#50933 |
Connection issues
Drives: '15 ultramarine
#50934 | |
The Dictater
Drives: '13 Red Scion FRS
#50935 |
Well, I reckon you're jest ah usen too much, you don't hafta use the whole can -
![]() I was usen belt dressing before you were born, on bigger belts than you have ever worked around. It was black sticky stuff that came in large cylinder shaped tubes. The only difficulty was to figure out which side of the belt to treat, when they crossed the belt to make the machine run in the proper direction. humfrz for Bubba |
| The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (12-04-2018) |
#50936 |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Sapphireho (12-04-2018) |
#50937 | |
Connection issues
The other option is machining the inside of the rim, but then the clock gets way too expensive. |
#50938 |
fabulous
But then you're just hanging a wheel on the wall.
#50939 |
Connection issues
#50940 |
fabulous
You have to make the clock. Otherwise you're just keeping it for spite.
...which is still a good enough reason but it's no clock.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (12-04-2018) |
#50941 | |
#50942 |
The Dictater
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (12-04-2018) |
#50943 |
Drives: 2017 BRZ
Nothing that fits inside the center bore?
#50944 |
Connection issues
#50945 |
Connection issues
I found a small round clock motor that would fit in the bore. It is commonly used to restore old auto clocks, but it is super wimpy and only has enough torque to handle 1 inch arms, so it would be a very tiny clock in a big rim.
#50946 |
fabulous
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
