#49253 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | ScoobsMcGee (10-09-2018) |
#49254 | |
humfrz
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Sapphireho (10-10-2018), ScoobsMcGee (10-10-2018) |
#49255 |
Junior Senior with Cheese
Drives: 15 BRZ
| The Following User Says Thank You to ScoobsMcGee For This Useful Post: | humfrz (10-10-2018) |
#49256 | |
Well, there's a chance my TOB and/or clutch fork is starting to go. A few months ago I started getting a "tuhtuhtuhtuh" or similar (i don't know how to enunciate in text) if I depressed the clutch all the way, but not all the time. Same thing happened tonight while I happened to be with some 86 guys down here, and they think it's clutch-related.
I think 2017+ are supposed to have a better one? ![]() Unless I just put more stress on it the first 4 or so months learning to drive manual properly..
Instagram: @spike.brz
| The Following User Says Thank You to spike021 For This Useful Post: | humfrz (10-10-2018) |
#49257 | |
![]() (I'm jest ah messen wich ya - )humfrz Last edited by humfrz; 10-10-2018 at 01:54 AM. |
| The Following User Says Thank You to humfrz For This Useful Post: | ScoobsMcGee (10-10-2018) |
#49258 | |
If it just squeaks while pushing it in or letting it out, with or without the engine running, it may be that just the clutch fork is dry. Several fixes have been posted to quiet it down (basically, lub it). I doubt that your "learning curve" with the clutch, caused the TOB undo stress. Maybe the clutch disk took a beating, but they don't usually make noise unless they are worn out or are coming apart. So, can the noise be heard if the engine is running but the clutch is NOT engaged? How about when the engine is running and the clutch IS engaged (pedal pushed to the floor)? How about a video/audio - humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | spike021 (10-10-2018) |
#49259 | ||
As far as squeak while pushing in/letting out, yeah I've gotten that at times, but not all the time. Nope, usually it's when I've started the car and then engage the clutch. When it happens I feel like it happens more often within the first half hour or half mile since the car's turned on. But can also happen later than that from stops.
#49260 | |
So, when you push in on the clutch and start the engine, does it make that sound (not the squeak, but the other sound) or does it just make the sound when you let up on the clutch pedal? Calling on all clutch/TOB experts, we need a little help here - ![]() humfrz |
#49261 | ||
#49262 |
Drives: 2014 BRZ Limited
just get a loud exhaust and you won't have to worry about it anymore. these cars are so noisy I had to put a stop to it.
| The Following User Says Thank You to echo419 For This Useful Post: | spike021 (10-10-2018) |
#49263 |
Drives: Subaru BRZ and AE86 coupe
I used to drive a Fiesta ST. Loved that car, but the small interior space wasn't cutting it.
Build Threads:
----------------------------- 1985 AE86 Coupe /// 2014 BRZ Limited (soon.. gathering pictures) |
#49264 | |
Drives: 15 BRZ
Hey now, that red pinstripe was hand drawn! I even paid extra to have my initials written along the pinstripe at the back of the doors. |
#49265 |
Country Boy 4 Life
I must have missed this piece of info when looking at coilovers.
Fortune Auto Coilovers are designed and assembled in Richmond VA. I'm a HUGE fan of MADE in USA! And, I thought I had made up my mind on what I wanted... Back to researching....
I LIKE TIRES! |
#49266 | |
Find out where the components are MADE. Wording is everything here.
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
