#4313 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Just dont okay.
Jokes aside If you want a drop more then 1 inch you will need new shocks or some good coilovers. Then you will also need LCA's and will probably want to look into roll center correction. |
#4314 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I thank the counsel for their quick consensus
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | go_a_way1 (03-24-2016) |
#4315 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
you lose too much travel, ride the bumpstops and get a bouncy uncontrollable ride
#4316 |
Not Bаnned Anymore
and he forgot to add "because racecar" does not work here. The real reason anyone does this is because retard
#4317 | |
#4318 | |||
![]() More then 1.5 front and back (I don't care what the spec sheet says I own a tape measure). Over 60K miles. Only bounced off the stops 10 or so times. Ride is little different than stock. Handling is maybe a tad better EAT IT!
| The Following User Says Thank You to Tcoat For This Useful Post: | go_a_way1 (03-24-2016) |
#4319 |
Drives: 2015 CWP BRZ Limited
We only have about 5mm of travel before we start compressing the bump stops in the front. The bump stops act as a sort of secondary spring with a rapidly increasing spring rate in these cars. The OEM bump stops are 60mm tall. While you may not completely bottom out the suspension, I assure you, you are compressing the bump stops every single day.
| The Following User Says Thank You to jawn For This Useful Post: | go_a_way1 (03-24-2016) |
#4320 |
Drives: 2013 Brz C38 (bought not built :P)
and it's officially hailing/frezzing rain
| The Following User Says Thank You to fumanchu1 For This Useful Post: | go_a_way1 (03-24-2016) |
#4321 |
So what you're saying is sportlines just suck?
#4322 | |
#4323 |
Not Bаnned Anymore
We got 6cm of snow on the way out west
#4324 |
I have no opinion on them I have never used them.
#4325 | |
-You people... -(Robert downy jr.)WHAT DO YOU MEAN YOU PEOPLE -(actual black guy) What do YOU mean you people!!! |
#4326 |
A Demon
Drives: Raven GT86
Fuck it I'm getting racelands
| The Following User Says Thank You to ZOMFGAARON For This Useful Post: | finch1750 (03-24-2016) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
