Old 01-19-2017, 03:21 PM   #25817
Teseo
Drives: frs
'Knock knock'
-whos there?
'Childhood'
Teseo is offline
Old 01-19-2017, 03:38 PM   #25818
Ultramaroon
fabulous
Ultramaroon's Avatar
Even though I'd probably die from exhaustion, this sounds so much fun!
Karting is a whole different experience. I tried to use techniques I learned in auto-x and some of them doesnt carry over at all.. especially late braking lol
Braking techniques would carry over if karts had front brakes. Think about how it would feel if all you had was your handbrake.
I struggle with braking on karts too.
Ultramaroon is offline
soulreapersteve (01-19-2017)
Old 01-19-2017, 03:55 PM   #25819
gramicci101
Off Topic
And trunk. Shit. In retrospect I guess I AM looking at going to that extreme after all.
Nah, there's a big difference between just dynamat vs. dynamat plus high density foam plus low density foam. On one hand, you'll already have it all apart, so you might as well. On the other hand, it's more work, more materials, more cost, and more time for a benefit that you may not need.
If you're not going to go crazy with sound deadening, I'd really only worry about the trunk if it becomes a problem. The goal is to mute road noise around the passengers, not mute road noise in the trunk. Unless you drive with the seats down or put passengers in the trunk frequently. Your license plate might buzz against the trunk, so maybe put something under that to keep it from hitting.
gramicci101 is offline
Old 01-19-2017, 04:04 PM   #25820
Was watching the Barrett Jackson auction last night and not sure if I remember correctly (there were so, so many cars) but I believe it was a 66 Corvette that had a front brake delete as a factory option!
Tcoat is offline
Ultramaroon (01-19-2017)
Old 01-19-2017, 04:05 PM   #25821
Well not sure if "passengers" is the right word for who goes in the trunk!
Tcoat is offline
finch1750 (01-19-2017), gramicci101 (01-19-2017)
Old 01-19-2017, 04:09 PM   #25822
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I used to have my seats down all the time til the rattling from the sub started. If i could get back to that I'd be happier
finch1750 is offline
Old 01-19-2017, 04:41 PM   #25823
gramicci101
Off Topic
Then I would definitely take a look at everything nalc did for his trunk. And potentially under the rear deck as well.
Old 01-19-2017, 04:51 PM   #25824
Ashikabi
Ashikabi's Avatar
I spent about 120$ adding a powered sub in my trunk. Super happy with it. Install was easy. Probably going to switch to the Subaru factory option sub though as it tucks in the corner instead of occupying half my trunk. It's about $300 used in the classifieds
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (01-19-2017)
Old 01-19-2017, 04:53 PM   #25825
That is an option as well but they are pretty scare up here and I don't want to pay exchange to bring one up. Buying one new form the dealer is just way more than it is worth I think.
Tcoat is offline
Old 01-19-2017, 06:23 PM   #25826
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Allch Chcar View Post
I will have to get into tuning at some point. I asked about E85 at a local fuel retailer, Renners', and they haven't gotten back to me. They do racefuel up here so I might try shipped drums if I can. I used to only burn about 18-20 gallons of fuel a month. The Mazda3 got 37-38mpg. I just got 33.976 with the BRZ on the entire highway 36 stretch to bring it home. I could run 50/50 blends and make a 55 gallon drum last a couple months. E50 is the peak of the efficiency delta I think and air temps stay pretty low around here.
How fast were you going? I averaged around 36mpg in my FR-S. The FA20 goes into closed loop enrichment at very low load, so leaning out the tune helped a lot when going up hills. I set the idle to 600rpm which saved 10% at idle. Then the VVT settings gave me 1mpg at steady state 60-65mph cruise.
The hardest part about getting good mpg was that when I was trying to find parking in SF, I would burn through a crazy amount of fuel because the FA20's efficiency drops like a rock below 2000rpm, and the 2800lb curb weight is much more than my Spyder's 2200lb curb weight. The Spyder managed to get 25-27mpg going between stop signs while the FR-S struggles to do 22.
Nowadays I just have my 2ZZ Spyder as a track toy and I don't drive to work, so I don't care about fuel economy anymore. The stock tune on the 2ZZ is not bad, the AFR is around 12.8 at red line and it runs closed loop stoich whenever you're below 3700rpm or something. It gets around 40mpg on the freeway, which is good enough for the rare occasion it gets to go on the freeway.
serialk11r is offline
Old 01-19-2017, 07:00 PM   #25827
finch1750
finch1750's Avatar
Whats the spyder like compared to your twin? And does your twin have header and tune?
I have a Spyder but cant imagine keeping it for a lot longer. The 2zz seems like the lack of torque would make it not as good a DD still.
Old 01-19-2017, 07:06 PM   #25828
Ultramaroon
fabulous
Well, that's beyond stupid. NHTSA was formed in 1970. What's the Canadian equivalent?
Old 01-19-2017, 07:26 PM   #25829
serialk11r
Keep in mind that you have much less weight on the Spyder, so it actually feels much more torquey than an FR-S even though the stock tune on the 1ZZ and 2ZZ has very bad low end torque. At least that's how I feel about it, when I get into my FR-S my immediate thought is "gosh this is really slow". Some people think a 1ZZ has more torque, but they're plain wrong, the 2ZZ is actually a little bit stronger in the low end, the same around 3000rpm, and slightly weaker in the 5000-6000rpm range before the second cam engages. The small cam has lower duration which is better for the low end, but very low lift which chokes the engine a little.
My FR-S is basically stock. I flashed it back to stock since I'm trying to sell it, but with the tune it had appreciably more grunt than stock. A header would help a lot, but it is a s***load of money and you would also have to find the right smog check person to stuff a few benjamins which is not cool.
I like to think of the Spyder like a motorcycle with some pannier bins, the only thing you carry in it is yourself plus a bag or two. Performance wise it's plenty fast with a stock 2ZZ. A tune gets you into the 200bhp range before any physical modifications, and brings the low end torque up a good amount, and would be perfect as far as power is concerned IMO. A K20 or 2AR-FE would be better for durability however.
Old 01-19-2017, 07:50 PM   #25830
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
New random thought:
Why the fuck does literally nobody listen to anything other than annoying rap, or ear-piercing metal these days? Here's a gorgeous performance of "All I Ask of You' from 'Phantom of the Opera' just to piss you all off (also, Sierra Boggess is a cutie):
[ame="https://www.youtube.com/watch?v=WqQcYQgQkS8"]Michael Ball & Sierra Boggess - All I Ask Of You HD - YouTube[/ame]
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline
Search this Thread:
Advanced Search
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
