Old 08-04-2016, 03:33 PM   #15051
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Drives: 15 BRZ
I know! RT is on point today.
Some days I want a "Thank All" button.
ScoobsMcGee is offline
The Following 3 Users Say Thank You to ScoobsMcGee For This Useful Post:
MrFisty (08-05-2016), Tcoat (08-04-2016), Ultramaroon (08-04-2016)
Old 08-04-2016, 05:23 PM   #15052
HunterGreene
Hail Magnet
HunterGreene's Avatar
Sorry
slow day.
Everybody is on vacation and I am running the plant.
I have no idea how to run the plant so it is on it's own.
So far I have heard no screams, sirens or other blatantly obvious indications of disaster so will just let the guys do what they do.
God, I hope they know what they are doing.
You know that means that the employees know exactly how much you know about running the plant, which means that they are all slacking off, hence the lack of disaster noises.
It has priests in it?
HunterGreene is offline
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (08-04-2016)
Old 08-04-2016, 05:43 PM   #15053
Nah they know I know how it runs. We actually were 2% over normal which could be bad since they may want to know how I did it and my only answer would be "I left them alone".
Tcoat is offline
Dadhawk (08-05-2016), HunterGreene (08-04-2016), Ultramaroon (08-04-2016)
Old 08-04-2016, 05:57 PM   #15054
HunterGreene
Hail Magnet
And that, folks, is how effective management works.
Old 08-04-2016, 06:02 PM   #15055
I mean they are only making rotors. What could possibly go wrong?
Tcoat is offline
Old 08-04-2016, 06:10 PM   #15056
Ashikabi
Ashikabi's Avatar
Do those get turned on a lathe or is there some kind of "rotor machine". Do they start out as a casting?
Ashikabi is offline
Old 08-04-2016, 06:19 PM   #15057
Casting is turned on machines similar to lathes, drilled and then balanced. There are very tight specs and they are gauged many times through the process. Oh and those things will rust if you look at them wrong until treated.
We make about 5 million a year in our plant.
Tcoat is offline
Old 08-04-2016, 06:21 PM   #15058
Ashikabi
Ashikabi's Avatar
That's about what I expected. Seemed the most efficient. Do they load automatically or does someone have to stick each one in the chuck?
Ashikabi is offline
Old 08-04-2016, 08:14 PM   #15059
Pretty much all auto. Robot picks casting up from dunnage, it passes through all the machines and guy at the end of the line puts it in the customer dunnage.
Now the guys have to do several things in between but the machines do all the heavy work.
Tcoat is offline
Old 08-04-2016, 08:23 PM   #15060
Ashikabi
Ashikabi's Avatar
Again, that's about what I expected.
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
Tcoat (08-04-2016)
Old 08-04-2016, 08:44 PM   #15061
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Sorry
slow day.
The Twins make me smile
soulreapersteve is offline
The Following 4 Users Say Thank You to soulreapersteve For This Useful Post:
Dadhawk (08-05-2016), HunterGreene (08-05-2016), Tcoat (08-04-2016), Ultramaroon (08-05-2016)
Old 08-04-2016, 08:46 PM   #15062
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
I'm guessing if you've seen a few episodes of "How It's Made" you have a rough idea of how just about everything is made.
While there are millions of different widgets in the world, only a handful of processes make most of them.
iamjacob is offline
The Following User Says Thank You to iamjacob For This Useful Post:
Tcoat (08-04-2016)
Old 08-04-2016, 08:53 PM   #15063
Pretty much only the scale of the equipment changes.
I used to work where they made heavy truck springs and it was the most diversified as far as process went. Ranged from pretty much hand forging all the way to laser and plasma robotic cutting and just about every level of tech in between. You could watch 3 episodes of How It's Made on the place and still not se every operation. The heat treat operators were closer to witch doctors than factory workers.
Tcoat is offline
Old 08-04-2016, 08:55 PM   #15064
Totally inaccurate!
I have hair and there is no window from my office into the plant floor at that site.
Tcoat is offline
Cole (08-05-2016), soulreapersteve (08-04-2016)
Search this Thread:
Advanced Search
Random Rubber Part OoLong BRZ First-Gen (2012+) -- General Topics 8 01-28-2014 11:31 AM
