Old 02-20-2016, 03:18 AM   #1
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Spec-D Black vs. Gloss
TL;DR:
Is there a comparison of the black and gloss black Sepc-D headlight?
I've been eyeing the Spec-D's for a long time and noticed two listings on FT86Motorsports. There is a "black" and "gloss black" available, both have the same description and pricing. The images (below: Black followed by gloss) look the same to my eye.
Black
Gloss
I have exhausted my search ability (both here and online), has anyone seen both; if so, is there a noticeable difference (eg: high contrast as in matte vs. gloss) between the two?
PS: I would contact the site/manufacturer, however I'm a while away from upgrading my lights, focusing on other parts
Thanks in advance!
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 02-20-2016, 03:22 AM   #2
_gt86_user
Inactive
Drives: .
Ones matte ones gloss black housing inside, my opinion spend your money elsewhere for sure do not buy.
_gt86_user is offline   Reply With Quote
The Following 2 Users Say Thank You to _gt86_user For This Useful Post:
NyC Zn6 (02-21-2016), YamahaR86 (02-20-2016)
Old 02-20-2016, 03:37 AM   #3
Sosa
[||]--(86)--[||]
Sosa's Avatar
Matte vs. gloss is a decision I can live with, but why spend elsewhere (as far as lighting is concerned)?
I understand that they’re heavy, as in Monogram/10 Series heavy, they require some play to get the lighting right, and sunlight may wash out the “boomerang”. Is there anything else I should be aware of?
[||•]==(86)==[•||]
Old 02-20-2016, 10:49 AM   #4
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Lighting sucks. I have HIDs in mine but it's still bad. The projectors are halogens which mean they're suited for halogen bulbs. The light output is subpar, hotspots and an erratic cut off line. I've heard some people say their highbeams are stuck "on" as well on one of them so they have to keep flicking them on and off to get the flap to low again.
I don't like the boomerang color, it's a bluish instead of white, so I plan on changing out the LEDs in them to white when I open them up to replace the projectors as well to morimoto minis.
Also, this applies to spyder as well as any other aftermarkets. The headlight will lose it's UV coating in a year. It'll start to peel and crack.
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Sosa (02-20-2016)
Old 02-21-2016, 02:26 AM   #5
Sosa
[||]--(86)--[||]
Sosa's Avatar
Damm it, lol! I could get over most your dislikes, but poor lighting and an abrupt cutoff is concerning. Back to the drawing board for me (black out/JDM/BRZ). Thanks again Yamaha!
[||•]==(86)==[•||]
Old 02-21-2016, 02:44 AM   #6
ryoma
ryoma's Avatar
you will probably get better performance by just using an HID kit in your stock housing. don't use anything JDM since their cutoff is on the wrong side
Old 02-21-2016, 02:47 AM   #7
Sosa
[||]--(86)--[||]
Sosa's Avatar
This I remember, should have posted monogram/10 series, my bad :-)
[||•]==(86)==[•||]
Old 02-21-2016, 04:41 AM   #8
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
if you buying small items from them i can tell you go ahead.
If you buying something big i suggest you find a trustworthy company.
Because i dont have a good experience Spec-D.
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
_gt86_user (02-21-2016)
Old 02-21-2016, 12:55 PM   #9
_gt86_user
Inactive
Drives: .
I worked at SpecD for like 5 years right around the time they released these lights at SEMA, honestly I'm just letting you know all the lights are shit.
The Following User Says Thank You to _gt86_user For This Useful Post:
Old 02-21-2016, 12:58 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Yep just like Winjets as well
Old 02-21-2016, 08:06 PM   #11
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I vote retrofit the stocks! And if you like the black look, just paint them.
MS, CSCS, TSAC-F, CPT
Old 02-22-2016, 09:33 PM   #12
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Yeah I'm not a lighting snob but it's pretty bad. I did a retrofit on motorcycles a while back with FX-R Projectors and those were so crisp and clean I was amazed, especially since it was my first projector install. Nowadays I compare lighting to those projectors or even OEM HID ones and they have a clean cut off line.
These Spec-Ds aren't good at all. Another member and I plan to install morimoto mini's in there when we open them up later on as TRS (The Retrofit Source) sells a projector kit aimed to replaced Spec-D headlights, like really, it says "For Spec-D" on the product page.
head lights, headlights, spec-d
From Gloss black to Matt Black, recomendations please Lunatic Cosmetic Modification (Interior/Exterior/Lighting) 27 10-23-2014 09:06 PM
Gloss black interior pieces (silver to black) Cruisincam Cosmetic Modification (Interior/Exterior/Lighting) 0 10-10-2014 10:31 PM
FS: Work Meister S1R Matte Black Face x Gloss Black Lips reggie@circuitsoul Wheels and Tires 2 12-29-2013 06:50 PM
ADVAN RSII 18x8.5 & 18x9.5 (Hyper black / Semi-Gloss Black) - in stock! Touge Factory Wheels and Tires 13 01-15-2013 07:43 PM
