| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#15 |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
I think the real answer to the question is emissions fuel economy regulations based on unrealistic testing conditions. To improve economy, you need a small, low reving engine with high compression that is capable of running very lean. Because you need some power while accellerating but not much at any other time, at least on the typical emissions or fuel economy test protocol, manufacturers are pushed towards turbocharging. Small turbos combined with high compression ratio, very high pressure direct injection and sophisticated and precise fuel control allow very good numbers to be achieved in the Euro cycle and US EPA tests. Real world economy is generally worse than in these "idealized" test scenarios, but the gap is much larger for modern turbocharged engines than for NA.
I suspect that is part of why Mazda has mostly resisted the turbocharged approach and focused on weight reduction combined with sky high compression with their Skyactive concept. TLDR: Manufacturers are forced by emissions and economy regulations to replace larger NA engines with smaller turbo engines with lots of low end boost.
Anything worth doing is worth doing twice...
| The Following User Says Thank You to Talus1 For This Useful Post: | mdm (02-21-2016) |
#16 |
Sarcastic SOB
Note: Most newer performance oriented brands have switched to smaller displacement (1.4L to 2.5L) turbocharged engines using small twin scroll turbines. From an emissions and fuel economy perspective, hitting peak torque down low (1600 to 2000 RPM) is ideal and will provide good acceleration. This combined with properly calculated gear ratios. Another strategy is switching from Otto cycle to Atkinson cycle or having the ability for the ECU to switch on the fly. Finally, variable valve lift , duration and ignition timing and sometines variable intake runner length.
The sweet spot for displacement seems to be 2 L with premium forced induction engines now.
| The Following User Says Thank You to wbradley For This Useful Post: | mdm (02-21-2016) |
#17 | |
Drives: '06 AM V8V Coupe
Variable intake runner length is also only able to do so much. The 2AR Camry engines already have it, and they're not much of a performance boost over the 2AZs. The LFA has 3 stage variable runners, but the low end torque is still lacking. 2L is the sweet spot in the US today, because fuel here is cheap enough that no one really cares about the savings that you would get from going down to the 1.3-1.5L range that's the norm in other countries. With the EPA standards going up quickly though, I think engines like the Hyundai 1.6 turbo and Ford 1.6 turbo are going to become more common. |
#18 |
Sarcastic SOB
^^ While most people realize the US is a big market, most global manufacturers design for a global market.
Toyota for one, has something like 10 different small displacement engines ready for or scheduled for production. Brands like Jaguar are using 2L turbo engines in their new models. Mazda 9, their flagship SUV has a "huge" 2.5 L turbo for a 7 passenger vehicle. Too bad gas is cheap in the US, it just makes their CO2 emisions that much worse.
#19 | |
Drives: 2016 FR-S
#20 | |
Cams are a reasonable solution to opening poppet valves. The only things that really matter are duration (can be fudged by moving the cam around) and lift, but there's no way to get more lift without more duration, because the faster you open the valve the more power it takes (you need a stronger spring to resist that force too) and the more stress there is on the valve. It only takes 2 or 3 profiles to get a reasonable approximation of the ideal profile for 95% of driving circumstances, which is what Honda figured out. Last edited by serialk11r; 02-22-2016 at 05:24 AM. |
| The Following User Says Thank You to serialk11r For This Useful Post: | Captain Snooze (02-22-2016) |
#21 | |
Drives: 14' firestorm
[ame="https://www.youtube.com/watch?v=f4p-55a3WV8"]Koenigsegg engine innovations - YouTube[/ame] |
#22 | |
Drives: 2005 Toyota Camry
Smaller turbos have smaller (turbine) wheels, thus they spool up faster. Given the same amount of mass (exhaust gases), a smaller wheel will spool up faster than a larger wheel. Kind of like a small garden hose versus a large mainline pipe. Given the same mass of water, the velocity coming out of the small hose is much faster. As for when a turbo is efficient, that depends on how the wheels are sized. Bigger and faster is not better... and much like most tuning and modding questions in general, the right answer for turbos depends on what questions you are asking and the context. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Captain Snooze (02-22-2016) |
#23 |
Because compromise ®
Drives: Red Herring
There's been a handful of cars with sequential turbos: Porsche 959, Mazda RX-7, Toyota Supra, Subaru Legacy.
#24 |
Sarcastic SOB
I think OP's question is how is it that turbos increase low RPM torque. Simple answer is small turbine spools up at lower RPM. The reason this design is widely used is to make useful power for acceleration whilst maintaining low fuel consumption.
| The Following User Says Thank You to wbradley For This Useful Post: | mdm (02-22-2016) |
| AVO turbo kit - 401whp, 314ft/lbs of torque | AVOturboworld | Forced Induction | 38 | 10-29-2018 07:46 PM |
| Improving at Buttonwillow with 86 Cup - shaving a second off my personal best | mav1178 | Tracking / Autocross / HPDE / Drifting | 0 | 06-30-2015 01:03 PM |
| A discussion on improving ride quality | RYU | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 305 | 06-10-2015 07:55 AM |
| Improving Steering Feel | sittinSideways | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 08-18-2014 07:52 PM |
| FBM Premium Turbo w/SSP High Stall Torque Converter and Racing Valve Body | DeOppressorLiber | Forced Induction | 11 | 04-15-2014 12:59 AM |
