Old 02-17-2016, 11:36 AM   #15
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Looking at the picture again while I sipped my coffee this morning....
It looks like my coffee
Instagram: trevor.parque
go_a_way1 (02-17-2016)
Old 02-17-2016, 11:56 AM   #16
Nickosport
Drives: 2015 WRB BRZ Premium
Originally Posted by ハチロク View Post
This sounds like bad news... What should I do about it?
Is the trans acting funny? How many miles are on the car? Still under warranty?
If you still have a warranty I would take a sample of that oil and send it to blackstone, see what they come back with. Then take that and the car to the dealer and have them document it/diagnose it. At the minimum have them document the problem so that if you have an issue when the warranty expires you still have a leg to stand on. Its going to be hard because the dealer is going to want to see and drain the oil themselves.
If its out of warranty and the car is still shifting OK, I would refill it with new fluid and let it ride until it shits. Maybe start looking for a new trans once you start having issues.
Regardless, monitor the color of the fluid. I don't know how to tell you to do it, because its not like there is a dipstick, and you want to avoid draining the fluid to check the color. You need to find a way to get a sample without draining, probably through the fill plug. Maybe a syringe and a hose? You only need enough to see the color.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 02-17-2016, 01:32 PM   #17
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I'd personally drain and refill it. Drive a bit (like 10 miles), then drain and refill it again. Then drive some more, then TAKE IT TO SUBARU, and have them drain and refill it. I changed mine 3 times before it started coming out clear.
That way if this same issue happens again, they are the last people to have touched it, which might help.
Stang70Fastback is offline   Reply With Quote
Old 02-17-2016, 02:11 PM   #18
_gt86_user
Inactive
Drives: .
Yeah had that same looking fluid in another car after I drove through a portion of flooded streets, I've found the best way to just check your fluid is to use a 1ml or 10ml syringe and just suck some out to check and put back in if its good. 1ml is usually small and skinny enough to get in almost any transmission without draining.
_gt86_user is offline   Reply With Quote
Old 02-17-2016, 02:18 PM   #19
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This is motul 300 manual transmission fluid after about 25k miles.
Are you sure you didn't barrel through a large puddle or partially flooded street?
Old 02-17-2016, 02:21 PM   #20
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
I mean I've driven over puddles. This is a daily driver. but nothing I would consider excessive.
ハチロク is offline   Reply With Quote
Old 02-17-2016, 03:44 PM   #21
Ultramaroon
fabulous
Ultramaroon's Avatar
I bet it's like @stevesnj said. I'd take a look at your vent/check valve to see if it isn't stuck open. The spring is super light.
Old 02-17-2016, 04:17 PM   #22
ハチロク
ハチロク's Avatar
Where is that vent/ check valve?
Old 02-17-2016, 05:06 PM   #23
Ultramaroon
fabulous
It's the part right above the blue switch in this photo. You can reach it from underneath the car and wiggle it.
ハチロク (02-17-2016), Bonburner (02-26-2016)
Old 02-17-2016, 05:29 PM   #24
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Sorry to be off topic and jack OP's thread.
Just want to know, is there such a valve at the diff as well?
Brzerker is offline   Reply With Quote
Old 02-17-2016, 08:55 PM   #25
stevesnj
stevesnj's Avatar
Yep
My 2016 Build thread
Old 02-26-2016, 11:13 AM   #26
ハチロク
ハチロク's Avatar
UPDATE:
I brought my car in to toyota for service to have them look at the car. I brought in the drain fluid. they said there wasn't anything to worry about. "some metal flakes is normal after this many miles". They also said they didn't know what I was talking about when I said it looked "milky". Apparently it looks a lot more transparent when the fluid is warm. They poured some of it out and it looked a lot different from when I took the picture.
The Following User Says Thank You to ハチロク For This Useful Post:
Nickosport (02-26-2016)
Old 02-26-2016, 12:53 PM   #27
Ultramaroon
fabulous
So that wasn't water? Wow. Both dust and water would have eventually settled out of suspension. Perhaps that's why it looked so different when they poured from your sample. I take it they didn't see your photo.
Thanks very much for following up here.
Old 02-26-2016, 06:45 PM   #28
Celica00
Celica00's Avatar
Drives: 86
Wow they sound a lot more helpful and informative than what I've experienced from dealer mechanics.
Celica00 is offline   Reply With Quote
Is this normal? scottxnizzle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-10-2015 01:26 PM
Is this normal in the OFT?? benlaz88 Software Tuning 4 12-04-2014 10:23 PM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 04:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 03:54 AM
