Old 02-15-2016, 07:15 PM   #15
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
Originally Posted by Spartarus View Post
*Looks at username* ...We want to hear the story of this front-end accident. With pics.
Then we will help you fix it.
The pictures will help in that endeavor.
Need to see the throttle body and intake manifold before I can help with the actuator and min stop code.
If the throttle body motor isn't working properly, the car will not start or idle. It's a drive-by-wire throttle.
Honestly I don't see why there is a need to judge me based on my user name. I got in to a simple front end crash that's all. It turns out I had something stuck in the throttle body. I will investigate further and see where it leads to. Thanks for the help anyways.
Sent from my ONE A2005 using Tapatalk
driftking96 is offline   Reply With Quote
Old 02-15-2016, 07:17 PM   #16
driftking96
Originally Posted by kev60625 View Post
Leaves that out as if it doesn't matter
Lol sorry guys my stupidity. Obviously I should have mentioned something that serious and I didn't. I'm really sorry.
The Following User Says Thank You to driftking96 For This Useful Post:
Ultramaroon (02-15-2016)
Old 02-15-2016, 07:20 PM   #17
Ultramaroon
fabulous
Ultramaroon's Avatar
Lessons learned. No worries. It's big of you to own it so you're a good guy in my book.
Best of luck getting it fixed up.
PandaSPUR (02-15-2016)
Old 02-15-2016, 08:55 PM   #18
driftking96
Is the throttle body valve opening/plate/cover supposed to be slightly slanted?
Old 02-15-2016, 09:06 PM   #19
Ultramaroon
fabulous
yes, just a tad and it should not stick. If you turn on the ignition, you should hear the servo buzz and you should hear it operate as you work the throttle pedal.
Old 02-15-2016, 10:06 PM   #20
driftking96
Is the servo supposed to buzz continuously when you turn on ignition? I can move it when I press the gas pedal. I tried starting the car but alas I couldn't get it to start. Still same issue as before. It cranks but doesn't run. This time I had a friend start it and when he did, right before the car died it made this loud pop which I have heard before. Except I saw a quick burst of blue flames. Not sure if that's good or bad. The flames came out of the throttle body. Any idea why?
EDIT: I didnt see the flames before because the throttle body was covered.
Old 02-15-2016, 10:30 PM   #21
driftking96
Holy shit did my stock engine just backfire? I just researched and found out that incomplete combustion can also occur through the manifold, previously I thought it was only through the exhaust? I have uploaded a video of my car starting up and at around 20 seconds you can see another really small and quick backfire with a little bit of flames, if I'm not wrong.
EDIT: Video attached inside compressed ZIP file and uploaded on vid.me
https://vid.me/GUFD
File Type: zip Engine backfiring through Throttlebody.zip (2.38 MB, 86 views)
Old 02-15-2016, 11:44 PM   #22
Ultramaroon
fabulous
Yes it will buzz all the time. Typical backfire. I suggest reinstalling everything upstream of the throttle body. Don't leave any holes. The MAF sensor is a critical component.
Maybe you were fiddling with the throttle while you were cranking it? That's a no-no.
edit: ok, saw the vid. I think once you put everything back on, it will run just fine.
Old 02-15-2016, 11:57 PM   #23
driftking96
Okay now only issue is that I'm learning how to do all this so I'm not exactly sure what is upstream of the throttle? Would you please be kind enough to either tell me or refer me to a source so I can figure out what I have that is broken/missing that I need to replace? MAF is Mass Air Flow sensor and I'm pretty sure I found it but it may be broken. I will be attaching pictures of it below as soon as I get on a computer so I can downsize the images to fit the attachment requirements on the forum. I also have the oem intake which I will upload as well.
Old 02-16-2016, 12:01 AM   #24
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
http://parts.subaru.com/a/Subaru_201...10-070-02.html
Check that link. The parts diagram for the intake area is up top and it has corresponding part numbers/links so you can buy replacements.
EDIT: And this one, more up close diagram of the intake including the MAF:
http://parts.subaru.com/a/Subaru_201...10-070-01.html
Throttle area:
http://parts.subaru.com/a/Subaru_201...10-063-01.html
PandaSPUR is offline   Reply With Quote
The Following 3 Users Say Thank You to PandaSPUR For This Useful Post:
driftking96 (02-16-2016), new2subaru (02-19-2016), Ultramaroon (02-16-2016)
Old 02-16-2016, 09:39 AM   #25
jdubious
Drives: 13 Scion FR-S
If plastic bits get past the throttle plate it could potentially interfere with the valve train. I've seen this bend valves and cause a no start condition on a VW. I would do a compression test if possible.
jdubious is offline   Reply With Quote
Old 02-16-2016, 09:43 AM   #26
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Didn't mean to come off as judgemental. Meant it as a lighthearted joke.
Always happy to help.
I'll keep following and throw in any more help I can.
Inline 4 is best 4
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Old 02-16-2016, 11:34 AM   #27
driftking96
Is a compression test the only way I can check if the valve train hasn't been compromised by plastic pieces? How exactly do you get a compression test and where do you do it?
Old 02-16-2016, 11:38 AM   #28
driftking96
Lol its all good. It's hard to say anything on the internet when there's no option to add in your tone or attitude which is why jokes work best in person I guess. Idk. Body language isn't something the internet has understood yet. Regardless, thank you.
cel, engine, stalls
Car will not starts at all Tomahawk Issues | Warranty | Recalls / TSB 74 02-06-2016 08:32 PM
Do e85 cold starts damage engine? jaorocks1 Engine, Exhaust, Transmission 20 12-02-2015 06:12 AM
Strange beep sound from engine on starts fanaticalz Issues | Warranty | Recalls / TSB 5 05-19-2015 02:10 AM
jerky starts goshem BRZ First-Gen (2012+) -- General Topics 14 01-20-2014 12:21 AM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 03:09 PM
