Old 02-09-2016, 05:56 PM   #1
soilent
Drives: 2022 BRZ Premium
I have sort of a weird picture request if someone could fulfill it. LED turn signals
I'm looking into getting some LED turn signals for the front of my BRZ and I was curious what an LED bulb with a black housing would look like in the reflector while OFF. If anyone has a setup like this and has a picture, please post it. I'm curious to see if it makes the inside of the headlight look darker. Thanks.
P.S. This is what I mean by bulb with black housing just FYI.http://www.ebay.com/itm/1x-Resistor-...lVUV7-&vxp=mtr
soilent is offline   Reply With Quote
Old 02-09-2016, 06:11 PM   #2
ryoma
ryoma's Avatar
my setup is the opposite of what you want to get lol. the chrome trim on the LED bulb would probably go pretty well in a stock reflector... but black might look out of place. I should probably get some black bulbs lol
Old 02-09-2016, 06:11 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
looked........why would black plastic make ur headlight look darker?......
Old 02-09-2016, 06:16 PM   #4
ryoma
ryoma's Avatar
he means that since the turn signal housing is reflective, it might reflect the black color of the LED bulb when it's off during the day and make it seem sort of tinted. however, if you really wanted the inside blacked out, it's best to just crack open the lights and paint it lol
Old 02-09-2016, 10:04 PM   #5
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
For reference, LED bulbs in a stock (non-painted housing)
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 02-09-2016, 10:21 PM   #6
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Do you have photo and video of the turn signal on?
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 02-09-2016, 11:21 PM   #7
ryoma
ryoma's Avatar
no, but it is still the same amber as the original bulbs. the LED's I got were from Diode Dynamics and it was their brightest turn signal one
Old 02-09-2016, 11:36 PM   #8
STZ
Drives: '15 WRB BRZ Sport-tech
I was thinking of doing this when I get mine. Did you have to do anything to fix the rate of the blinking or was it completely plug and play?
Which LED bulbs are those?
STZ is offline   Reply With Quote
Old 02-10-2016, 12:25 AM   #9
ryoma
ryoma's Avatar
you will need to get an LED flasher relay otherwise it will hyper blink. I had installed the relay prior when I got my Tom's tail lights so I didn't need to do anything special.
The Following User Says Thank You to ryoma For This Useful Post:
STZ (02-10-2016)
Old 02-10-2016, 01:42 AM   #10
extrashaky
Drives: 2014 BRZ Limited
I don't know if DD's kit is like this, but some of the LED kits come with resistors you solder in to prevent the hyper blink, or you can just buy the resistors on ebay. However, you don't need the resistors if you instead replace your blinker relay with one made for LEDs (like the relays that come with LED tails as ryoma mentioned). Personally, I think this is a much cleaner solution, since it takes care of all your blinkers with one unit plugged in under the dash rather than having you hack up the wiring at each corner.
I run a TapTurn in mine, which has given me zero issues with front and rear LEDs and also has the advantage of weird hazard lights that get the attention of tailgaters and sometimes make them back off.
The Following User Says Thank You to extrashaky For This Useful Post:
STZ (02-10-2016)
Old 02-10-2016, 01:48 AM   #11
STZ
Would normal halogen blinkers work in the front if I got tom's and put the relay on to prevent the hyperblink in the rear?
Also, which bulbs did you decide to go with. You forgot to answer in the last post :p
Old 02-10-2016, 01:56 AM   #12
extrashaky
Yes. I ran mine like that for over a year before finally replacing the stock bulbs with LEDs (I don't recall the make off the top of my head--a member here had them for sale). The only difference is that if one of your front blinkers goes out, the relay doesn't hyberblink to let you know.
Old 02-10-2016, 02:07 AM   #13
ryoma
ryoma's Avatar
I got the HP11's. it's $60 for a pair from Diode Dynamics, so not really that cheap haha.
Old 02-10-2016, 08:40 AM   #14
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
I've done this on mine - ordered the LEDs from DiodeDynamics. They have an ugly yellow base, so I wrapped that with black electrical tape before installing. Gives the headlights a nice monochromatic finish, in my opinion. You can sort of see that in the attached pic below.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Picture Request Mr Kirmudget BRZ Photos, Videos, Wallpapers, Gallery Forum 0 08-08-2013 12:42 AM
Request - 5000k LED Switchback Turn Signals raul Cosmetic Modification (Interior/Exterior/Lighting) 8 03-07-2013 06:50 PM
Picture Request koyv90 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 02-03-2013 05:03 AM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
