86WORX
Doborder, orthojoe
Old 03-16-2013, 10:43 AM   #57
FR-S Matt
Used this DIY just the other day for my Axleback install. Harbor Freight jack stands and a 2.5 ton Harbor Freight low profile jack. Worked like a charm.
Old 03-24-2013, 03:23 PM   #58
aaronosaurus
The data matters
Drives: WRBP BRZ
After jacking the car up from that front jack point, I set it back down onto the jackstands. How far did your car settle between the pinch welds and the 2x4 coming off of the crossmember? Mine went 2-3 inches; I'm guessing thats from the load coming off of the rear suspension. Anyone else have this issue? I hope I'm not bending the chassi with the motor than far forward of the jack points.
aaronosaurus is offline   Reply With Quote
Old 07-16-2013, 12:59 PM   #59
DarkestBuddha
Drives: BRZ limited GBS
is it alright to use jackstands that arent notched so deep?
like these
DarkestBuddha is offline   Reply With Quote
Old 07-16-2013, 01:04 PM   #60
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
like these
Should be fine, if anything I'd say make sure its right in the center of the groove, I use their 3 tons and they have that little area that concave in for our jacking points.
Old 07-18-2013, 01:50 PM   #61
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Porsche View Post
The BRZ is by far the easiest car to elevate ever. So long as one has a jack that can reach the central jack points.
Actually, any car that is front engine, rear wheel drive with sufficient ground clearance (i.e. no supercars) is just as easy, if not easier. You either lift on the front "jack point" or engine crossmember, or the rear diff/subframe.
I owned a S13 for many years and that car was even easier to lift.
-alex
Old 10-20-2013, 06:03 AM   #62
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Due to blatant carelessness, I did not place the jack correctly and managed to bend the edges of the side pinch weld point. The paint also chipped off and has exposed the bare metal.
What do you recommend to do to prevent rust? I know I can just get some touch up paint, but what would be the proper procedure to follow instead of just applying touch up paint?
Fizz is offline   Reply With Quote
Old 10-21-2013, 08:34 PM   #63
FRSEEYA
FRSEEYA's Avatar
I like to use a piece of soft wood when using the rear differential as a jack point as well. Suprised to see you didn't do that but then again I guess our cars are much lighter than an 02' mustang.
FRSEEYA is offline   Reply With Quote
Old 02-03-2014, 12:44 PM   #64
Selvedge
@GrimmSpeed Could you please relink the images? Thanks!
Selvedge is offline   Reply With Quote
Old 02-08-2014, 10:10 AM   #65
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
@GrimmSpeed This. Please!
flashburn is offline   Reply With Quote
Old 02-08-2014, 09:12 PM   #66
710IL
+1
710IL is offline   Reply With Quote
Old 02-10-2014, 01:10 PM   #67
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
I'm looking into it right now (all of our DIY links seem to be broken again, old server problems unfortunately).
Chase
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
chrisp1992 (02-10-2014)
Old 02-10-2014, 04:07 PM   #68
710IL
Chase
I know I'm a new face here, but I'm an old nasioc iwsti guy, and a computer engineer with a web server and a love for this car that I finally bought. Send me the source material, and I'll get a mirror up a sap with appropriate credit and links to GS.
Also, I am doing full fluid change this weekend and have yet to stick my floor jack or stands under this car...
Sent from my SCH-I545 using Tapatalk
The Following 2 Users Say Thank You to 710IL For This Useful Post:
chrisp1992 (02-10-2014), nzer (02-10-2014)
Old 02-10-2014, 06:35 PM   #69
GrimmSpeed
GrimmSpeed's Avatar
Hey thank you very much we appreciate that! Instead we just hosted them on our current server, and we don't expect to have a problem with it again. I went through and fixed all the broken pictures on our DIYs as well
Chase
Engineering
The Following 5 Users Say Thank You to GrimmSpeed For This Useful Post:
chrisp1992 (02-18-2014), nzer (02-10-2014), Selvedge (02-13-2014), SirBrass (04-13-2014), Slipstream (02-16-2014)
Old 02-16-2014, 11:25 PM   #70
710IL
Wanted to report that I just used the Torin alu 3 ton hex base flat top jack stands, with 3 layers of 3/8" clear tubing sliced in half and stacked like 3 buns with the pinch weld being the hotdog. Can't even tell the car was in the air
I used the HF 68050 and had no clearance issues at all. However, that jack has the worst release valve I have used in a very long time...it will not be a permanent fixture in my garage for long I suspect.
Now to drive this car full of motul and royal purple... that OEM garbage was hideous in the shifting.
Search this Thread:
Advanced Search
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) -- General Topics 2 06-27-2012 09:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 06:19 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 06:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 09:07 AM
