#15 | |
dont reuse exhaust gaskets, they will leak after a while. they are designed to crush to shape and can only be used once |
| The Following User Says Thank You to steve99 For This Useful Post: | ShadowReaper (03-10-2016) |
#16 |
Fteightysix.com sells the oems cheap. Or villagescion.com
#17 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
The dealership already has some in the way. Might as well stick around for that, as it will be quicker.
Instagram: 86_Maul |
#18 | |
Drives: WRB Limited MT6
![]() I filmed it with my phone and an old go pro, so the sound isn't the best lol [ame="https://www.youtube.com/watch?v=uKJmcTFBi1o"]Subaru BRZ UEL Dezod Exhaust - YouTube[/ame] |
#19 | |
![]() Yep, your car sounds like it's on a track ...... humfrz |
#20 |
insta: f_de_pinho9
Drives: Toyota GT86 Std
Hey, Cholofrom sorry about this but im also new to exhausts.. when you get a exhaust do you need a tune for it to run properly?
#21 |
#22 |
Drives: Asphalt 2015 FRS
Can you elaborate a bit more on this? I understand that without a tune, it will most likely throw a CEL. And I know that a tune will make the most out of the header. But you can still put one on and not tune it, right? I'm in this situation and as long as no damage will come of it, the tune is coming a little further down the road.
#23 |
Drives: GT86
Essentially there are two sensors in the manifold (headers) that look for differences in the exhaust gasses before and after the cat in the manifold. When you go with a decat manifold the sensors don't read the differences they are expecting and the engine will throw up a CEL. don't worry, no damage will be done, no limp home mode or power drop, all that happens is the cruise control will be disabled.
The stock map on the ECU was designed with the catted factory manifold in mind, including accounting for the restriction of the cat etc etc. The freer flowing exhaust allows a modified and better mix to be combusted, but the ECU needs to be told this through an aftermarket tune. Basically, without a map the engine can breathe better but the ECU doesn't know how to make the most of it. With a map, the ECU is given parameters to capitalise on a freer exhaust. As for the catback, this system is installed after all the factory sensors so will have no effect on what the ECU sees. A small gain may be had from it however, due to the fact that again the aftermarket component will tend to be freer flowing and allow better passage of exhaust gas. |
| The Following User Says Thank You to secret.squirrel For This Useful Post: | Haeb (03-18-2016) |
#24 | |
If your going to start engine mods suggest you read Basic Bolt on Mods guide below |
#25 | |
Someone once told me off the forums some theory about changing the header without a tune messes with cylinder temps/firing or something like that. Just looking for confirmation that my motor won't blow up which I don't think it would.. |
#26 | |
#27 | |
the fueling and timing is uneffected by header ie the ecu will run same timing and fueling it ran before header, the ecu will adjust fuel trims itself so it runs the same fueling even if header flows better. the main thing tune does is adjust the intake and exhaust valve timing to take advantage of the better gass flow of the header and they will also adjust many other parameters. no it wont blow up :-), you just miss out on a lot of the possible gains intakes can upset ecu much more than headers |
| The Following User Says Thank You to steve99 For This Useful Post: | Teseo (03-20-2016) |
#28 | |
| ROOKIE QUESTION TPMS!! | brz23 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 03-01-2015 07:05 PM |
| Help out a rookie? | Outride | Forced Induction | 37 | 02-04-2015 02:04 PM |
| BRZ holds its own in Auto-X with rookie driver | mtimney | Tracking / Autocross / HPDE / Drifting | 4 | 08-11-2013 01:24 PM |
| Adventures of a rookie in Autocross | djfuller | Tracking / Autocross / HPDE / Drifting | 9 | 04-01-2013 10:30 PM |
