86WORX
Old 02-14-2020, 04:46 AM   #71
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exhaust manifold of GRMN86 is catless, but not that much different from the upgraded OEM manifold. You can think of it as a catless version of the OEM.
Intake manifold is another story, but not much information about. All they were saying was that it was too expensive to install it to the factory car.
Old 02-14-2020, 05:07 AM   #72
tomm.brz
Drives: brz 2017 hksv2
jp car parts also list those parts as out of production and yes, the price was incredibly high
Old 02-14-2020, 05:27 AM   #73
ck20090418
Drives: gt86
the cost bonnet is incredibly high
ck20090418 is offline   Reply With Quote
Old 02-14-2020, 05:33 AM   #74
ck20090418
Drives: gt86
the intake manifold is a headache. and i m planning getting those parts.
but it require a bunch of modification to get it run right.
it using vacuum to activate, it also have sensor which connect to a different wiring to the engine loom and i believe only grmn 86 using that engine wiring.
Old 02-14-2020, 05:33 AM   #75
ck20090418
Drives: gt86
i only have the front lip, side skirt and the rear spoiler atm
Old 02-14-2020, 05:35 AM   #76
ck20090418
Drives: gt86
and actually the cost for the intake manifold itself is just slight high than the kouki red intake manifold. and it just require a lot of work to make it run right
Old 02-14-2020, 05:37 AM   #77
ck20090418
Drives: gt86
i have try out jpcarparts, most of them are not shipping to oversea since grmn is a special model
Old 02-14-2020, 06:19 AM   #78
tomm.brz
they do ship, but those parts are out of production.
The GRMN86 tune has no change in cam intake/exhaust timings, so that intake manifold do not require anything special to make it work, it'd just work good as soon as you'd plug it in
Old 02-15-2020, 03:43 AM   #79
ck20090418
Drives: gt86
82219-18010. there is extra wiring that only use in grmn for the sensor
Old 07-10-2020, 03:25 AM   #80
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
GRMN86 differential
The Following User Says Thank You to nikitopo For This Useful Post:
DarkPira7e (07-10-2020)
Old 07-14-2020, 05:48 PM   #81
gpvecchi
gpvecchi's Avatar
If I'm not wrong it's a different ratio Torsen with 4.3 FD, right?
gpvecchi is offline   Reply With Quote
Old 07-14-2020, 07:06 PM   #82
TylerLieberman
TylerLieberman's Avatar
Drives: '20 Hakone 86
That’s my understanding too. Gotta say I’m a little puzzled why somebody would spend the time and money to specifically track down a GRMN diff when the 17+ cars utilize the same gearing.
TylerLieberman is offline   Reply With Quote
Old 07-15-2020, 02:51 AM   #83
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes, it is with 4.3 FD ratio. Compared to standard TORSEN LSD, lock rate is over 133% when accelerator is stepped on and over 124% when released.
Compared to a multi plate type LSD, smooth and responsive performance of the TORSEN traction is kept. Additionally, it doesn't require any maintenance apart from the usual oil change.
Old 07-15-2020, 03:52 AM   #84
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This was a build to order factory part. Meaning that Toyota Japan took a standard 17+ differential (4.3 FD ratio) and opened it to change the Torsen with the improved one.
Other parts like the GRMN intake manifold are discontinued, so it is much harder to find them.
frs, grmn, gt86, st-autosport, toyota
GRMN 86 unveiled nikitopo Scion FR-S / Toyota 86 GT86 General Forum 103 07-22-2020 04:38 AM
What kind of wheels are these on the GRMN 86 Prototype? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-10-2018 09:23 AM
New article on the GRMN 86 (Tuned race ready spec) Wise Scion FR-S / Toyota 86 GT86 General Forum 15 02-16-2015 11:13 PM
GRMN SPORTS FR Concept PLATINUM PREDATOR786 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 01-21-2013 11:47 PM
GRMN 70NYD Scion FR-S / Toyota 86 GT86 General Forum 17 01-23-2011 04:29 AM
