Old 06-30-2016, 03:33 PM   #29
mabviper
Drives: WRB BRZ
@justatroll I'm using a trick that ppl have used in the past when it comes to data software analysis. I save my files in CSV format. I then run it through a converter to adapt it to AEMData's format for analysis. AEM doesn't have a way to import CSV data. However, I only really use AEMData if I want to get nice graphs and more in-depth analysis. I usually just use Dashware for most of my analysis because it integrates video so much easier than AEMData w/o loosing too much of the functionality. I created a Dashware template and gauge to read my data w/o too much setup from the user.
I was also playing around with expandability through other peripherals like your board or the TC-4 thermocouple unit. I've worked with the TC-4 before in FSAE so it shouldn't be too hard. Writing a driver for your board shouldn't be a problem either. I'm still waiting on the components to get this finally on a board then I need to port all the code over ^^.
@Mazikowski Thanks for the vote of confidence ^^. This is also the heart of my canbus projects. I have a few things that I want to interface to this including my Raspberry Pi dashcam and my N7. The Pi dashcam needs to be upgraded with their new Sony sensory ^^.
mabviper is offline   Reply With Quote
Old 06-30-2016, 03:56 PM   #30
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
@mabviper
Just in case you were interested, here is a screen shot of my java applet that extracts data from a CSV and displays it:
When you run it it asks for the *.csv file of interest.
It then searches it for all contiguous datsets, then displays the list of datasets for the user to choose.
Once you choose a dataset, it opens these graphs.
If one were to have any java experience it would be very easy to customize.
justatroll is offline   Reply With Quote
Old 07-02-2016, 11:48 PM   #31
redlined600
redlined600's Avatar
Drives: Fr-s
I skimmed a bit, but to be clear the car broadcast brake pressure over can?
Cool project!
Old 07-03-2016, 12:32 AM   #32
mabviper
Drives: WRB BRZ
Yup, there's brakes pressure in the bus which looks like in bar but I'm not sure if it's accurate since i have no way of installing a separate sensor to calibrate the readings. I'm almost sure it's in bar though.
Sent from my Nexus 4 using Tapatalk
The Following User Says Thank You to mabviper For This Useful Post:
redlined600 (07-03-2016)
Old 07-03-2016, 01:14 AM   #33
mabviper
Drives: WRB BRZ
@justatroll ah that's pretty cool. That applet would probably work with my csv data as well. I don't work too much with the front end so I ended up using available options.
justatroll (07-13-2016)
Old 07-03-2016, 04:53 AM   #34
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Good stuff!
Intent > Content
Old 07-13-2016, 07:37 PM   #35
mabviper
Drives: WRB BRZ
After waiting almost 2 months for chips, I finally received both my GPS and wifi chips! I'm still waiting on the micro but if I get real impatient, I'll just express it from digikey... along with the other support components.
Also, I'm working on predictive lap timing as well. I still have to try that one out. ^^
ZZT86 (07-14-2016)
Old 07-25-2016, 04:10 AM   #36
mabviper
Drives: WRB BRZ
Updated the first post indicating that accelerometer and yaw data working in video.
Old 07-25-2016, 12:08 PM   #37
Rameus
Drives: 2015 FR-S
I'm extremely impressed! Like I said on Saturday (I was the mechie who came by in the morning), you're incorporating all the features I've been dreaming of.
As if you didn't have enough offers already, I'd be happy to help test whenever you need it (or even design/build, if there's anything I can do).
Rameus is offline   Reply With Quote
Old 08-26-2016, 09:49 PM   #38
mabviper
Drives: WRB BRZ
So I've been quiet for a while due to busy work schedule but I did have some time to update the data logger.
Enjoy!
The Following 3 Users Say Thank You to mabviper For This Useful Post:
D18 (09-06-2016), Mazikowski (08-26-2016), Sideways (08-28-2016)
Old 09-25-2016, 08:57 PM   #39
duqx
Drives: 15' FR-S, 02' 911
That looks really nice set into that panel. Any more updates?
duqx is offline   Reply With Quote
Old 09-25-2016, 10:21 PM   #40
mabviper
Drives: WRB BRZ
I'm glad that you like it. I don't have an update on the fitment in the console just yet. I've been testing it for the past few weeks on track. There are some road blocks that are preventing me from installing it at this time. 1, the signals from the car, ie airbag on/off, haven't been completely tested yet. 2. The stock car pins were shifted slightly on my board so it's not plug and play. 3. I haven't gotten the wifi to work just yet so getting the data out is quite tedious (removing micro sd card from the back).
Having said that, I need to revise the board but hopefully will have a few prototypes up and running. Also, once I'm completely happy with it, it'll open source the software.
For now, here's one of my sessions in CTMP DDT this past September.
[ame="https://www.youtube.com/watch?v=V6LQ6FVQGkM"]SPDA Sept 10 2016 - YouTube[/ame]
Old 10-24-2016, 04:45 PM   #41
CNGAOX
CNGAOX's Avatar
Finished? Looking forward to
CNGAOX is offline   Reply With Quote
Old 03-07-2017, 07:12 AM   #42
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
@mabviper have you made any progress over this winter?
BatStig is offline   Reply With Quote
Data Logger choices : Aim MXL2 - MXS - MXG philooo Tracking / Autocross / HPDE / Drifting 10 01-05-2023 10:48 AM
FS: Racelogic PerformanceBox Data Logger ft86Fan Miscellaneous 0 09-07-2015 06:26 PM
iPhone track data logger app? Wonderbar Tracking / Autocross / HPDE / Drifting 14 05-07-2013 04:31 PM
Solo Specific Data Logger.. VERY COOL Scooby South Tracking / Autocross / HPDE / Drifting 10 04-29-2013 11:54 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
