#29 | ||
| The Following User Says Thank You to CSG David For This Useful Post: | Rapiddan45 (01-22-2016) |
#30 |
Drives: Subaru BRZ
Interested in thr torque and HP curves comparison as well .
#31 |
That Guy
Drives: 2013 asphalt FRS MT
What's the pulley size for the C30 kit, the C38 kit, and the HBP?
What's the maximum compressor RPM for the C38? And what is the maximum compressor RPM of the C38 kit while using the JRSC C38 kit's supplied pulley and running the engine at 7400 RPM? Does the C38 kit effect the power curve vs the C30 kit? Does the C38 kit use the same MAF housing as the C30 kit? Why the drastic change in attitude? Before this CSG representatives have stated that the C38 would be too much for a stock engine. Now here is another kit that claims the C38 will be fine on 91 octane. |
| The Following 5 Users Say Thank You to Calum For This Useful Post: | -Phil (01-25-2016), Apoc (01-25-2016), byun (01-25-2016), Freeman (01-25-2016), Scottemad123 (01-25-2016) |
#32 | |
- 90,000 RPM maximum, 70,636 RPM at redline with 110mm pulley - Same power curve in CARB trim. - Yes, same MAF - I think we can all agree that pushing 15+ psi of boost is too much for a stock engine. At 9 psi, the stock engine is fine, regardless of compressor size. It took nearly 3 years of testing to get here with the C38. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#33 | |
Driving Coach
#34 | |
That Guy
#35 |
It's not spinning at the same speed. The gear ratio of the c30-94 is a 9.49 multiplier, while the C38-81 is 7.50. The difference in compressor efficiency is small enough that it falls under the error range of most dynos.
#36 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
I'm probably oversimplifying this, but basically theres no difference between the two kits until theres a pulley even smaller than the HBP?
I'm understanding it as, the bigger compressor will push more air, but due to the different gear ratios, will spin slower than the smaller compressor (while making the same boost). The benefit comes when an even smaller pulley is used to push the C38 to even higher RPMs, and this same smaller pulley would be unusable on the C30 because it would cause it to spin faster than it can handle. |
#37 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
#38 |
Drives: 2013 FR-S M/T Ultramarine
Sure did! And gotta hand it to Jackson racing, their packaging is superb. Got a good portion done tonight, hoping to have everything finished in the next few days.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
#39 | |
#40 |
Should we take that as a nod to a new high boost pulley being in development, given that you mentioned "current HBP"...?
Sent from my SM-G925T using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#41 |
#42 |
my C38 blower Showed up today hope to have it together in the next day or so.
| The Following User Says Thank You to Jmonty For This Useful Post: | CSG Mike (01-26-2016) |
| FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal | spitz | Cars for Sale/Trade | 3 | 02-05-2016 12:59 AM |
| Jackson Racing CARB supercharger+oil cooler LA | blahblah | Engine, Exhaust, Bolt-Ons | 9 | 12-30-2015 01:33 AM |
| (SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA | *LongFella | Cars for Sale/Trade | 27 | 04-11-2015 01:35 PM |
| Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? | Yui-Chan | Forced Induction | 179 | 03-04-2015 08:50 PM |
