Old 05-02-2018, 01:40 PM   #225
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
I happened upon a One Take where Matt Farah was testing an AT with the JRSC. He mentioned that he felt the SC maintaining boost after throttle release for ~1.5". Is this a known behavior? If so, has it since been resolved?
mistople is offline   Reply With Quote
Old 05-02-2018, 02:01 PM   #226
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
He isn't the most knowledgable person and often blabs incorrect stuff. It is not a issue.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
weederr33 (05-02-2018)
Old 05-02-2018, 02:33 PM   #227
Originally Posted by Rederick View Post
Any reason this kit wont work on the 2017s? Also if the user has their own ECUTEK cable and license, is it possible to get just a tune sent for the CA 50 state?
Just charge pipe fitment on the 86 bumper; the existing kits fit on a 2017 BRZ.
PM me to order.
Old 05-02-2018, 05:23 PM   #228
mrg666
pessimistic skeptic
mrg666's Avatar
That can happen if the bypass valve is damaged, leaking vacuum. With a working bypass valve boost is recirculated as soon throttle is released. A broken bypass valve can damage the compressor because of surge.
Old 05-02-2018, 07:21 PM   #229
SoCalArgento
Drives: 2014 Argento FRS
Sort of an out of the ordinary question, are quick intermittent voltage drops expected when on throttle with the C38 SC?
SoCalArgento is offline   Reply With Quote
Old 05-02-2018, 10:28 PM   #230
No. Sounds like you may have other electrical gremlins.
Old 05-03-2018, 12:51 AM   #231
SoCalArgento
Really? I would of thought since the the SC takes some parasitic loss from all the pulleys like the alternator, however insignificant it may be.
The volt drops are very quick and minimal during 1/4 throttle or so, dropping from ~14.4v to between 13.8 and no less than 12.8v or so then as soon as off throttle they immediately shoot back up.
Old 06-09-2018, 04:08 AM   #232
valtore101
Drives: 2016 FR-S
That's what's supposed to happen. Electrical systems in cars are designed for 12V. As long as you're not under that you're fine. Any basic electrical system will drop voltage when it is put under load unless corrected by the supply.
Even if the alternator has "minimal parasitic loss" the battery still provides voltage to the car.
valtore101 is offline   Reply With Quote
Search this Thread:
Advanced Search
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-05-2016 12:59 AM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 01:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 01:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 08:50 PM
