#99 | ||
The Stig's German cousin
And you're wrong - this isn't a matter of opinion, but one of physics and math. Spring rate will go up if you reduce the number of coils in the system. See the equations and links posted by Gunman. |
#100 |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | wparsons (01-26-2016) |
#101 |
Guys, go look at the stock springs. If you're cutting enough out to only lower it 1/2", you're not cutting the active coils.
#102 |
Any decrease in dead coil length will turn some of the live cool into dead coil to replace that now missing length. For .5 inches it won't make a big difference in spring rate but it will some. Probably won't even be noticeable
| The Following User Says Thank You to Ashikabi For This Useful Post: | Gunman (01-26-2016) |
#103 |
Ridge Racerrrrrrrrr
Is this guy dead now?
| The Following User Says Thank You to SkAsphalt For This Useful Post: | wparsons (01-26-2016) |
#104 | |
That's not how dead coils work. They aren't the same rate as the main part of the spring, they're just used to locate the spring and take up space so the spring isn't rattling around with the shock fully extended.
#105 |
Drives: 2019 Mazda Miata RF
You don't cut the closed end of the coil off, you still want that to locate the spring. You would trim coil from the open end. The small bit at the end of the open coil that sits against the helix is the "dead" portion on that end. It will always be at the end, regardless of how much you trim off, because that small section at the end will always sit against the helix.
#106 |
Drives: 2016 Oceanic, "base" model
In the interest of collecting information, can you let us know how you know? I've cut springs and never had any problems... I used an abrasive wheel: cut a bit, let it cool, repeat. About 1/2" on either side of the coil got red hot but no more. Quenched it when I was done, just because didn't want to wait for it to air-cool.
Funny story: a friend of mine tried to cut his springs but he only had a hack saw. He spent hours on one spring and was able to knick it about 1/8". When he heard I had the abrasive wheel, he brought his springs to me and it took me a few minutes to cut them. |
#108 | |
That Guy
#109 |
Quenching would not be good here
#110 | |
Drives: 2013 Brz C38 (bought not built :P)
#111 | ||
So, how much did you cut and how, that would cause those symptoms you describe? Oh, and I guess "quenching" is not quite the correct word since it has a specific meaning in metallurgy. I should have said I would spray the spring end after the red glow went away to cool it faster. |
#112 | |
| Tags |
| #builtnotbought |
| Cutting Sway Bar End Links | mcrane | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-18-2019 10:41 PM |
| Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers | b2autodesigns | Brakes, Suspension, Chassis | 818 | 09-10-2017 09:33 AM |
| Cutting apart the rear bumper | SavingManuals | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 06-19-2016 06:47 PM |
| Hesitation/Cutting out in 5th and 6th gear | WRBRZ | Engine, Exhaust, Transmission | 5 | 08-05-2013 01:21 AM |
| Waterjet metal cutting? | DarrenDriven | Northwest | 18 | 09-14-2012 11:13 PM |
