86WORX
go_a_way1
Old 01-24-2016, 07:46 PM   #85
Gunman
Drives: 2019 Mazda Miata RF
IMHO "closed, not ground".
Definitely cut from the open end, the closed end helps locate the spring.
Gunman is offline   Reply With Quote
Old 01-25-2016, 10:57 AM   #86
wparsons
wparsons's Avatar
Originally Posted by Gunman View Post
By cutting the coil, you reduce the over all length, thus reducing the amount of active coils, and this increases the spring rate.
Assuming the spring is completely linear, just cutting some of the spring off won't change the spring rate at all.
It'll change the total force needed to fully compress the spring, but not the spring rate.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Cole (01-25-2016), Toyarzee (01-25-2016)
Old 01-25-2016, 12:49 PM   #87
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
cutting springs also weakens them near the cut and makes them prone to snap near the cut
Yes, yes it does... ask me how I know
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
go_a_way1 (01-25-2016)
Old 01-25-2016, 12:51 PM   #88
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thankyou haha!!
I still wana see what happens when he cuts his springs so share after he is done
Old 01-25-2016, 12:56 PM   #89
fumanchu1
@go_a_way1 this?: Coming up next at the 6 o clock news, a frs/brz jumps off the road after a suspension failure that sent the vehicle rambling down a cliff after a loss of control in a mountain road
Old 01-25-2016, 01:05 PM   #90
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
more like this cuz he cant corner anymore
Old 01-25-2016, 07:42 PM   #91
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
lol, I love how we're discussing a way of saving <$300 on a $25,000 car with potentially adverse consequences.
pushrod is offline   Reply With Quote
The Following 2 Users Say Thank You to pushrod For This Useful Post:
strat61caster (01-25-2016), Toyarzee (01-25-2016)
Old 01-25-2016, 07:59 PM   #92
Gunman
Thankyou haha!!
The car will be lower. Just like every other car/truck with cut coil springs.
The Following User Says Thank You to Gunman For This Useful Post:
Old 01-25-2016, 08:01 PM   #93
Gunman
Per this formula, how does reducing the number of active coils, not change the spring rate?
Spring Rate = F/S = Gd4/8ND3 where:
F = spring force.
S = spring deflection.
G = torsional modulus of the material.
d = wire diameter.
N = number of active coils.
D = mean (average) coil diameter.
Old 01-25-2016, 08:30 PM   #94
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Lol no I mean I want to see if he breaks anything else or if they car becomes unbearably bouncy
Old 01-25-2016, 08:35 PM   #95
renfield90
The Stig's German cousin
Uhh. You're contradicting yourself along with basic math/physics.
Spring rate is force divided by distance (lbs/in or N/mm across the pond). If the total force needed to fully compress the spring increases, and the distance needed to fully compress the spring decreases, then by definition spring rate has changed.
Old 01-25-2016, 09:10 PM   #96
Gunman
Of all the cars/trucks I've seen with cut springs, I've never seen anything break, and only unbearably bouncy if the bump stops aren't cut, or the frame notched in some cases.
Old 01-25-2016, 09:56 PM   #97
wparsons
wparsons's Avatar
Where did I say the force needed to fully compress the spring increased by cutting it? It would be decreased because there would be less length to compress.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Calum (01-26-2016)
Old 01-25-2016, 10:25 PM   #98
Gunman
You can play with this, reduce the number of active coils, and watch the spring rate increase:
http://www.pontiacracing.net/js_coil_spring_rate.htm
Cutting a coil spring, is the same as reducing the number of active coils.
Another:
http://www.racingsuspensionproducts....ing%20rate.htm
and one more:
https://www.easycalculation.com/phys...pring-Rate.php
#builtnotbought
Search this Thread:
Advanced Search
Cutting Sway Bar End Links mcrane Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2019 10:41 PM
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 09:33 AM
Cutting apart the rear bumper SavingManuals Cosmetic Modification (Interior/Exterior/Lighting) 32 06-19-2016 06:47 PM
Hesitation/Cutting out in 5th and 6th gear WRBRZ Engine, Exhaust, Transmission 5 08-05-2013 01:21 AM
Waterjet metal cutting? DarrenDriven Northwest 18 09-14-2012 11:13 PM
