86WORX
Old 01-17-2016, 09:42 AM   #15
smudge
Drives: Supercharged GT86
Originally Posted by Matt@Cosworth View Post
understood
I know you're committed to the HKS parts but I would highly recommend sourcing a rod with a copper beryliium bush on the little end if you can
unless the HKS part does actually have this?
I don't think it does
The main reason for the HKS kit was having the extra capacity and the brand of HKS being well known so I've got the support if anything did ever go wrong
Parts are being sent off to Japan next week so fingers crossed we get a quick and positive response
smudge is offline   Reply With Quote
Old 01-17-2016, 09:59 AM   #16
sam69
Drives: GT 86
Hey smudge with the Ozzy $ heading further south every day an LS 2 swap would be a possible option one would think .
So glad I got forged rods when I look at this
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
cl271 (01-27-2016)
Old 01-17-2016, 10:23 AM   #17
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Sorry to hear about your failure. That rod doesn't look very beefy, and this is quite similar to the high torque FA20 failures we have seen with the stock hardware. If you plan on running anything over 300 torque the only real option is to use a quality forged rod, I.E. Carrillo, Manley, or whatever Cosworth may be releasing. You may see some cast type rods with strong bolts and stroker kits used for NA applications to save weight/cost. But you won't find that on a high HP application like you're trying to do here with the supercharger.
Not to say some other factors weren't what led to the failure, but regardless I'd only go with a stout forged H beam or I beam rod when doing such a build.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
8686 (01-17-2016)
Old 01-18-2016, 06:56 AM   #18
smudge
Well that's exactly my issue. I would expect HKS to be high quality but it's confusing that the rods aren't forged liked the pistons and crank are.
We had about 260ftlbs at the wheels so we were closing in on the 300 figure you state but again HKS rate this kit to much higher figures so it shouldn't happen
Old 01-18-2016, 10:52 AM   #19
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
have you considered there was an event of large detonation during the run or some kind of installation error?
I can understand stock motors are hit and miss and can blow up anytime. I also understand there's always the possibility an HKS part slipped through quality control (although would be unlikely).
Although I agree stock rods are weak, I for one have been running at 383 wtq for two years now, and they held on the dyno and a few runs at 471 wtq.
Of course, my experience does not mean any and all stock rods can take that much power. I know stock rods have bent on very mild builds, but man that kind of carnage with just around 260 lb-ft is unbelievable.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
RobertPaulson (01-20-2016)
Old 01-18-2016, 11:30 AM   #20
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
In for updates.
Instagram: trevor.parque
Old 01-18-2016, 11:38 AM   #21
celek
Resident Gear Head
celek's Avatar
I am sorry to here this.
Although HKS states Forged Crank and Forged pistons.
Directly from the site it says:
POINT-2:CONNECTING ROD
Specific connecting rods have been designed to suit the longer stroke.
With no engine modifications, a special size crank pin has been set requiring new bearings.
※The crank metals (Nissan RB26 & SR) must be purchased separately.
High strength I beam design and revised connecting rod bolt size.
Nothing about being forged. They are probably a Billet rod to reduce production costs VS making a new forging for the rod. Although all the new F motors from Subaru are going with a Angled rod we may be in luck in the future for kits from HKS.
The other reason I skipped HKS's full kit on my build and only purchased the crank was the Rod to stroke ratio. Although not stated on the site I doubt they got back to anything near stock which kills the top power and has a severe rod angle in the case against the cylinder wall. Which can result with the OP results.
Source:
http://www.hks-power.co.jp/en/produc...city/fa20.html
2.3ltr Build below
http://www.ft86club.com/forums/showthread.php?t=63901
celek is offline   Reply With Quote
Old 01-18-2016, 11:49 AM   #22
ajc209
Drives: GT86 Cosworth
Source:
2.3ltr Build below
All the data they present there is with CAMs on an N/A car... surprised they dont talk about the SC kit.
ajc209 is offline   Reply With Quote
Old 01-19-2016, 05:39 PM   #23
smudge
No sign of det whatsoever from the logs and for I'd be surprised if it was an install error for 2 main reasons:
1. Abbey Motorsport are well known here in the UK and have done all sorts of performance engine builds across various models for decades
2. It wouldn't last 2,100miles if there was something wrong from the start
So many ideas being thrown around at the moment. Until HKS come back with their report it's hard to say really
The Following User Says Thank You to smudge For This Useful Post:
Sportsguy83 (03-13-2017)
Old 01-19-2016, 10:52 PM   #24
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Best of luck, friend. Been following your build for quite sometime. You went out with a motor, I went out with a car!
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 01-19-2016, 11:16 PM   #25
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Wow. Carnage, wtf?! In for updates, as well!
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed
1996 Mazda Miata (Track car.)
2007 Suzuki SV650 (Track bike.)
akiranakayama is offline   Reply With Quote
Old 01-19-2016, 11:26 PM   #26
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Are you going to go with HKS again once everything is fixed?
MS, CSCS, TSAC-F, CPT
Old 01-20-2016, 02:39 PM   #27
smudge
It all depends on what HKS come back with to be honest
There are 5 possible outcomes from this:
1. HKS find a fault, supply a new set of rod, compensate me for the block and installation cost - unlikely but hopeful with my contact at HKS being a good friend of mine so hopefully he can pull some strings
2. HKS find a fault and supply me with a new set of rods but won't compensate for any of the additional cost for the block or install - far from ideal as I don't really have the cash to pay for the block and install all over again
3. HKS don't offer anything and put it down to an installation issue. Then it's a difficult conversation with Abbey but this is very unlikely in my opinion
4. HKS don't offer anything but don't put it down to install issue - I MAY have a backup plan which will involve selling the 335 charger and a few other bits to fund the new project
5. Sell all the parts off the car and just be done with it - least likely option as I'm still in love with her
Time will tell...
Old 01-20-2016, 02:48 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
6. ???
7. Profit
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
smudge (01-20-2016), Spartarus (01-21-2016), Uplink (01-28-2016)
Search this Thread:
Advanced Search
