GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
01-09-2022, 09:17 PM | #15 | |
Drives: Miata
As long as they don't prove to be a weak link, think I would have to go with the BRZ. |
01-09-2022, 09:43 PM | #16 |
Drives: 2022 BRZ Limited 6 speed manual
There's definitely a pro to the steel knuckle holding up better to abuse. Most likely cheaper to replace if damaged I'd imagine. Who knows? I'm now seeing the aluminum knuckle is having aftermarket brake fitment problems. So maybe that came into play also. I preferred aluminum but not really that big of a deal
The Following User Says Thank You to PBR For This Useful Post: | timurrrr (01-10-2022) |
01-09-2022, 10:09 PM | #17 |
Drives: 2020 Toyota 86 GT 6M
yeah most gen 1 bbk's are compatible with the gr86 but not the brz cuz of the knuckle.
01-10-2022, 06:52 PM | #18 |
Drives: '13 BRZ TLM Spec
All BBK's, performance pack Brembo's, etc. that use a caliper that bolt directly to the knuckle will work fine, aluminum or steel. BBK's that use a bracket between the caliper and knuckle may have an issue. Specifically the AP Essex kits from the 2013-2020 the braket does not clear the knuckle. Essex already has measured a 2022 and is developing an new bracket that will fit. So if you are looking to lose unsprung weight on an older gen, the aluminum knuckles are a benefit.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | PBR (01-10-2022) |
01-10-2022, 06:59 PM | #19 |
Drives: 2022 GR86
Wrong.
Someone on FB already documented that the bar/bracket (that PP Brembo uses essentially like a washer/reinforcement between the bolt heads and the knuckle) doesn't fit. It's possible to attach the caliper without that bar/bracket and with shorter bolts, but the overall rigidity/durability is likely compromised. |
01-10-2022, 07:08 PM | #20 |
Time Traveller
"Feel" could definitely translate to steering feel (of which most that tested the 2022 BRZ say the steering is actually lighter than the outgoing model (lighter steering is not desirable.)
01-10-2022, 10:19 PM | #21 | |
Wonder if this means the bulk of third party bbk's are essentially universal calipers and use appropriately sized rotors and brackets to fit to various makes/models while the ones that bolt directly onto the vehicle are actually made specifically for the particular make/model
01-10-2022, 10:25 PM | #22 | |
A Ferrari 458 has light steering and is full.of feel. Less feel is not desirable. Not necessarily weight. It still weighs up niicely and is one of the best eps systems available. And that would come down mostly to tuning. The marketing and accessories along with the Japanese vids have me thinking that the GR86 is the much more image conscious car of the two. The BRZ is just a little more serious because the Toyota doesn't have to be. I'm sure they saw the numbers too. Way more manuals sold in the previous gen BRZ. Anyways you see feel in steel knuckles and I see a cheaper part. Agree to disagree. |
01-11-2022, 12:55 AM | #23 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
A couple of kg of unstrung weight at the very edge of the car will add resistance to a cars rotational inertia, and iron and aluminium flex quite differently. Whether or not its enough to feel different only time will tell - I'm sure people will be doing swaps right. |
The Following User Says Thank You to Blighty For This Useful Post: | PBR (01-11-2022) |
01-11-2022, 07:17 AM | #24 | |
01-11-2022, 09:19 AM | #25 |
The Dictater
Drives: '13 Red Scion FRS
Ok, here's the advantages/disadvantages of each.
Steel -is 3lb each heavier in this application. More unsprung weight (well, mass) is generally bad because it increases the vertical momentum of the wheel when it goes over bumps and such -has a fatigue limit, meaning it can be designed to last literally for ever. No amount of force oscillation within the stress limit will cause fatigue if designed this way. -is typically stronger than aluminum at key points that cannot be changed, such as interfaces to other components. Aluminum parts usually have different designs than their steel counterparts to make up for lower strength. However, things like holes and threads used to attach other parts have to be the same between both materials -is cheaper Aluminum -is 3lb lighter -can be designed to be as strong and stiff as a steel part, usually with less total mass (though slightly greater volume) as seen above -has no fatigue limit, meaning the part will become less strong/stiff over time and eventually fail, regardless of design. -is weaker than steel at key interface points. -costs more |
01-11-2022, 12:00 PM | #26 | |
Drives: '20 Tundra, '84 SpecE30
Great summary! Just to add, if you live in the rust belt, the aluminum will last longer than the steel because the steel won't live long enough for the fatigue limit to matter |
01-11-2022, 12:18 PM | #27 |
The Dictater
Lol. I'd be more worried about the subframes than the steering knuckles. Never had a steering knuckle rust through, but I did see my one rear subframe split into 3 subframes on my old Outback...
01-11-2022, 01:27 PM | #28 | |
Drives: '23 BRZ
So typically aluminum components will actually be a bit stiffer due to being bulkier (higher sectional moments of inertia) while also being lighter-weight, while being sufficiently stout to withstand multiple lifetimes of load cycles without loss of stiffness due to fatigue/cracking. |
The Following 5 Users Say Thank You to ZDan For This Useful Post: | Jdmjunkie (01-11-2022), PBR (01-12-2022), Spuds (01-11-2022), Tatsu333 (10-23-2022), treedodger (01-12-2022) |
Similar Threads | ||||
Drop Knuckles instead of lowering Springs or Coilovers | FRSPacNW | DIY (Do-It-Yourself) Guides | 19 | 10-09-2017 12:42 AM |
PBM modded knuckles | sid94 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 07-12-2017 05:40 PM |
Wisefab knuckles | Ryaquinn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 03-27-2014 12:28 AM |
