Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-17-2021, 11:29 AM | #1 |
Drives: 2018 Subaru BRZ Limited with PP
Exhaust Hangers Slide (exhaust misaligned)
I have a CSG Touring86 cat-back and for a while everything was perfect. I'm a bit of a perfectionist, so I was happy that initially the exhaust tips lined up dead center in the slots for them.
After a while, the cat-back has slightly shifted to one side, making both tips lean toward one side more. I checked underneath, and noticed that the stock exhaust hangers that I have, have simply shifted to one side a little more. I shifted them back, and a few weeks later I'm in the same boat again. I think it is because I always park on a slant that tilts my car a bit to one side and the heat probably lets them shift ever so slightly over time. I've tried parking the other way, but realistically I just want to solve this for good if possible. Are the aftermarket hangers like from Perrin larger or tighter than the stock ones? Would they do the trick for solving this or should I just try to stick something else along side the hangers to help block them from shifting? |
The Following User Says Thank You to Dzmitry For This Useful Post: | humfrz (09-18-2021) |
09-17-2021, 11:32 AM | #2 |
Drives: Crapcan
It could be exhaust alignment pushing it off too, that is the issue with my car. I bet if you unbolt the flange you would have a wider gap on one side of the flange.
You could try measuring the hanger rods and using something like this to keep them from shifting. https://www.amazon.com/Aobbmok-Solid...1892612&sr=8-3
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (09-17-2021) |
09-17-2021, 11:42 AM | #3 |
Bend the hangers to tweak it. Weld/clamp something to prevent the rubber from moving. Hard mount. Add hangers at opposing angles so they fight against each other
Sent from my ONEPLUS A5010 using Tapatalk |
09-17-2021, 01:57 PM | #4 | |
Both of you guys are offering the kind of solution I would think about doing. I'm just curious if any aftermarket hangers take care of this kind of issue, without having to modify/bend/clamp anything. Because if so, I'll just go with that for better strength and support. But if not, I'll do something like you guys are suggesting to hold it in place. |
09-17-2021, 02:03 PM | #5 | |
TRACKBREAD
These were wayyy tighter than my OEM hangers: https://www.rallysportdirect.com/par...nger-12mm-blue |
09-17-2021, 02:07 PM | #6 | |
Alternatively maybe you could add a wire/cable holding it over to the side Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | Dzmitry (09-17-2021) |
09-17-2021, 02:07 PM | #7 | |
09-18-2021, 05:52 PM | #9 | |
Like ol @Ashikabi suggests, just use some baling wire and wire it over. |
The Following User Says Thank You to humfrz For This Useful Post: | Dzmitry (09-18-2021) |
09-19-2021, 06:24 PM | #10 |
Drives: JRSC BRZ SOLD
I have the same exhaust and had the same problem. I installed these guys, https://www.amazon.com/gp/product/B07FLYLFP3 and haven't had an issue since.
The Following 4 Users Say Thank You to PulsarBeeerz For This Useful Post: |
09-19-2021, 09:18 PM | #11 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Another order made on PulsarBeeez recommendation for a fix. Thanks again. Just adjusted this again this week, with my new urethane hangers. No change, still shifts. Even loosened and wiggled the exhaust clamps. Still moves. Mine goes from center to driver's side.
09-20-2021, 08:53 AM | #12 |
Drives: 2013 frs base
How about a hose clamp on the shaft of the hanger.
09-20-2021, 09:14 AM | #13 |
TRACKBREAD
I did a hose clamp on each hanger for a while, it works, but the thin sheetmetal of the clamp starts cutting into the rubber hanger after a while. A shaft collar like @PulsarBeeerz linked would be better long term.
09-20-2021, 10:31 AM | #14 | |
Appreciate the info everyone, I'll try this out. Won't bother reporting back about it, but if there's some failure in the future with it, I'll mention it. |
Similar Threads | ||||
Exhaust Hangers | Maverick986 | Engine, Exhaust, Transmission | 10 | 07-27-2016 10:49 AM |
Exhaust Hangers | FrSnake | Engine, Exhaust, Transmission | 11 | 01-20-2014 01:45 PM |
exhaust hangers | jazztennor | Engine, Exhaust, Transmission | 7 | 02-19-2013 09:57 AM |
Exhaust hangers | yomchi1989 | AUSTRALIA | 4 | 12-01-2012 01:15 AM |
Rusty exhaust hangers? | finch1750 | Issues | Warranty | Recalls / TSB | 5 | 11-12-2012 12:29 AM |
