Old 07-24-2015, 12:29 PM   #393
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
@sales@delicioustuning.com is the RS running on 3.48" pulley? 312HP/234tq is pretty impressive if it is. i wanna do that on mine too! lol
Weapon86 is offline   Reply With Quote
Old 07-24-2015, 03:04 PM   #394
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
I just finished reading all 18 pages. I wanted to ask a few questions. I have been running the Vortech kit for a few years now. I got it during the spring blow out sale that Visconti did back in APR 2013. Good kit no problems, never had an issue with the tune, but I have never put it on a dyno to what kind on numbers it's putting down.
I am now wanting to get the flex fuel kit and the Fast & Go tune. I am not sure if I need them both or just the the flex fuel kit with the tune option. Dose the FF kit have the F/I tune? Dose the FF kit come with the mounting bracket? I saw that it was extra on the website.
Second, When I got the Vortech kit from Visconti it came with the smaller pulley, larger injectors and larger fuel pump. I never installed the parts. I was told that it was needed for running E-85. Is this still the case? or will the stock fuel system be fine?
Deepseadiver is offline   Reply With Quote
Old 07-24-2015, 03:46 PM   #395
Crazypinoy9
Drives: FR-S TRD RS1#1488
Originally Posted by sales@delicioustuning.com View Post
Then you should be good to go when 16.2 rolls out to everyone
Sincerely,
Zach
When this update does roll out we just need to email you with our Calibration ID#'s to get it right?
Crazypinoy9 is offline   Reply With Quote
Old 07-24-2015, 03:59 PM   #396
ft86me
ft86me's Avatar
Drives: 2013 FRS
If you want to go flex fuel, you will need the flex fuel kit from delicious, upgrade your injectors, and you will need to purchase a tune for flex fuel. From my understanding, you can use the stock fuel pump to about 12-13psi. With the pulley from vortech that comes with the kit out of the box, from what I remember, is a 9psi pulley so you should be fine with the fuel pump. You can use the smaller one that pushes 11-12psi with no problem. I was on stock injectors and fuel pump with the 11-12psi pulley before I went turbo. Currently, I am at 12psi with my turbo kit with e85 using the stock fuel pump and upgraded injectors with no issues. As for the bracket, I'm not sure if it is extra, but it cleans things up real nice and I would highly recommend it.
Hope this helps
p.s. those of you waiting for 16.2, I am on the beta and will say that it is F*CKING AMAZING! Total night and day difference. You guys will love it.
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
Old 07-24-2015, 04:27 PM   #397
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I'm not quite sure what size pulley he was running, we'd have to check the logs to see what the boost was.
Sincerely,
Zach
Old 07-24-2015, 04:30 PM   #398
DeliciousTuning
Sincerely,
Zach
If you'd like, you can PM me directly and I can give you a thorough price quote so as to stay within the rules here. As for mods, if you're going Flex Fuel you'll immediately need those upgraded injectors installed. For the short term, your stock pump is fine, but since you already have an upgraded pump laying around it would be prudent to install that at the same time. The Flex Fuel kit does come with the mounting bracket. We offer it separately for customers with other kits that use the same sensor and like our mounting solution
Sincerely,
Zach
Old 07-24-2015, 04:31 PM   #399
DeliciousTuning
We'll simply need your full name, the kit you're running, and your Dongle ID.
Sincerely,
Zach
Old 07-24-2015, 07:00 PM   #400
Crazypinoy9
Sincerely,
Zach
Sweet! Can't wait till it's released!
The Following User Says Thank You to Crazypinoy9 For This Useful Post:
Old 07-29-2015, 02:13 PM   #401
DeliciousTuning
Hey all, I'd like to announce the official of version 16.2 of our Flash & Go tunes. Version 16.2 offers these improvements over 14.65:
1. Greatly improved low end drivability.
2. Improved idle (Stock Rotating Mass & Compression).
3. Improved top end power (~5-10whp on top).
4. No more low RPM hiccups from 2-3k rpm.
5. Fuel economy maintained.
6. More responsive throttle, especially at low RPM's.
7. Scaling for nearly all MAP sensors.
8. Scaling for more injectors including FIC and ID. (DW is still preferred).
Similar to our 14.65 release, 16.2 will be available to all prior customers in one of two ways.
If you're currently running 14.65 or newer, the 16.2 update will be free of charge. For all free updates, there is a turnaround time of about seven business days. If you want to expedite your update, you are welcome to pay a $65 fee to prioritize your service.
If you're currently running a Flash & Go older than 14.65, there will be a required $65 upgrade charge. All paid updates such as these have a typical turnaround time of about three business days.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
civicdrivr (07-29-2015)
Old 07-29-2015, 05:58 PM   #402
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Sincerely,
Zach
Beautiful, so how do you go about requesting your free update for those that qualify. Thanks for the continuous updates and work.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
xxscaxx (07-30-2015)
Old 07-31-2015, 05:43 PM   #403
DeliciousTuning
Hey Yomny,
You'd simply send me an email with your full name and the kit you're running so we can locate your old file with which to update.
Sincerely,
Zach
yomny (08-01-2015)
Old 07-31-2015, 07:16 PM   #404
Crazypinoy9
Hey Yomny,
Sincerely,
Zach
And Dongle ID#
Old 08-11-2015, 06:01 PM   #405
Shit Luck
Drives: red frs
So I am still on a flash and go tune due to a lack of local tuner...
What numbers are people seeing with the flash and go tunes.
My JDL kit on a dyno made 282hp with 700cc injectors and a dw65c pump.
I am running a v14.55 tune.
Is the low power number because my tune says 91oct? I am running 93oct, my original tune showed 93oct?
Shit Luck is offline   Reply With Quote
Old 08-11-2015, 06:24 PM   #406
DeliciousTuning
Keith,
Did you happen to fix those injector harnesses that you were popping codes for a couple months back when we last spoke?
Sincerely,
Zach
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
