05-31-2017, 03:43 PM | #2311 |
Wes
Oh the headers I will be going with will be catted, and there will also be an ultra quiet resonated catted overfront pipe. So hopefully the noise will be decent
05-31-2017, 04:21 PM | #2312 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I run full ACE catless and it's nice and quiet. Not a lot of guys like the center exit but a dual should be out this year. Sent from my iPhone using Tapatalk |
05-31-2017, 04:58 PM | #2313 | |
Drives: 2013 Hot Lava Fr-s
CEL code.
i havent checked the OBDII yet but i have the same issue about car stalling on idle. CEL, traction ctrl and cruise ctrl light turned on when i was driving in the freeway. i got a 2013 fr-s so warranty on the edelbrock is out of the question. The kit was installed two months ago by a licensed installer and only running on carb tune. Only has the catback exhaust mod everything else is stock. |
06-01-2017, 01:56 PM | #2314 |
Wes
06-01-2017, 01:57 PM | #2315 |
06-01-2017, 03:19 PM | #2316 | |
Drives: Supercharged Car
Your limited powertrain warranty is no longer valid... Which is a completely separate warranty and covers different components. Last edited by itsibarra; 06-01-2017 at 08:25 PM. |
06-02-2017, 12:45 PM | #2317 | |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
06-03-2017, 05:17 PM | #2318 |
Drives: Ultramarine 2013 FR-S
Coolant pump turning on randomly
I've noticed that my kits water pump will turn on randomly when the car is not running.
I have heard it kick on a few times just walking through my garage when I haven't started the car in a day or two. My room mate confirmed that he will hear it click on randomly in the middle of the night (he sleeps right next to the garage) I've been told that it should only turn on when the ECU is powered - any ideas? Last edited by RCSlide; 06-03-2017 at 05:21 PM. Reason: added image |
06-03-2017, 09:16 PM | #2319 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
06-04-2017, 03:54 AM | #2320 | |
Drives: 2013 Firestorm FRS
"Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction." |
06-04-2017, 10:37 AM | #2321 |
Even if directly powered and not through the ignition switch (ecu does not power or switch on the coolant pump, the ignition does that) the coolant pump should not run for more than a short time after shutdown. It should run for some time after the ignition is off, presumably to avoid boilover in the intercooler matrix. The system runs a pressure cap which blows off extra pressure just like a rad cap would.
Now how the run on period is controlled I don't know but that would be where I would be looking. I should've thought it was a time delay relay which is what turbo cars like SAAB and Audi use for this function, though for the main coolant circuit since they do not have liquid intercoolers. SAAB have a tune deiay relay to run the rad fan blowing air directly into the turbo and Audi use one to run a reverse coolant pump that backflows coolant from the rad through the two turbo bearing housings to prevent oil coking. Edelbrock runs the pump to clear the hot coolant out of the intercooler after shutdown. |
06-04-2017, 10:52 AM | #2322 | |
Drives: 2015 Raven FRS
06-04-2017, 10:54 AM | #2323 | |
I also am running a carless Top Speed header which has over 35,000 miles on it with no problems. HKS dual resonated down pipe and Invidia Q300 exhaust. Very quiet which is what I want, but still sounds good when you get on it. |
06-05-2017, 06:13 AM | #2324 |
Drives: Toyota Gt86
@cgsmike ypu have a pm
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
