02-18-2021, 02:33 PM | #491 | |
Drives: 2022 BRZ sport-tech
I have noticed that the cost of NA/NB have gotten significantly more expensive. Does FM make a turbo kit for the NC? What other boost options are there? I have not read about the 2.5L too much but is it a drop in affair that uses OEM engine mounts? Basically, it just places the factory 2.0L?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
02-19-2021, 09:40 AM | #492 | |
Anti stance.
02-19-2021, 10:16 AM | #493 | |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
1. Remove oil pan, valve cover, intake manifold, all accessories from 2.5L 2. Remove sensor between cyl 2/3 3. Transfer VVT solenoid gasket from 2.5L valve cover to 2.0L valve cover 4. Install balance shaft delete plug and delete balance shaft 5. Cut notch on timing cover 6. Port match the intake manifold runners via dremel or grinder and use RTV to seal cylinder head 7. Transfer 2.0L accessories, wire harness, motor mounts to 2.5L 8. Swap VVT solenoid connector 9. Transfer crank pulley, replace diamond washers 10. Install clutch/flywheel That's ONLY the required things to get the swap working let alone refining it. IDK to me it seems like a lot of work for 7 HP and some torque. Not to mention, now you have an engine without a balance shaft (I'm actually a powertrain NVH guy so this is a big deal to me haha). Fab9 tuning has probably the most complete FI kit on the market in my opinion. Has anyone suggested a late model RX8 for the OP yet? Honestly the 09+ cars have much better reliability and at least I find that a similarly prepped RX8 is just as if not a slight bit faster than a FT86 with similar mods. There's a local guy that's in near SCCA TT T4 spec that's like a few tenths faster than me, granted he does have a small street port. I think his point was that there was four vehicles that outperformed their price bracket by magnitudes - one of those being the SS 1LE which share the same chassis as the V6 model.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
02-19-2021, 10:50 AM | #494 |
Drives: Many
VVT swap into an NA is mostly just wiring work, and requires expensive aftermarket ecu.
I think a 2.5 swap NC is easier and ultimately is probably a better car to run. (source:I have a VVT swapped 97 miata). NC fits bigger tire, more modern chassis, and 2.5 motor is cheap and easy. If you're talking about an NC, though, that's spitting distance to an ft86... The kit that I really wish existed was 2.5 swap for rx8 but that is nowhere near bolt-in. |
02-22-2021, 12:35 PM | #495 |
Drives: '12 C63 P31, '23 GRC
Fellas, please chill with the Miata conversations. Somewhat interesting, but I'm not buying a Miata. Not interested.
Put an offer in on a gorgeous and meticulously maintained C63 Friday. Owner said he wanted to think about it over the weekend. Sunday night he called me and said he changed his mind and just can't sell. Loves the car too much. This is the 3rd car for sale in the last few months that I've shown serious interest in, to only have the owner change their minds because they love the cars too much.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
The Following User Says Thank You to WolfpackS2k For This Useful Post: | CSG Mike (02-22-2021) |
02-22-2021, 01:14 PM | #496 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | CSG Mike (02-22-2021) |
02-22-2021, 01:18 PM | #497 |
Drives: Subaru BRZ
E92 M3? 8,300 redline + can get it in manual.
02-22-2021, 04:28 PM | #498 |
^It's just not ticking the right boxes for me.
Oh I didn't say 3rd C63 AMG
02-22-2021, 06:47 PM | #499 |
EDITED
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 02-22-2021 at 07:21 PM. |
02-23-2021, 01:50 AM | #500 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
02-23-2021, 08:14 AM | #501 | |
Only happy when it rains.
Drives: series.blue
The Following User Says Thank You to why? For This Useful Post: | Tokay444 (02-23-2021) |
02-23-2021, 09:34 AM | #502 |
No worries. The reason it comes up so often is it's just by far the closest thing to the twins on the market today.
Well, they did lol. Looks like the Porsche Cayenne Turbo, and the Lamborghini Urus beat the twins by way more than 10 seconds. But yeah, VIR is a different track than most of the others around the USA so take it with a grain of salt for sure.
The Following User Says Thank You to Goingnowherefast For This Useful Post: | why? (02-23-2021) |
02-23-2021, 12:05 PM | #503 |
But VIR is my home track, so it's certainly relevant to me!
Also nobody should care what a 5000 lb car can do around a track. (car or SUV). The brakes and tires will be cooked within a few laps and/or need to be replaced. It's just folly.
The Following 3 Users Say Thank You to WolfpackS2k For This Useful Post: |
02-23-2021, 12:52 PM | #504 | |
Drives: series.blue
It's really close to me, but don't they change configurations a lot? I need to go some day. |
Tags |
brz, cayman, s2000 |
Similar Threads | ||||
2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 07:03 PM |
FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 04:17 PM |
GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-27-2012 11:26 PM |
FRS/brz VS Porsche Cayman | jurjurson | FR-S / BRZ vs.... | 22 | 08-15-2012 04:14 PM |
FR-S, Cayman S, & Lexus GS | Mcdj18 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-23-2012 04:49 PM |
