Software Tuning Discuss all software tuning topics. |
05-12-2020, 05:06 PM | #1 |
Port OFT maps to Ecutek
I got annoyed during lockdown, so I would like to play a little with Ecutek.
Is it possible to port the OFT (like stage 1, 2 etc.) maps to Ecutek? I presume you have to manually copy the tables... |
05-13-2020, 06:36 AM | #2 |
Drives: FT86
If it Auto you can jist pull it into ecutek, if its manual you will need to manually transfer tavles due lc\ffs patch
you can only use non calid altered roms or ecutek will be confused |
05-14-2020, 01:05 AM | #3 |
Thanks, manual. So I'll just manually copy tables, can you point me which ones? All the cam timings and which ones?
05-14-2020, 01:14 AM | #4 |
Drives: brz 2017 hksv2
Since we are lacking compare function in our ProEcu suites, it s easy to mess with ecutek if you dont know where to go
If you want to know what s changed from oem tune in ots maps, open them in romraider together with the equivalent oem tune and use the Compare and it shows you all the modified tables then you can manually copypaste them into ecutek if you want, if you use A01G or K00G, they aren't calid hacked and they ll open in ProEcu to read from them |
The Following User Says Thank You to tomm.brz For This Useful Post: | gpvecchi (05-14-2020) |
Similar Threads | ||||
EcuTek Base maps? | Rederick | Software Tuning | 4 | 01-11-2018 06:24 AM |
EcuTek maps separate learning or not? | PR138 | Software Tuning | 2 | 08-18-2017 04:36 PM |
Ecutek Help, Can't seem to choose maps | Allan13 | Software Tuning | 5 | 12-31-2014 12:55 PM |
Can't seem to swap maps Ecutek | Vex | Software Tuning | 3 | 07-02-2014 05:57 PM |
EcuTek ProECU PI/DI Maps Added | EcuTek | Software Tuning | 1 | 12-22-2013 10:23 AM |
