03-02-2016, 09:35 AM | #239 | |
Sarcastic SOB
I have a much bigger intercooler than HKS supplies, and have deleted the intake restrictor. On stock injectors and pulley I have peak 275 WHP @ 7000 RPM using 94 octane. My tuner is pretty much the most respected one around here (Onpoint) and I am sure he has me absolutely maxed out while staying safe from detonation. Keep in mind I also have an EL header without cat, an aftermarket over pipe and an aftermarket cat back. The only stock part of my exhaust is the front pipe which I have retained since it has a cat and a resonator and I am at my loudness limit presently. 280 WHP indicates just beyond I have with my setup. I am doubtful an aftermarket front pipe will get you another 5 HP. You can use that as a reference point but also keep in mind different dynos read differently despite SAE correction. I have read conflicting opinions but it is possible Onpoint's dyno reads up to 10% higher than some other systems. So I could possibly be somewhere between 250-275 WHP depending on which dyno system. Sasha, the tuner, indicated that he typically sees around 50 HP power train loss on these cars so my BHP might be anywhere from say 295 to 325. No clutch issues at all and don't expect to have any. Firstly, the power comes on higher in the revs (think S2000), and I am pretty smooth in clutch takeup and never dump the clutch at high RPMs. The power for me isn't really for drag racing, but more for passing power. I think a positive displacement supercharger is more likely to burn a clutch.
03-02-2016, 02:04 PM | #240 | |
Drives: 2015 AOZORA EDITION
03-02-2016, 02:39 PM | #241 | |
Sarcastic SOB
Also, if you don't have a way to drive the car to the tuner after install I have an HKS FCON iS that I would lend for a security deposit. I used it fora few weeks until Sasha was available. http://www.ft86club.com/forums/showthread.php?t=92116
03-02-2016, 02:44 PM | #242 | |
03-03-2016, 03:05 AM | #243 | |
03-03-2016, 08:13 AM | #244 |
Drives: HKS
The Following 3 Users Say Thank You to Torry@HKSUSA For This Useful Post: |
03-03-2016, 03:26 PM | #245 | |
Drives: Pearl White '13 ZN6
Sent from my D5803 using Tapatalk |
03-03-2016, 03:29 PM | #246 |
Drives: HKS
03-03-2016, 06:04 PM | #247 | |
Do you guys sell different blowers? I know you don't have blower upgrade or upgrade kit in the works for this car, but if someone wanted more power could they maybe grab the one you guys have for the 2GR engine and then make their own brackets and adapt it to fit the piping? I love the design of this kit, how it sits in the engine bay, the minimal cutting and trimming, the way it leaves room for a strut bar, abd that price point is sooo good which is why I'm asking It just seems a bit disappointing that the hp cap is so low leaving you with such little room to grow. Sent from my D5803 using Tapatalk |
03-03-2016, 06:29 PM | #248 | |
Sarcastic SOB
I think they also sell non vehicle specific supercharger tuner packages but they will be more work to supply. It's on the HKS int'l website.
The Following User Says Thank You to wbradley For This Useful Post: | CxG (03-03-2016) |
03-03-2016, 06:35 PM | #249 | |
03-03-2016, 06:47 PM | #250 | |
Drives: HKS
There is an optional pulley upgrade kit ($360), which ours has on it. As for upgraded superchargers, HKS does make other superchargers but the 7040L that is included in this kit is the only designed for this kit. Ultimately, this kit is designed for easy and affordable reliable power in the 300HP range. If you're looking for big power, it probably isn't the best solution for you. |
The Following User Says Thank You to Torry@HKSUSA For This Useful Post: | CxG (03-04-2016) |
03-04-2016, 03:19 PM | #251 | |
Drives: Scion FR-S
current mods: HKS GT SC (no restrictor) V1 HKS S type oil cooler HKS 95mm pulley custom BOV TRD baffled catch can larger vertical intercooler BC I beam connecting rods ARP extreme hardware ARP head studs 12.5:1 CR pistons TI vavle springs and retainers cosworth head gaskets ft86 speedfactory uel headers FIC injectors DW fuel pump moto-east flex fuel act 6 puck act LW flywheel perrin LW crank perrin rear shift bushing perrin tranny support mtech shift springs i think thats everything haha... i cant wait to see the numbers. Last edited by Andew727; 03-04-2016 at 04:15 PM. |
The Following User Says Thank You to Andew727 For This Useful Post: | CxG (03-04-2016) |
03-04-2016, 03:42 PM | #252 | |
Sarcastic SOB
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4306 | 04-18-2024 06:23 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Five Axis Edition FR-S Owners Thread | digital_assassin | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 563 | 07-08-2015 09:22 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
Supra Owners Build Thread | BoostJunkie | Other Vehicles & General Automotive Discussions | 164 | 03-12-2012 09:37 AM |
