09-18-2014, 01:02 PM | #141 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Getting owned by your own link? Priceless. |
The Following User Says Thank You to DylanFRS For This Useful Post: | wparsons (09-18-2014) |
09-18-2014, 01:04 PM | #142 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Adding some actual experience to this thread:
I got an oil change at Toyota and they put my tire pressures back to the "driver's side door" spec. Guess what? They filled it on the coldest day this week (in the morning) and are probably a bit higher right now just due to temperature. The car almost snapped away from me when getting on the throttle on my favourite on-ramp. Didn't happen the day before... Tire pressures recommendations are just a starting point! |
The Following User Says Thank You to drewbot For This Useful Post: | wparsons (09-18-2014) |
09-18-2014, 01:23 PM | #143 |
i'm sorry, what?
Drives: Canada
heh
this thread just reminded me of this little gem [ame="https://www.youtube.com/watch?v=N2IWxqvsSY8"]Overdrift - YouTube[/ame]
The Following 4 Users Say Thank You to 7thgear For This Useful Post: |
09-18-2014, 01:50 PM | #144 | |
Wparsons!!!!!!!!!!!!!! |
The Following User Says Thank You to Tcoat For This Useful Post: | Dipstik-sportech (09-18-2014) |
09-18-2014, 04:54 PM | #145 | ||
Drives: BMW 120d
09-18-2014, 04:54 PM | #146 |
i'm sorry, what?
Drives: Canada
when you're fight is with a bubble boy holding a megaphone... any victory feels empty
09-18-2014, 04:55 PM | #147 |
Drives: BMW 120d
09-18-2014, 06:44 PM | #148 |
09-18-2014, 08:52 PM | #149 |
Eff that! A win is a win
The Following User Says Thank You to wparsons For This Useful Post: | Dipstik-sportech (09-18-2014) |
09-18-2014, 10:48 PM | #150 |
Drives: 2014 FR-S red
I have these in a 225 45 17 on stock rims, as hard as I try I can't get the back to brake loose.
Could 1 cm make that much diff.? I wanna slide once in a while. |
09-19-2014, 10:40 AM | #152 | |||
Drives: '23 BRZ
Here's how it appeared in the thread: Quote:
Greater contact patch area does not equate with greater load-carrying capacity. Greater tire volume does give greater load-carrying capacity at a given pressure, even though contact patch area is roughly the same vs. a smaller tire at the same pressure. http://www.bridgestonetrucktires.com...4/v3i4Tech.asp You could say it's the number of air molecules inside that determines the maximum load. Higher pressure means more air molecules and higher capacity. And, a bigger tire can contain more air molecules-and therefore has more capacity-than a smaller tire at the same pressure. And there's one other factor. http://www.goodyeartrucktires.com/pd...tread_S5_V.pdf A tire requires proper air pressure to adequately carry the load placed on it. The “container volume,” material properties and inflation pressure determine the load carrying capacity of the tire. |
09-19-2014, 11:06 AM | #153 |
We're not talking about extremely heavy loads here, we're talking about passenger vehicle tires.
If tire width doesn't matter, why don't you see BMW X5's driving around on 165's? The reason is because to get the contact patch area needed to support the heavy truck a 165 would need a very long contact patch (and a very flat looking tire), or extremely high pressures. If you're talking about the difference between a 215 and a 225 on the same car, sure. Take one car and two sets of wheels/tires. One set is a 215/45/17, the other is 215/50/16. Same tire make/model, so construction will be very similar. Both tires will have the same contact patch, and both have to support the same weight. Will the desired pressure in the 16's be lower because of higher volume?
09-19-2014, 11:31 AM | #154 |
You know you want it.
Drives: '13 FR-S
Oh my god. I just, I don't even know.
Thank you so much.
The Following User _________ Stay_Puft(09-13-2014) Says Thank You to MmmHamSandwich For This Useful Post: |
Similar Threads | ||||
Michelin Pilot Super sport vs hankook vs nitto | ft86me | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 52 | 03-21-2015 04:43 PM |
How durable are Michelin Pilot Super Sport on the track? | Ferrari | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-21-2014 11:55 AM |
Michelin Pilot Super Sport 225/40/18 | FastLane1000 | Wheels and Tires | 2 | 09-03-2013 12:04 PM |
Michelin Pilot Super Sport - 245/35ZR18 | Staf00 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 08-30-2013 06:13 PM |
Michelin Pilot Super Sport 17 inch | DieselBoXXer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-05-2012 10:17 PM |
