BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
11-08-2014, 08:46 PM | #1 |
Drives: 2014 BRZ Limited
Which parts are Toyota, and which parts are Subaru?
We all know the boxer engine is Subaru, and the direct injection is Toyota, but beyond that, what is what? I was following another thread about learning stick where wearing out the clutch was discussed, and having a lot of experience with Subarus, I felt like commenting not to worry, because the throw out bearing will wear out way before the clutch anyway. But then it occurred to me, I'm thinking of this car as a total Subaru, when in fact I don't even know if it's really a Subaru clutch!
11-08-2014, 10:07 PM | #2 |
Drives: 2013 BRZ Limited
From what I found the OEM clutch is an Exedy clutch(same company Subaru uses). From what I know the parts that lean towards one manufacturer are as follows.
Subaru: engine headlights(limited are adjustable like the STi) wheel studs(12x1.25) Toyota: rear diff direct injection keyless entry The rest of the car was custom designed(unibody does take after a Subaru) to be what it is or suitable parts sourced such as the Aisin transmission.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
11-08-2014, 10:56 PM | #3 |
The Angry Brit
Drives: 1991 E30 318iS
The ecu/electrical system is toyota. For instance the turn signal stalk has toyota stamped on it. I found this while switching a fog light turn stalk in to my car. I'm willing to bet the wiper stalk is the same thing and a lot of the electrical components.
11-08-2014, 10:58 PM | #4 |
Drives: car
11-08-2014, 11:38 PM | #5 |
義理チョコ
The 3 knobs for the cabin hvac and probably all the related stuff is Toyota.
Chassis/suspension is Subaru. Clutch and pedal cluster are also Subaru |
11-09-2014, 12:02 AM | #6 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
The FR-S badge is subaru - someone here had a pic of the back.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
The Following 2 Users Say Thank You to shiumai For This Useful Post: | Jrryjms07 (11-10-2014), Ultramaroon (11-09-2014) |
11-09-2014, 12:09 AM | #7 |
Drives: 2014 SWP BRZ Limited
I believe the electric steering is lifted from some lexis models. I also believe the 6-speed gearbox is an IS250 part. I could be wrong on both counts.
11-09-2014, 12:28 AM | #8 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
If I learned anything from the Internet, everything that breaks is a Subaru part, and everything that doesn't is Toyota.
The Following 8 Users Say Thank You to Bobblehead For This Useful Post: | AznBRZer (11-09-2014), GotBRZ1691 (11-10-2014), hmong337 (11-09-2014), Jrryjms07 (11-10-2014), manonastick (11-10-2014), maxjedi (11-09-2014), NIN69 (11-09-2014), strat61caster (11-09-2014) |
11-09-2014, 12:30 AM | #9 | |
義理チョコ
Were we (and Aisin) wrong about the BRZ / FR-S / GT 86 manual transmission? Or is Scion? |
11-09-2014, 12:58 AM | #10 |
Drives: 2014 SWP BRZ LIMITED
Um WRX platform? Bueller.......bueller?
11-09-2014, 01:08 AM | #11 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Trans is an asin tl70
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
11-09-2014, 04:18 AM | #12 |
Drives: 2023 Subaru BRZ
This thread has done a good job at showing most of the important components.
http://www.ft86club.com/forums/showthread.php?t=71898 |
The Following User Says Thank You to Jegan_V For This Useful Post: | Bristecom (11-11-2014) |
11-09-2014, 11:00 AM | #13 |
I rented a Camry last week. I think all the stalks were the same, including the cruise control. I rent cars a lot for my job, so every time I drive something new I have to figure out where things are. It was strange to get into the Camry for the first time and already know where all the controls were.
11-09-2014, 11:11 AM | #14 |
Sarcastic SOB
Denso electrial parts and Aisin tranny all fall under the Toyota umbrella I believe.
So in general, fuel injection, much electrical and tranny is Toyota. Also, various switch gear. Chassis, suspension, engine and virtually everything else Subaru. Concept and styling Toyota. Execution and assembly Subaru. Safe to say neither could have made this car without the other. Financially, Subaru needed Toyota. For the boxer engine and available production facilities Toyota needed Subaru. Toyota conceived the idea, Subaru eventually capitulated. This is probably the most visible benefit of Toyota acquiring 17% stake in Subaru.
Similar Threads | ||||
Toyota vs Subaru parts prices???! | Minovsky | CANADA | 5 | 07-18-2013 08:43 AM |
Subaru vs Toyota parts pricing | Turdinator | AUSTRALIA | 17 | 03-07-2013 10:07 PM |
Toyota vs Subaru Parts | 86drift | AUSTRALIA | 9 | 11-12-2012 06:51 PM |
[Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 10:30 AM |
