Old 12-30-2013, 03:30 PM   #43
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Thanks for the part #. Put it in my Amazon cart.
It was kind of a pain to put it in my cart for some reason. I just ended up clicking the 'add to cart' button on the "bundle" and removed the unnecessary part from the cart.
SloS14 is offline   Reply With Quote
Old 01-07-2014, 10:09 AM   #44
Captain Stall
OK, here we g...oh, wait
Captain Stall's Avatar
Drives: '13 Hot Lava 6M
Don't forget your local auto parts shop. I just picked up an AUTO EXTRA Part # 616-24524 (matches the WIX 24524) for *$10.99* + tax = $12.42. There's even installation instructions in the box.
Make sure you ask for a Honda Fit filter. I first asked for an FR-S filter and was quoted $42.05.
Captain Stall is offline   Reply With Quote
Old 01-09-2014, 08:59 PM   #45
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
Originally Posted by SPEEDGOD View Post
I just changed it with the Fram 10549 it's a near perfect fit about 1/8mm longer which is better in terms of a tighter fit
and the filter door still shuts properly after inserting it in
Also do not use pliers it is definitely unneccesary. I damaged the pin but no biggy. The trick is to put more pressure on the arm and push it to right side (while applying a slight upward pressure on the pin)
Sent from my SM-N900W8 using Tapatalk
So I ordered this filter and was wondering, do you make arrow face downward or upward?
JohnAyySays is offline   Reply With Quote
Old 01-10-2014, 01:22 AM   #46
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
I faced it downwards but I dunno if that's right...
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 01-10-2014, 01:34 AM   #47
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by F3dzo View Post
Attachment 32979
25,000 miles
Damn it's time to replace mine then :0
Carlitoz3 is offline   Reply With Quote
Old 01-17-2014, 01:03 AM   #48
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'm going to O'Reilly's for a replacement cabin filter .. funny thing is its $31 for FR-S version and $15.99 for Honda Fit.
Dimension is different by oh so much:
FRS:
  • Length (In): 7.240 Inch
  • Width (In): 7.051 Inch
  • Height (In): 1.140 Inch
Fit:
  • Width (In): 7.050 Inch
Gunna be trying out WIX's products
Old 01-17-2014, 12:47 PM   #49
andrew20195
Drives: 2013 Subaru BRZ
The filter is on the suction side of the blower, so the airflow arrow should face down, towards the blower. Some filters have an "up" arrow rather than an airflow arrow. That should obviously face up. :-p
andrew20195 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew20195 For This Useful Post:
invaliduser (11-29-2015), yamsta (09-06-2014)
Old 01-17-2014, 09:30 PM   #50
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
So I tossed in the Wix filter .. so far I'm not seeing any difference ..
I'm kind of disapointed .. my AC still a bit stinky .. maybe it'll take a few more miles than the ~10 i tossed on it so far ..
i put the arrow pointing up like as it was in the stock set up .. tbh im sure it doesnt even matter.
Old 01-18-2014, 04:36 AM   #51
JohnAyySays
I used the Fram CF10549 and I noticed the smell in my car went away. Only reason why I went with the Fram was because it's carbon activated I believe and it also has baking soda. Here is the link that I purchased mines and the fit is almost perfect like the above post said.
[ame="http://www.amazon.com/CF10549-Fresh-Breeze-Cabin-Filter/dp/B002NEWUGI"]FRAM CF10549 Fresh Breeze Cabin Air Filter : Amazon.com : Automotive[/ame]
Old 01-18-2014, 09:51 AM   #52
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Would just like to confirm if that item really fits.
andrewFT86 is offline   Reply With Quote
The Following User Says Thank You to andrewFT86 For This Useful Post:
chas3wba0 (10-15-2014)
Old 01-18-2014, 04:38 PM   #53
nayrk
Drives: 2013 Asphalt Scion FRS
Fits =P
It fits. I just installed it yesterday.
nayrk is offline   Reply With Quote
The Following 4 Users Say Thank You to nayrk For This Useful Post:
akahenry (03-14-2015), andrewFT86 (01-20-2014), chas3wba0 (10-15-2014), flippy (12-30-2014)
Old 01-18-2014, 04:47 PM   #54
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Thanks for the heads-up on the Fram filter... ordered.
cobrabyte is offline   Reply With Quote
Old 01-18-2014, 04:52 PM   #55
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I thought i'd add some other options out there haha
and it was only $15 at a nearby store :P
Update 1/12/14: ok so after a few more miles the Wix filter is doing its job so it seems - smells are gone (even though my friend puked in my car - dw i had a bin for her to puke in) but what I noticed is that the filter seems to be impeding my AC - less air flow than stock in other words :X
not necesarilly a bad thing its very minimal and can just be comparing a used air filter to a brand spanking new one that needs breaking in heh
Old 01-25-2014, 08:31 PM   #56
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Just installed this (FRAM CF10549), fits pretty great. It's probably 3x heavier than the stock filter, much denser element.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
air filter, cabin air filter, diy
Safety Inspection Sticker Mount Philz0r Hawaii 13 06-12-2015 02:29 PM
brake pad inspection sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-05-2013 09:22 PM
inspection sticker question wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 6 12-02-2012 04:48 PM
PIC 10K TRD Air Filter Inspection Yruyur Scion FR-S / Toyota 86 GT86 General Forum 8 10-07-2012 01:53 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
